1 Continuous MCPWM at a time
Page 1 of 2 12 LastLast
Results 1 to 40 of 47
    Jul 2011
    Default 1 Continuous MCPWM at a time
    Hello guys,
    I am currently trying to use the MCPWM on my pic18F4331 (20 MHZ external oscillator)
    I am trying to control a brushless dc motor with 12 IGBT's so I need 12 outputs. Amongst these 6 outputs, I want to use the PMW0 to PMW5 one at a time. Because I get inputs from my encoder, telling me when to switch which PWM.
    I have been searching the forum, and it helped me a lot, I have used the code described here : http://www.picbasic.co.uk/forum/show...3820#post43820
    I'm looking over the datasheet, i'm still pretty new at this but, i can't figure out how to use one pwm at a time. (I only need one duty cycle for all of them)
    Thank you very much in advance for your answers..
    Default Re: 1 Continuous MCPWM at a time
    Barney,
    Have a look at this thread. One of the guys discovered that the "ovdcond" register can be used to switch
    the pwms on and off.
    http://www.picbasic.co.uk/forum/show...hlight=ovdcond
    Jul 2011
    Hello mark_s,
    Thank you for your quick reply, it is exactly what I was looking for.
    I Know need to adjust my pwm duty cycle with a potentiometer 1K on AN0.
    Is 1K enough ?
    Can someone help me to understand the process with that A/D module ?
    I'm not sure i'm understanding quite well the process.
    Jul 2011
    Question
    Hello, it's me again.
    I went through the registers in the datasheet and used the example of Bruce here : http://www.picbasic.co.uk/forum/showthread.php?t=6768
    I tried to understand and apply it to my case, but it's not doing anything my duty cycle ?
    Thank you in advance for your help, it'd be really appreciated
    Duty VAR Word
    TRISA  = %11111111
    TRISB  = %00000000
    TRISC  = %00000010
    TRISD  = %00000000
    TRISE  = %00000000
     ' Analog setup
        ' Single shot, single channel, Group A is taken and converted, A/D converter enabled
        ADCON0 = %00000001
        ADCON1 = %00010000
        ADCON2 = %11001111   ' Right justified, 24 Tad, Frc
        ADCON3 = 0           ' Disable all triggers
        ADCHS = 0            ' Channel select for AN0
        ANSEL0 = %00000001   ' AN0 analog input, rest digital
    PORTB = 0
    PORTD = 0 ' clear port
    PTCON0=$00 'timebase
    PTPERL=$A0 ' $01A0 = 12kHz
    PTPERH=$01
    PWMCON0 = %01001111
    PWMCON1=%00000001
    DTCON=$00
    OVDCOND = %00000000
    OVDCONS = %00000000 'PORT PINS
    PDC0L=$00
    PDC0H=$00
    PDC1L=$00
    PDC1H=$00
    PDC2L=$00
    PDC2H=$00
    PDC0L = Duty.LowByte
    PDC0H = Duty.HighByte
    PDC1L = Duty.LowByte
    PDC1H = Duty.HighByte
    PDC2L = Duty.LowByte
    PDC2H = Duty.HighByte
    PTCON1=%10000000
    GoTo Main
        ADCON0.1 = 1         ' Start the conversion
        While ADCON0.1=1     ' Wait for it to complete
        Wend
        Duty.HighByte = ADRESH ' get result from AN0
        Duty.LowByte = ADRESL  ' Increment buffer pointer
        OVDCOND = %00000010 'PWM on PWM1
    Is this all of your code? If it is, can you explain what you "think" should be happening, and how you know it's not?
    Folks here love to help, but what you're showing here doesn't indicate even a modest amount of homework..;o)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2010
    Maryland, USA
    If it is the entire code, maybe looping back to main would help? Otherwise I agree with Bruce.
    -Bert
    Something like this might help so it doesn't drop-off the end and restart from the beginning. It also loads the new duty-cycle values.
    PTCON1=%10000000
       Wend
       GoTo Main
    It's untested, but should work. I didn't check the A/D part, but it looks ok at a glance.
    You might want to insert a PAUSE before the GOTO Main?
