For the average user both frequencies will work about the same. Generally the higher the frequency the easier it is to to transmit through the typical Faraday cage (re-bar in walls) but 315 and 433 are pretty close.Is there any benefit of 315MHZ over 433MHZ?
I would expect around 1/2 mile line of site with these using a 1/4 wave whip antenna, good ground plane, and decent code. Of course the range is farther but it is harder to get reliable data the farther you stretch it.
Here is a code example that for the simplicity is very reliable.
http://www.picbasic.co.uk/forum/showthread.php?t=12554
I would think this code will work with the modules you are looking at.
