1 Continuous MCPWM at a time
Results 1 to 40 of 47
    Default Re: 1 Continuous MCPWM at a time
    You're getting the picture..
    12kHz you tried before bumped it up over 10-bit resolution. If you're stuck with 10-bit A/D just figure out a frequency with 10-bit resolution.
    I think 12kHz worked out to around 10.7-bit, but it was enough to shift it up >10-bits.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2011
    My oscillator is 20MHz, and my PWM can't be over 15 KHz frequency.
    If I understand this right, (with the formula resolution page 185, equation 18-4), to have a 10 bit resolution to match the analogue/digital module, I probably need to change the value of my oscillator ? (as I don't want a PWM frequency above 14KHz).
    You should be able to divide the frequency by setting it up for Center-Aligned mode. Try my example for 19.455kHz, change PTCON0 = 0 to PTCON0 = 2.
    That should give you roughly 9.7kHz, and let you keep the 10-bit resolution.
    At least that's my guess after reading the note just above table 18-2. Seems like it would work just fine, and you can keep the 20MHz osc. If this freq will work for you?
    -Bruce
    tech at rentron.com
    Jul 2011
    yes, that would work, thank you, I will try that first thing in the morning tomorrow I will, of course, let you know.
    Thanks again for the help, really appreciate !
    Jul 2011
    I have tried this, and it is still at 68% duty cycle maximum... I also tried with a 4MHz oscillator and PTCON0 = 0, and it gives also 68%.
    What are we missing ?
    Getting desesperate as I thought this would work but it seems it's not really the problem.. is it ?
    Have you checked the output of your potentiometer? It works just as expected for me from 0 to 100% duty-cycle on an 18F4431 @ 20MHz.
    Try the attached without making any changes.
    PCPWM_AD.txt
    -Bruce
    tech at rentron.com
    Jul 2011
    Thanks it is working now, I made a huge mistake that I am so ashamed to make you waste your time with me. I am testing everything on a breadboard and my potentiometer was still connected to a resistance somewhere... I feel silly. Well at least it is working.
    I am grateful for your time and your patience.
    I am now getting started with my commutation sequence. Thank you again !
    Even if this pic is complicated, I'm starting to see how powerful it is.
