mtripoli,
You're probably right.
However the 74FXX chips cost less than $0.20 each.
Their switching speed is phenomenal...on the order of 3nS
My PIC timer project has a measurement resolution of 200nS.
Do you think that the PIC could react this fast?
This circuit kind of evolved from an earlier circuit that could control the Set and Reset function of a precision bench-top frequency counter / timer that I have. That controller needed 2 S-R latches. one of which I also use to control PIC timer for comparison
I can use the bench-top unit to determine error corrections for the PIC timer
The PIC timer uses CCP1 and TIMER1 instant interrupts to count clock pulses from a single pulse on a single pin.
The core engine of the was put together by Bruce, Based on Darrel's instant interrupts.
See: http://www.picbasic.co.uk/forum/show...01&postcount=3
Thanks for the suggestion.
Bob W.
