2D Matrix Rotation
Results 1 to 9 of 9
    Aug 2003
    Default 2D Matrix Rotation
    Hi Guys,
    Does anyone have a 2D matrix rotation algo they'd like to share?
    I'd like to rotate all bits in a byte array so:
    byte0: 00001110
    byte1: 00001111
    byte2: 00001111
    byte3: 11111111
    byte4: 11111111
    byte5: 00001111
    byte6: 00001111
    byte7: 00001110
    becomes:
    byte0: 01111110
    byte1: 11111111
    byte2: 11111111
    byte3: 11111111
    byte4: 00011000
    byte5: 00011000
    byte6: 00011000
    byte7: 00011000
    I can do this if I have a list of coordinates like this:
    x_new = y_old
    y_new = 1 - (x_old - (8 - 2))
    Do this for every coordinate (64 times) and the result is what I want.
    Art.
    Perth, Australia
    off the top of my head this is what i came up with (untested):
    array          var byte[8]
    array_rotated  var byte[8]
    bit_num        var byte
    byte_num       var byte
    temp           var byte
    result         var byte
    for byte_num=0 to 7
        for bit_num=0 to 7
            temp=array[7-bit_num]
            temp=temp>>byte_num
            result=result<<1
            result.0=temp.0
        next bit_num
        array_rotated[byte_num]=result
    next byte_num
    *edit* fixed some mistakes
    *edit* fixed one last mistake
    Aug 2003
    I did come up with a way using a very verbose drawn out method that referenced every bit,
    and copies one array to the other, but this looks much neater I'll give it a try, thanks!
    Perth, Australia
    If it works, you can repay me by sending me some of those DSE component racks you were bragging about on OCAU. Hehe j/k.
    Aug 2003
    It's a small world
    There was a little more to it than bragging.
    I was trying to find interested people to get together to possibly buy the next lot in a few months.
    But I also try to show off a bit
    Cheers, Art.
    Perth, Australia
    *wonders if any of the Perth DSE stores are willing to flog theirs off too*
    Nice routine. How about an angle turn and not exactly 90 degrees?
    I mean, to rotate an object live?
    Aug 2003
    Then you'd be needing this:
    http://www.picbasic.co.uk/forum/showthread.php?t=10528
    For the trig functions.
    Ooh, yes. I think I would.
    Thanks a lot.
  1. led matrix pic 16f84 and 4017 help me please
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 5th February 2011, 00:06
  2. RGB LED Matrix
    By ERIK in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 07:01
  3. LED Matrix Question
    By mekohler in forum Schematics
    Last Post: - 29th September 2007, 13:12
  4. 4x16 Dot Matrix LCD control is possible?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 09:56
  5. need help with switch matrix
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 18:59
