Capture and compare serial data
Results 1 to 17 of 17
    Default Capture and compare serial data
    Hi Guys
    Haven't been around in a while and I hope everyone is well :-)
    I am trying to do a kind of wireless capture and compare but I have a problem on the receiving end that I lookings for some suggestions on.
    Heres the pseudo code:
    1.send/transmit 4 bytes 4 times (done and it's working!)
    2.receive the 4 bytes 4 times (the receiver receives the 4 bytes 4 times successfully -using serial port tool)
    3.Store the 4 instances/lines of 4 bytes (Here's where I have the problem)
    4.Compare lines 3 and 4 (or any of the lines with one of the others.This is the other problem I have)
    Heres my code:
    'Variables begin here
    	SYNK    VAR BYTE
        	SYNK = $7E   '126 DECIMAL, BINARY 11111110
        	TRAIN   VAR BYTE
        	TRAIN =  $B3
        	WNUM    VAR BYTE
        	XNUM    VAR BYTE
        	YNUM    VAR BYTE
        	ZNUM    VAR BYTE
        	WNUM = 31
        	XNUM = 1
        	YNUM = 2
        	znum = 2
    'end of variables
    	low led 'set led low
            If GPIO.2 = 1 then main 'check button
    send:
              for counter = 0 to 3
                DEBUG train,train,train,train,train,synk,WNUM,XNUM,YNUM,ZNUM,$d,$a
               next counter
                  high led 'set led high
                 pause 200
    So as you can see I use DEBUG to send the same this to the serial port 4 times which renders this output in the serial tool:
    ³³³³³~
    ³³³³³~
    ³³³³³~
    ³³³³³~
    which converted to DECIMAL looks like this:
    17917917917917912631122
    PERFECT but .....
    How can I receive and store each instance of WNUM,XNUM,YNUM,ZNUM.
    In other words I would like to have four instances of WNUM,XNUM,YNUM,ZNUM, so I could compare each instance of WNUM,XNUM,YNUM and ZNUM.
    What is the best way to do it ?
    Would I use 4 different arrays?
    For example array1 would hold the first line conatining the values for WNUM,XNUM,YNUM,ZNUM.
    Array2 would hold the values for the second line and array3 for line 3 and array4 for line 4.
    Some help would really be appreciated.
    Kind regards
    Dennis
    Default Apologies for the bad english ...
    In my frustration @ myself and my rush to post I really messed up the english for this line
    What it should read is :
    I am trying to do a kind of wireless capture and compare but I have a problem on the receiving end that I am looking for some suggestions on.
    Looking forward to your replies
    Thanks so much
    Dennis
    Hey Dennis,
    An array(s) would be the way to do it. Could compare separate bits or the whole array sorta like doing a checksum. Lots of possibilities.
    This may give you some ideas on how to set it up
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    Default Thanks Dave
    Dave :-)
    Thanks a million for the tip ...very helpful indeed.
    Still bashing around with the options.
    Now this is what prompted me to post this thread, if I use an array , should I use a byte or a word array ?
    Which would be the better one?
    Why choose one over the other?
    No matter what type of array I choose, I think the comparison of bytes would become rather cumbersome not so ?
    For example if I choose a word array then the first line received would receive the first 4 bytes(0 to 4) WNUM,XNUM,YNUM,ZNUM.
    The second line would be held in byte 5 to 7 not so ?
    Then to compare each line is where things start to get cumbersome I think and by that I mean lots of IF,THEN statements.
    So for example to compare lines 1 (WNUM,XNUM,YNUM and ZNUM and line 2 (WNUM,XNUM,YNUM and ZNUM I might have to do something like :
    MyWordArray var WORD [7]
    If (MyWordArray.0 and MyWordArray.1 and MyWordArray.2 and MyWordArray.3 ) = (MyWordArray.4 and MyWordArray.5 and MyWordArray.6 and MyWordArray.7) THEN DoSomething
    This doesn't look quite right :-(
    That's the problem I have ... I am really battling to somehow compare each line.
