help with pic16f887
Results 1 to 40 of 61
    Why doesn't it work in MPlab ???
    Because @ DEVICE is for PM
    The inc file tells you that.
    Sep 2006
    Ooo yes in the comment on top I will try this . I would rather learn MPlab then installing XP on my Win 7 machine.
    You do not have to learn MPLAB. If you are using Micro Code Studio, or whatever for an editor, just tell it to use MPASM for the assembler.
    Sep 2006
    HUmmm..
    I am using Notepad++ as my editor and just use the command in Dos to complie. Iwould use MPLAB strictly to program my chip.
    Now that I have Win7, I cannot compile in Dos and I found out how in MPLAB.
    Why would I want to use MPASM for the assembler as you mention earlier ??
    What is that going to give me more, any advantage ?
    thanks
    K
    You can still use DOS.
    Here is the guts of a *.bat file. Running Win7 64 bit.
    Change the paths and file name as needed.
    cd
    c:\pbp\pbpw -e -s -ac:\C:\Program Files (x86)\Microchip\MPASM Suite -p16f676  C:\PICPROGS\T1\T1.bas
    cd C:\Program Files (x86)\Microchip\MPASM Suite
    MPASMWIN.exe /e C:\PICPROGS\T1\T1.ASM
    cd\
    Because you need it for the 18F parts and basically more advanced "stuff".
    Sep 2006
    Ok I am home now and ready to make it work.
    I tried to compile it and it would not work I went into the the build configuration menu and removed the pasmwin option.
    here is what I am getting now in MPLAB:
    Executing: "C:\PBP2.60\PBPMPLAB.BAT" -p16F887 "C:\PBP2.60\eeprom.bas"
    Executing: "C:\PBP2.60\PBPW.EXE" -p16F887 "C:\PBP2.60\eeprom.bas"
    PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute PM.EXE.Halting build on first failure as requested.
    BUILD FAILED: Tue Nov 30 18:26:11 2010
    and my code:
    '// Define section //
    @ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    OSCCON = %01110000 '8 Mhz
    DEFINE OSC 8
    ANSELH = 0
    Up in post #3 you were using mpasm, now you are using PM with MPLAB...
    I do not understand.
