help with pic16f887
Results 1 to 40 of 61
    Try installing the free version of Micro Code Studio that came with PBP.
    Then in the toolbar click View - Compiler and Program Options.
    There will be tabs on the dialog box.
    Under Compiler click find automatically.
    Under the Assembler tab check Use MPASAM and click find automatically.
    Then when you want to compile hit the F9 key.
    That is the simplest way.
    Sep 2006
    Gee not compiling giving me one error and one warning:
    -Overwriting previous address content (2007)
    -Argument out of range. Least significant bits used
    and I did select the right chip....
    Sep 2006
    ok knocked off this line
    @ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    and its only giving the warning :-Argument out of range. Least significant bits used
    If I remove the "e"
    lcdout $FE,1, " Appuyé sur Start "
    And remove the space at
    RTCYear
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCY ear,RTCCtrl] 'read clock
    It compiles.
    Sep 2006
    Hi I finally got it to compile. Now I have a small problem writing to memory. Its actually not writing. and on the LCD its always showing 0000
    I have A0 and A1 to ground and A2 to 5v. on the eeprom 24LC1025, pins are configued correctly, is there anything in the program that will not allow a writing ???
    '// EEPROM  test program
    '//	Using the PIC16F887
    '// Define section //
    '@ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    'OSCCON = %01110000 '8 Mhz
    DEFINE OSC 8
    ANSELH = 0
    '// LCD configuration //
    DEFINE LCD_DREG PORTB 	' Set LCD Data port
    DEFINE LCD_DBIT 4 		' Set starting Data bit (0 or 4) if 4-bit bus  RB.4, RB.5, RB.6, RB.7
    DEFINE LCD_RSREG PORTB 	' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 		' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB	' Set LCD Enable port
    DEFINE LCD_EBIT 0 		' Set LCD Enable bit
    DEFINE LCD_BITS 4 		' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 		' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// PIN configuration //
    TRISB = %00000000 ' Set PORTB to all output
    TRISA = %11111111 ' Set PORTA to all input
    TRISC = %11000000 ' Set PORTC to all output
    '// Variable Declaration and initialization //
    Battery_Switch var byte
    i var byte
    j var byte
    Battery_Charge_Counter var byte
    SDApin var PORTC.4                     ' RTC data
    SCLpin var PORTC.3                     ' RTC clock
    bat var byte
    Write_Address var byte
    RTCSec var byte :RTCMin var byte :RTCHour var byte :RTCWDay var byte :RTCDay var byte :RTCMonth var byte :RTCYear var byte :RTCCtrl var byte
    lcdout $FE,1, "Bienvenue"
    lcdout $FE,$C0, "Welcome"
    pause 1500
    I2CWRITE SDApin,SCLpin,$A0,$00,[$03,$02,$05,$00,$00,$00,$00,$00] ' Write to  memory
       pause 20
    '////////////////// PROGRAM /////////////////////////
    Mainloop:
    	lcdout $FE,1, "Appuye sur Record"
    	lcdout $FE,$C0, "ou sur Show"
    	pause 200
    if PORTC.7 =0 then      'always 5v, push button to gnd
    			j=1
    			I2CRead SDApin,SCLpin,$A0,$00,[RTCSec,RTCMin,RTCHour,RTCDay]
    			lcdout $FE,1, "  Time ", dec j
    			lcdout $FE,$C0, dec RTCDay, dec RTCHour, dec RTCMin, dec RTCSec
    			pause 2000
    Endif
    goto Mainloop
    Sep 2006
    O by the way, while compiling another program, MicroCode studio does not seem to tell me where the error is unlike compiling in Picbasic pro. It only gives me this error:
    least significant bits used
    wow really helpful.... 600 lines of code
    Sep 2006
    Good morning.
    Ok a good night sleep was excellent. For the first message last night I posted at 23:03, I believe I may have to play around with the registers.. SSPCON... or perhaps others.
    Also, I may have to use A0 for write and A1 for read on the 24LC1025 EEPROM chip. I will try that tonight.
    For the second message, I still have no idea, the compiler just tell me there is a problem somewhere in the code. There must be a way ton configure MicroCode studio to be more specific, is there ?
    K