    Is there a way of doing this by sending and receiving everything as a STRING and comparing the entire string ?
    Any more suggestions would really be appreciated.
    Kind regards
    Dennis
    Sep 2005
    Campbell, CA
    Sometimes, when the strings you have to compare are very long, or when there are a lot of them, rather than compare them byte-for-byte, it is easier to use a good CRC algorithm on each one, then compare the CRCs.
    Charles Linquist
    Default a checksum..
    @Charles and Dave
    I definitely agree with the checksum idea , in fact, it is the checksum concept that has led to the confusion
    As a reference let's use this thread (thanks Art for his input!)
    http://www.picbasic.co.uk/forum/showthread.php?t=12492
    SO from that thread POST #2 one possible method of checksumming is described, since it's fairly straight forward we could use that as a reference.
    So the bytes I would like to transmit are declared as
    WNUM,XNUM,YNUM and ZNUM respectively.
    ***NOTE that this fairly trivial when comparing each byte of a single transmission BUT I am transmitting the same thing 4 times and that's whats confusing me.
    The reason I want to do it 4 (or more) times is because from what I have seen in my tests the first one and/or second received line is usually damaged/corrupted so I figured it is probably best if I compare the third and 4th transmitted lines. Does that make sense?
    Here's an example of the transmit code:
    WNUM as byte
    XNUM as byte
    YNUM as byte
    ZNUM as byte
    CHECKSUM as byte
    CHECKSUM = $3F
    'now do the XOR checksumming
    Checksum = Checksum ^ WNUM
    Checksum = Checksum ^ XNUM
    Checksum = Checksum ^ YNUM
    Checksum = Checksum ^ ZNUM
    'and now TX the data 4 times
    send:
       DEBUG train,train,train,train,train,synk,WNUM,XNUM,YNUM,ZNUM,CHECKSUM,$d,$a
               next counter
                 pause 200
    On the receiver side the code (as per the thread referenced earlier) would look like this:
        SYNK    VAR BYTE
        SYNK = $7E
        WNUM    VAR BYTE
        XNUM    VAR BYTE
        YNUM    VAR BYTE
        ZNUM    VAR BYTE
        CHECKSUM var byte 'this holds the received checksum
        CHECKSUM_CHECK var byte 'hold the XOR'd value
        Checksum_Check = $3F 'this is the checksum value to XOR with
      'Variables end here
    DEBUGIN [WAIT(SYNK),WNUM,XNUM,YNUM,ZNUM,CHECKSUM]
               ' wait for SYNK, when received store next 4 bytes in variables WNUM,XNUM,YNUM,ZNUM
               'then send these to hyperterminal or serial program or wherever
                'checksum the received bytes using XOR with 3F
                Checksum_Check = Checksum_Check ^ WNUM
                debug "xNUM checksum_check is ",HEX checksum_check
                Checksum_Check = Checksum_Check ^ XNUM
                debug "wNUM checksum_check is ",HEX checksum_check
                Checksum_Check = Checksum_Check ^ YNUM
                debug "yNUM checksum_check is ",HEX checksum_check
                Checksum_Check = Checksum_Check ^ ZNUM
                debug "zNUM checksum_check is ",HEX checksum_check
    IF Checksum_Check = Checksum THEN
    DEBUG "WNUM is ",DEC WNUM,"XNUM is ",DEC XNUM,"YNUM is ",DEC YNUM,"ZNUM is ",DEC ZNUM,$d,$a
    BUT as you can see the receive code only does its thing for each received line. I want to store all 4 lines of data then do a compare of the received lines 3 and 4.
    See the problem is if only one transmission is made (one line) and there is a corruption of a byte (checksum mismatch anywhere in the line) then the TX fails. That is why I thought to send and receive 4 lines (or more) of the same thing and then do a compare.
    I am totally confused (again)
    PLEASE HELP..........!
    Kind regards
    Dennis
    Not sure exactly what you are trying to do?
    Send the same thing four times and if any of them fail the whole thing fails? Even if one is good?