    -Bruce
    tech at rentron.com
    Jul 2011
    Hello,
    Thank you very much for your answers guys ! For you that code is nothing but for me it is what I wrote after spending hours on the forum and on the datasheet... trying to understand what i'm writing. So I am sorry if you feel that way..
    Bruce, thank you for putting in the right order my code, it is working now but somehow when my potentiometer is at its maximum i'm only able to have 50% duty cycle ? Where does this come from ?
    We're just messing with you when you miss something simple. Don't take any of it personal..
    When you forget to loop back to Main it runs off the end and loops back to the start. But that wasn't the only problem.
    PCPWM on these can be a bit intimidating. Give this a shot.
    DEFINE OSC 20
    Duty VAR Word
    TRISA  = %11111111
    TRISB  = %00000000
    TRISC  = %00000010
    TRISD  = %00000000
    TRISE  = %00000000
     ' Analog setup
    ADCON0 = %00000001
    ADCON1 = %00010000
    PORTB = 0
    PTCON0 = 0 ' timebase
    PTPERL = 0 ' ~19.4kHz at 20MHz
    PTPERH = 1
    PWMCON0 = %01001111
    PWMCON1 = %00000001
    DTCON = 0
    OVDCOND = 0
    OVDCONS = 0
    PTCON0 = 0
    PTCON1 = %10000000
       Wend
       PAUSE 500
       GoTo Main
    All-in-all I would say you're doing pretty darn good just getting started with one of the hardest to use/understand PIC types in this range....
    -Bruce
    tech at rentron.com
    Jul 2011
    Hi bruce,
    Thank you for your quick reply, and yes apparently this chip is pretty complicated but well I do not mind it's challenging.
    I have tried your code, changing the register "PTPERH" seems to do changing, I now have around 66% duty cycle.
    Now i'm looking at the datasheet of the pic page 187, and I am wondering one thing and maybe it has to do something with my duty cycle problem.
    Figure 18-11 shows the duty cycle comparison. Now PTMR(H and L) has 14 bits with 2 reserved for a clock and PDC(H and L) register has 14 bits as well.
    However, tell me if I am wrong but the analog digital converter module only operate on 10 bit. Would this be one of the reason ?
    If I could figure this out, it'd be amazing.. Thank you again for your help, I really appreciate !
    You're getting the picture..
    12kHz you tried before bumped it up over 10-bit resolution. If you're stuck with 10-bit A/D just figure out a frequency with 10-bit resolution.
    I think 12kHz worked out to around 10.7-bit, but it was enough to shift it up >10-bits.
    -Bruce
    tech at rentron.com
    Jul 2011
    My oscillator is 20MHz, and my PWM can't be over 15 KHz frequency.
    If I understand this right, (with the formula resolution page 185, equation 18-4), to have a 10 bit resolution to match the analogue/digital module, I probably need to change the value of my oscillator ? (as I don't want a PWM frequency above 14KHz).
    You should be able to divide the frequency by setting it up for Center-Aligned mode. Try my example for 19.455kHz, change PTCON0 = 0 to PTCON0 = 2.
    That should give you roughly 9.7kHz, and let you keep the 10-bit resolution.
    At least that's my guess after reading the note just above table 18-2. Seems like it would work just fine, and you can keep the 20MHz osc. If this freq will work for you?
    -Bruce
    tech at rentron.com
    Jul 2011
    yes, that would work, thank you, I will try that first thing in the morning tomorrow I will, of course, let you know.
    Thanks again for the help, really appreciate !
    Jul 2011
    I have tried this, and it is still at 68% duty cycle maximum... I also tried with a 4MHz oscillator and PTCON0 = 0, and it gives also 68%.
    What are we missing ?
    Getting desesperate as I thought this would work but it seems it's not really the problem.. is it ?
    Have you checked the output of your potentiometer? It works just as expected for me from 0 to 100% duty-cycle on an 18F4431 @ 20MHz.
    Try the attached without making any changes.
    PCPWM_AD.txt
    -Bruce
    tech at rentron.com
    Jul 2011
    Thanks it is working now, I made a huge mistake that I am so ashamed to make you waste your time with me. I am testing everything on a breadboard and my potentiometer was still connected to a resistance somewhere... I feel silly. Well at least it is working.
    I am grateful for your time and your patience.
    I am now getting started with my commutation sequence. Thank you again !
