Thanks Brian.
Yes this is a one off project not a big batch, although hopefully many other RC model enthusiasts will build themselves one as it's part of an open source telemetry project using 2.4Ghz.
The sensor is actually available mounted on a small PCB for about $10 more. That may be the safest option.
I think the datasheet says only light through the small air hole is a problem on this sensor, so that should be easy to cover with something like carbon foam (antistatic chip foam).
Looks like I'm pioneering this sensor with PBP, hopefully you guys can help me cross the hard stuff when I get there in a week or so.
Martin
