Pic Speed / Instruction Speed etc
Results 1 to 7 of 7
    Lightbulb
    Hi, Jamie
    @ first ... there is a small thing I do not understand so well ...
    you count the teeth ... oK ... but the way you use rising AND falling edges make 2 transitions per tooth ... or 70 transitions per turn ...
    the way the program is written - and taking 70 transitions into account ... I get a 13200 rpm counting limit @ 4 Mhz...
    Use a hardware counter like Timer0.
    Here's one example; http://www.picbasic.co.uk/forum/showthread.php?t=10608
    If you get 2 pulses per tooth just set a 1:2 prescaler for 35 counts per rev.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2005
    alain - yeah i found that out when i tested with the scope - i just doubled the numbers in the case statements and it worked fine. As the max speed is around 8500rpm, testing it seemed fine on the bench.
    Cool
    Hi, Jamie
    ... having 3 pulses per turn and a 8500 rpm limit ... make me think of a somewhat "unusual" engine ...
    could you tell me which engine it is ... may be I can be VERY interested in ...
    Aug 2005
    suzuki v6, and i want to decode a crank trigger to run an aftermarket tacho.
    it probably will never see 8500rpm, but i want to ensure the pic is stable at least to 7000rpm
    Jul 2005
    Palmdale, CA
    Default Re: Pic Speed / Instruction Speed etc
    I know this is an old post but I made a tach adapter using a PIC 16F1824. It basiclly takes a single cylinder engine signal (1 pulse /720 degrees) and multiplies it by 4 to use a 4 cylinder tach. Works real well if you are interested, I can send you the code. It can be adapted to other situations as well. I also designed a real stable interface to the coil if you don't have a crank trigger.