    Even if this pic is complicated, I'm starting to see how powerful it is.
    Been there - done that - just spank yourself, take notes & move on...
    -Bruce
    tech at rentron.com
    Jul 2011
    I did
    Hi again !
    I would like your opinions guys in terms of "state of the art" way to write a picbasic pro program
    I am getting inputs from an encoder, I have 12 positions possible, therefore 12 values. here is an example of my code for 2 values. I was wondering if the use of "Case" would be a better idea, that way if I decide to turn off my "switch" my program stops immediatly and is not finishing its loop before seeing that the switch's value changed.
    encoderstate1 var Byte
    duty var Word
    encoderstate1 = PORTA
    If switch = 1 Then
            If encoderstate = 0 Then
                GoSub GetADC
                GoSub SetPWM
                OVDCOND = %00100010 'Q4 (PWM5) and Q10 (PWM1)
                PORTC = %00000011   'Q1 and Q7 ON
            EndIf
            If encoderstate1 = 1 Then
                GoSub GetADC
                GoSub SetPWM
                OVDCOND = %00000110
                PORTC = %00001100
            EndIf
    GoTo Main
    Getadc is my subroutine for my pot and pwm to adjust the duty cycle regarding the value of the pot.
    Suggestions ?
    Sure, Select-Case is an option. It's "cleaner" but does result in slightly larger code than multiple IF-THEN statements. But if you're not short on space go ahead.
    Another option might be to use BRANCH.
    Also, perhaps you can move the GOSUB GetADC and GOSUB SetPWM to right after the If Switch=1 Then statement? That will save you a couple of bytes of program space and since, if I'm not mistaken, all twelve different encoder states calls both those routines you might as well do before evaluting the encoder value.
    Jul 2011
    Hello Henrik,
    I tried the code below with case and it does not work
    duty var Word
    If switch = 1 Then
            Select case encoderstate1
            Case 0
                GoSub GetADC
                GoSub SetPWM
            Case 1
                GoSub GetADC
                GoSub SetPWM
                OVDCOND = %00000110
                PORTC = %00001100
                End Select
    EndIf
    GoTo Main
    What am I doing wrong here ???? in my 2 cases, portA = 0 and portA = 1 in the other one (PORTA.0=1). The first code given with IF... THEN works but not this one ?
    PS : I'll try tomorrow morning (don't have access to my pic right now) to put the subroutines just once as well as that "Branch"
    Hello,
    I can't really see any problem with it.... What does doesn't work mean in this case, what does it do?
    The only think I can think of is if you have anything else connected to PortA so that the actual value assigned to EncoderState1 isn't 0 even when the encoder is in the zero-position. But since it works with the IF-THEN version it can't be that (?).
    Do you have a serial connection setup? If so you can HSEROUT some debug information which will make it easier to figure out what's going on. If not perhaps you could blink a LED the same number of times as the value that gets assigned to EncoderState1, just to see what's going on.
    Jul 2011
    Hello,
    Thank you for your reply,
    The IF...THEN code still works (thanks for the tip putting just the subroutines at the top of main).
    I am only using a PICkit 2 programmer. ?!
    What do you mean ??
    This morning I've tried a different code :
            Select encoderstate1
            Case %000000
                GoSub GetADC
                GoSub SetPWM
            Case %000001
                GoSub GetADC
                GoSub SetPWM
            Case Else
                PORTC = 0
                OVDCOND = 0
            EndSelect
    In case 0, it is doing what it should do, now if I'm trying to give the value of 1 (I have a switch on portA.0, that is all !!) it jumps to case else, it means that it does not see the value 1 ??? Why not ? it is working with IF... THEN...
    Moreover, after switching my switch and giving the value 1 to portA.0, 4seconds after, it acts like if the value on portA.0 was 0... ???
    AHHH sometimes those pics know how to make you crazy, doesn't they ?
