Thanks for all the help but I was looking at Bruce's remote example,
http://www.picbasic.co.uk/forum/showthread.php?t=12554
I thought I could also use the timer portion that could be helpful to jump out of the SERIN2 if no data is received, But ASM??? This is why I bought PicBasic Pro...
From what I understand, very little, I need to add this to my code:
DEFINE NO_CLRWDT 1 ' Watchdog timer is disabled, so we don't need to reset it
DEFINE INTHAND RESET_VT ' Interrrupt on Timer1 overflow to reset outputs in 65.5mS
' if no serial data received in this time period
SYMBOL TMR1IF = PIR1.0 ' Timer1 overflow interrupt flag (reset in int handler)
SYMBOL TMR1IE = PIE1.0 ' Timer1 interrupt enable bit
' Setup Timer1 for resets after ~65.5mS
T1CON = %00000000 ' Internal clock, 1:1 prescale, Timer1 off for now
TMR1L = 0
TMR1H = 0 ' Timer1 low & high bytes cleared
TMR1IF = 0 ' Clear Timer1 overflow flag before enabling interrupt
TMR1IE = 1 ' Enable Timer1 overflow interrupt
INTCON = %11000000 ' Global & peripheral ints enabled
chksum2 = 0 ' Clear match count
GOTO initialize ' Jump over int handler
RESET_VT
; Do interrupt stuff here
bcf T1CON,TMR1ON ; Stop Timer1
clrf TMR1L ; Clear low byte
clrf TMR1H ; Clear high byte
bcf PIR1,TMR1IF ; Clear Timer1 interrupt flag bit
DON'T KNOW ABOUT THE NEXT TWO LINES, SO I COMMENTED THOSE OUT. I BEEN READY THE DATASHEET FOR THE 16F628A, AND AT BEST GUESS TO CLEAR A SINGLE BIT ON PORTA, WHAT I SEEN IN THE DATASHEET REFERENCING WOULD BE PORTA, 1 OR PORT??1. DOESN'T COMPILE, HOW COULD I CLEAR PARTICULAR BITS HERE FOR PORTA AND PORTB?
;clrf portb ; Clear outputs on button release (or timeout)
;clrf porta ; Clear outputs on button release (or timeout)
bsf T1CON,TMR1ON ; Re-enable Timer1 before exiting interrupt handler
retfie ; Return from the interrupt
And then here is my serial in:
' Fire up Timer1 before entry to serial input routine
T1CON.0 = 1
' at 4MHz Timer1 overflows in 65536 * 1uS (~65.5mS) if no Synch byte
' and serial data arrive on time. SERIN2 timeout & label options
' are useless with a noisy RF receiver output - as noise continually
' resets the timeout period causing it to hang forever.
' Wait for Synch byte, then get new inbound data & checksum
SERIN2 serpin,16468,[wait(254),address1,address2,address3,address4,_
mydata1,mydata2,mydata3,mydata4,mydata5,mydata6]
T1CON.0 = 0 ' Stop Timer1 once we've received data
TMR1L = 0 ' Clear low byte
TMR1H = 0 ' Clear high byte
I compiled this with the rest of my code and it seems to be working fine, but am waiting for the gremlins to pop out.
Thanks a million for all the recommendations already.