    Even doing a compare will not tell you which one is good. Only the checksum (CRC) thing will do that.
    Default something like that :-0
    Hi Dave
    Send same thing 4 times
    so
    1
    2
    3
    4
    and compare instance 3 and 4 'cos usually correction occurs on 1 and 2
    If 3 and 4 match then TX was good.
    Hope that helps
    Kind regards
    Dennis
    OK, how about this.
    Receive the first two and do nothing with that data because it is most likely bad.
    Do the checksum on data #3.
    if good then ... STOP??
    OR go on and run the check on data #4
    If #4 check then GO ON.
    No compare any where...
    MAYBE...
    Default That could work!
    @ Dave
    OK cool
    So I Will
    1. Capture all 4 lines into and array each one is 4 bytes and a checksum byte so array needs to receive 20 bytes total.
    2. Check 4 for checksum match
    Continue on ...
    It certainly seems doable and will give it a bash right away!
    Still just wondering if there is a way to capture and compare all 4 lines
    Kind regards
    Dennis
    If you really want to do each line then I guess the way would be ...
    IF array1 bit1 = array2 bit1 then
    IF array1 bit2 = array2 bit2 then
    IF array1 bit3 = array2 bit3 then
    ......on and on and on....
    But something like Charles said
    IF check1 = check2 then
    IF check2 = check3 then
    IF check3 = check4 then
    Hey. it is done...
    Sep 2005
    Campbell, CA
    Depending on what your data looks like, you can also do some neat things with:
    ARRAYREAD (name_of_first_string),(nocompare_location),(numbe r_of_chars_to_compare),[WAITSTR name_of_second_string]
    Charles Linquist
    Default rewind....
    AHA...
    That's where I'm stuck ....at step 1 I mentioned earlier ...
    I this is the line I am using to receive the data
    What must be changed in order for me receive it 4 times and build the array?
    I was playing around with this as a start..but it's here where I am stuck!
    For counter=0 To 19
             counter=counter+1
            Next
    As always any help would be appreciated
    Kind regards
    Dennis
    May 2008
    Italy
    Hi Denis, I think you could take some advantage from this thread :http://www.picbasic.co.uk/forum/showthread.php?t=12870
    In post # 4 DT is giving an interesting snippet for having 2d array in PBP.
    I don't know if you have already used bi-dimensional arrays, if not let me say that they could easy your compare problem.
    You cannot corrupt the variable within a FOR/NEXT cycle:
    For Counter =0 to 19
    counter=counter+1
    Next Counter
    You should expect some problem from this code!
    Al.
    Default Thanks to all have replied so far..
    @ Charles ..thanks a million for the tips will check them out as soon as I have the array(s) built up.
    @ Al .. Thanks for the tip there , has me wondering how I can put the 2D array to use for my a solution.
    I am guessing as a start I should replace the DEBUG sommand with something like serin2 and build the array with one command ?
    Something like :
    SerIn2 GPIO.4,T2400,500, main,[WAIT(SYNK),STR DATAIN\4]
    This would indeed create an array and store the 4 bytes and the checksum byte.
    But again I want to to do this 4 times and have either one array with the contents of each time OR I could try have 4 different arrays (one created for each time) and then check the checksum values for each array.
    Now I am wondering if I am doing the right thing , perhaps I should rather have more SYNK/qualifier bytes and send and receive one instance of the data and checksum that.
    Problem is that sometimes some corruption occurs at the receiver side so to solve this I thought it best to send more instances of the same data.
    Any more suggestions are welcome
    Kind regards
    Dennis
    Here is something else if you want to go the route of sending "good" data the first time.
    You might be able to get an idea or two... or more confused
    http://www.picbasic.co.uk/forum/showthread.php?t=12554
    Another one idea is to have the 3rd string stored in an array and then on the 4th reception compare in the serial input that string using the wait modifier
    like this:
    debugin [str my_array\4]
    and then
    debugin [waitstr my_array\4]
    I'll try to put up an example soon. I got to go now... sorry