    Thanks for the help. Very much appreciated
    It's strange if it really does work with the IF-THEN version. However, as is common on these PICs there are analog inputs on PortA. These normaly needs to be switched to digital in order to work in digital mode (no surprise) and this PIC is no exception. I know you're using the ADC in your GetADC rotuine so I know you have it setup some way or another but are you sure that the pins used for the encoder are setup as digital? (ANSEL0 and ANSEL1 registers)
    My thought with the LED was something in the line of:
    i VAR BYTE
    LED VAR PortB.7
    EncoderState1 = PortA
    For i = 0 to EncoderState1
      High LED
      Pause 200
      Low LED
      Pause 200
    NEXT
    'Rest of code
    Pause 2000  'Just to make a visual "mark" that the loop starts over
    Goto Main
    This should make the LED blink the number of times equal to the value loaded into EncoderState1. It should help you figure out what's going on.
    My money is on the ADC being configured to have its inputs on some of the pins you're trying to use as digital. I don't know why it seems to work with the IF-THEN version though....
    If this doesn't help can you post a schematic and the complete code?
    Jul 2011
    Hello,
    I'll try this as soon as I can. I have configured correctly ANSEL0 and ANSEL1 and I'm using my pot on AN6 in order to have all of my inputs encoder on portA.
    Now, if this doesn't work i'll post my code and everything.
    However is there anyway to switch off my commutation sequence anytime using IF.THEN ? for instance :
    main :
    If switch=1 then
        if encoder=1 then
        PWM 1,2
        else if encoder = 2
        PWM 2,3     ==> I'm turning my Switch "Start/stop" here and I want the program to stop everything here and not wait the end of the loop ?
        else if encoder= 3
        PWM 4,3
        Endif
    Endif
    Goto Main
    Jul 2011
    The case code now works, now idea what happened... ?
    Now I have another question (I'm still interested about the one in the previous post).
    When I move my motor forward, my encoder gives 12 different values, however, when I will operate it backward, I have still 12 steps but within these steps there are some similar values.
    for example :
    0, 32, 48, 56, 60, 62, 63, 62, 60, 56, 48, 32
    Now for these 12 steps I need to activate different pins even though some values are the same, from my understanding, I will not be able to use select case / case in that "case" lol ?
    What is this encoder you're using? Is it some kind of resolver with digital output? And why does the seqeunce change (not just reversing) when you reverese the direction of rotation? Or am I missunderstanding?
    If knowing the intended direction of rotation isn't enough then I currently don't see how it's going to be done since the sequence is the same in both directions.
    Are you sure you don't have a second output on that encoder? This looks like a low resolution sine-wave to me which leads me to belive what you have is some kind of SIN/COS resolver with a digital interface. (?) Do you have a datasheet you can link to?
    The MCPWM module on the '4431 has dedicated faultinputs which can be setup to shut down the PWM. Either until the fault-input is cleared (good for cycle-by-cycle current limit) or untill a fault reset of the module is performed. Perhaps you could use that to stop the commutation. Otherwise you'll simply need to check the state of the switch as often as you need to - or use an external interrupt.
    Jul 2011
    Hello,
    Sorry for the late reply, it is nothing complicated like that. it is just 6 optical switches mounted on the rotor therefore 6 inputs on my pic that gives me a truth table. (in function of the inputs ON or OFF, I know what phases of the motor I need to turn ON/OFF).
    For the clockwise rotation, it goes like this :
    000000
    000001
    000011
    000111
    001111
    011111
    111111
    111110
    111100
    etc
    and for anti clockwise it goes like this :
    000000
    100000
    110000
    111000
    111100
    111110
    111111
    111110
    111100
    etc, as you can see for anti clockwise I am getting the same values but it is not the same phases ON, I need to turn ON (for 360 mechanical degrees, I have 3 times these 12 "cases").
    Can you give me a simple example ?
    Many thanks again for your answers
    OK, if I get this right it should be enough to remember the previous state of the input.
    FWD: 0,1,3,7,15,31,63,62,60,56,48,32
    REV: 0,32,48,56,60,62,63,31,15,7,3,1
    If the current state is 15 and the previous state is 7 we're going forward, if the current state is 15 and the previous state is 31 we're going backwards.
    EncoderState = PortA
    If EncoderState <> OldState THEN  ' Don't run commutation code if shaft hasn't moved.
    Select Case EncoderState
    Case 0
      If OldState = 32 THEN  'We're moving FWD
      'Code for FWD
      'Code foe REV
    Case 1
      If OldState = 0 THEN   'We're moving forward
      'Code for FWD
      'Code for REV
    Case 3
      If OldState = 1 THEN   'We're moving forward
      'Code for FWD
      'Code for REV
    ' And so on for all twelve states.
