For the baud rate to be timed right, PicBasic needs to told exactly what frequency the crystal is. PicBasic only allows certain crystals to be defined. Here are the settings allowed: MHz: 3(3.58) 4 8 10 12 16 20 24 25 32 33 40 48 64. Of course your chip has restrictions as well. (It max's out at 20 mhz).
If you have a 16mhz crystal, you might give it a try while you wait for a 20mhz to come in. 38400 baud works with debug out at 8 mhz, so at 16mhz I figure your 57600 might work. In the meantime, you could connect the gps to a max232 device, and change the baud lower with your computer. Then you could connect it to your pic at a lower baud rate, using a lower speed crystal. But 20mhz is highly recommended.
