3.3v signals to 5v signals
Results 1 to 13 of 13
    Default 3.3v signals to 5v signals
    Hi, can I use pull-ups to allow the PIC to properly receive the 3.3v signals from a SPI Radio module? Thanks
    Oct 2003
    holland
    No, you have to build a level converter to convert your signal from 3.3 to 5 volt.(possible with 1 transistor)
    3.3 v could be enough to be considered as a high level signal. Maybe you could just use it without anything in between. Depending your PIC, you could also use the built-in comparator and use it as a level converter as well.
    Feb 2003
    I have a USB Serial module that I use with my PIC projects.
    http://www.dontronics-shop.com/produ...roductid=16141
    That has 3.3V lines for TX and RX. I just use a 1k resistor between that and the PIC and it works fine
    If you were only going from the 3.3v device to an input then direct connection would probably be OK but if you send any signals back from the PIC then without a limiting resistor it would probably damage the 3.3v device.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    I tried your schematic, and all it does is cause my PIC to reset, and directly connecting just reads in jibberish
    Sep 2003
    Vermont
    I use 5 volt PICs and 3 volt PICs or other devices together all the time. Never had an issue as long as a resistor was put between them. (1 to 10K).
    That is true, but my problem is that the PIC is looking for 5v signals, and the radio module is only supplying 3.3v signals, so the PIC doesn't properly read the module's output.
    Sep 2003
    Vermont
    Depending on the PIC and port pin, a "1" will be any voltage over 1.8 to 2 volts. 3.3 will look like a "1", not a "0". If the PIC is not seeing a "1", something else is wrong. Check the "Tris registers, and if you want to prove the trip point of the PIC yourself, hook a 10K potentiometer to B+ and ground.Next hook the wiper to the pin in question. Write a short program to turn on a LED when the pin goes positive(and off when a zero).Next, measure the voltage.If it's over 3 volts, I'll buy the coffee!
    Dec 2005
    At least on the PICs I use the hardware SPI pins have Schmidt Trigger buffers and need 0.7*Vcc (3.5V @ 5V) for a logic high.
    Italy
    Some links.
    Best regards,
    Luciano
    Interfacing 3V and 5V applications:
    http://www.semiconductors.philips.co...otes/AN240.pdf
    Voltage Level Conversion:
    http://focus.ti.com/lit/an/swra071/swra071.pdf
    5V to 3.3V and back from 3.3V to 5V
    (Works down to 1.5V)
    74LVC4245A Octal dual supply translating transceiver; 3-state
    http://www.semiconductors.philips.co...LVC4245A_5.pdf
    MAX3370/MAX3371 logic level translators
    http://pdfserv.maxim-ic.com/en/ds/MAX3370-MAX3371.pdf
    More level translators from Maxim:
    http://para.maxim-ic.com/cache/en/results/5043.html
    5V to 3.3V
    Inputs can be driven from either 3.3 or 5 V devices.
    (The 74LVC125A and 74LVC244A will not replace the 74LVC4245A or the MAX3370/MAX337).
    74LVC125A:
    http://www.semiconductors.philips.co...4LVC125A_4.pdf
    74LVC244A:
    http://www.semiconductors.philips.co...LVCH244A_4.pdf
    Ok, I successfully got it to receive data using a LVC chip. Now, I have a GPS (CW20 from Navsync - email them for free samples - you just need an antenna) and it has a very vague data sheet. My oscilloscope says it is operating it's serial output at 1.8v. How do i get the PIC to see that? I think a loop back with a max233 might work
    Italy
    Use that:
    The devices accept VCC from +2.5V to +5.5V
    and VL from +1.6V to +5.5V, allowing data transfer
    between low-voltage ASICs andhigher voltage devices.
    Best regards,
    Luciano
    Wow, thanks for your help all
  1. Generating 5v from 4 batteries
    By BobP in forum Off Topic
    Last Post: - 27th December 2009, 09:46
  2. 6V to 5V
    By Fisher in forum Schematics
    Last Post: - 11th August 2008, 17:31
  3. 5v and 7v on same board - question
    By mark.oswald in forum Schematics
    Last Post: - 28th July 2007, 23:03
  4. Pic 3.3v ?
    By scottl in forum Off Topic
    Last Post: - 8th August 2006, 12:16
  5. Replies: 5
    Last Post: - 23rd February 2005, 17:35