    OldState = EncoderState  'Remember current state.
    As for the switch, I just mean that if you don't think it's enough to check at the beginning of the loop you'll have to check it as often as you think is neccessary, for example in each case statement. Personally I think that it's enought to check it one time in the main loop since only one of the Case blocks will get executed anyway. But I may have missed something.
    Jul 2011
    mhhh that sounds great !!! this will work I think ! I have a switch that tells me to go forward or backward I can add it to this !
    yes effectively the switch at the top of the loop in "case code" is enough.
    However when I start my pic it won't move, will it ? because no previous state ? or am I missing something ?
    Jul 2011
    also, if my motor is moving forward and then suddendly i turn on switch to go backward, that won't be beautiful... I need to add some sort of security that allow to start the commutation code only if my pwm is 0 or something like that, no ?
    That's correct, since the shaft can be in any location on powerup you need to establish the proper encoderstate at bootup and then initialise OldState to the apropriate value depending on the desired direction of rotation - before entering the Main routine. You could do it with something like this but please doublecheck the sequence here, I'm not sure I've got it right.
    'Get index of current encoderstate, Temp will be 0-11
    Lookdown EncoderState, [0,1,3,7,15,31,63,62,60,56,48,32],Temp
    'Now initialise OldState to correct value depending on desired direction of rotation.
    If DesiredDirection = Forward THEN
      Lookup Temp, [32,0,1,3,7,15,31,63,62,60,56,48], OldState
      LookUp Temp, [1,0,7,15,31,63,62,60,56,48,32], OldState
    EndIf
    Jul 2011
    thx i'll keep try that in the morning =)
    Jul 2011
    actually this can't work because my reverse values are :
    0, 32, 48, 60, 62, 63, 62, 60, 56, 48, 32....
    I'm getting desesperate with these switches...
    Jul 2011
    fwd values : 0, 1, 3, 7, 15, 31, 63, 62, 60, 56, 48, 32
    reverse values : 0, 32, 48, 60, 62, 63, 62, 60, 56, 48, 32
    I have 2 truth tables with switches to turn on/off for these values.
    Now i have a pot and a switch start/stop and a switch fwd/reverse..
    Now we should not be able to change the sequence commutation if the pot is not 0 so I did a little code like this :
    Direction VAR bit
    direction = 0
            GoSub GetADC
            If ADRESH = 0 Then 'value of the pot stored in ADRESH
                If ADRESL = 0 Then ''value of the pot stored in ADRESH
                    direction = PORTE.1 'switch for direction
                EndIf
            EndIf
    if encoderstate = 0  then
    'switches turn ON/OFF
    elseif encoderstate = 1 then
    'switches turn on OFF
    elseif encoderstate = 3 then
    ..... etc
    I'm getting desesperate to put all this together with my switches
    and my reverse sequence with if then. ifelse isn't working properly (need to have oldstate stored like you told me, Olson no ?)
    I'm sorry, I can't keep up with you here.
    Did the Select-case version not work? Is that the reason why you're now using IF and ELSEIF? And did keeping track of the previous state thru the OldState variable not work? Or why did you skip that.
    If I got the sequence wrong did you try to correct it and see if the aproach I took would work or not or did you just abandon that idea because I had the reverese sequence wrong?
    If the only thing controling the sequence of the commutation is the desired direction then there's no reason to keep track of the previous state because then it doesn't matter.
    Jul 2011
    hello, no I did try your great ideas, the case work for the forward direction but as my elseif code the case code for the forward does not work because the second half of the commutation is the same as the previous one. So in that case I think I need to have the old case. I will keep trying experiments, thank you for your time and ideas
    Jul 2011
    Do you have a good software for schematics ??
    Personally I use EAGLE from CADSoft, other popular packages are DipTrace and KiCAD but there are many many other in various priceranges. TARGET, OrCAD, Protel, DesignSpark, EDWIN, AutoTrax are a couple that springs to mind.
    Jul 2011
    thanks eagle seems pretty nice, we have orCAD at the university but I really don't like it...
    I'm gonna try this eagle thing
