N-Bit_MATH
Results 1 to 39 of 39
Thread: N-Bit_MATH
    As always, a great Darrel Taylor's project!
    Thanks!
    Wow, this is going to be very cool Darrel!
    I know you said to keep trying if it wouldn't compile but I can't seem to get it to "go thru" when using it in the same program as DT-Ints... Boiled down example, this compiles:
    PRECISION CON 4 SYSTEM
    INCLUDE "N-Bit_Math.pbp"
    Setpoint VAR BYTE[PRECISION]
    Position VAR BYTE[PRECISION]
    Error VAR BYTE[PRECISION]
    Start:
    Pause 10
    Goto Start
    This does not compile (or assemble):
    INCLUDE "DT_INTS-18.pbp"             'Include the interrupt system files.
    INCLUDE "ReEnterPBP-18.pbp"
    INT_LIST    macro   ;IntSource    Label   Type   ResetFlag
           INT_Handler INT2_INT,    _DoStep,   PBP,     yes
        INT_CREATE
    @ INT_ENABLE INT2_INT
    Start:
    Pause 10
    Goto Start
    DoStep:
    Toggle PortB.7
    @ INT_RETURN
    I get a whole bunch of Symbol not previously defined FSR0L0L and so on.
    Similarily, same code as above but simply removing the INCLUDE "N-Bit_Math.pbp"-line also compiles fine so there seems to be some incompatibillity there.I'm using 18F2431 but the device selected in MCS+ doesn't seem to matter.
    Any ideas what might be the issue?
    Thanks!
    Hmmm, apparently it's laughing at my use of FSR's "FSR0L0L".
    You are correct, there is a conflict when used with DT_INTS-18.
    DT-INTS-14 is OK.
    I must find a way around it.
    Thanks Henrik.
    Thanks again Henrick.
    The FSR problem should be fixed.
    The file has been updated to version 1.1 Alpha.
    And should now work with DT-INTS-18.
    http://www.picbasic.co.uk/forum/atta...4&d=1262930635
    Cheers,
    Hey Darrel,
    Only works for me with MPASM assembler case sensitive option enabled.
    In DT_INTS-18;
    SaveFSR macro F, Pr
    RestFSR macro F, Pr
    And in N-Bit_Math:
    SAVEFSR macro
    RESTFSR macro
    Edit:
    MOVE?PP  macro BeerIN, Pout ; copy an N-bit variable to an N-bit variable
    BeerCount = 0
        while BeerCount < PRECISION
          MOVE?BB BeerIN + BeerCount, Pout + BeerCount
    BeerCount = BeerCount + 1
        endw
    Too cool --- Classic Darrel...;o)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Well, then keep case sensitivity enabled.
    OK, since it's you bruce.
    Update 1.2 Alpha ; adds ability to turn Case Sensitivity off in MPASM
    Changes SAVEFSR and RESTFSR, to FSRSAVE and FSRREST.
    I think I'll go MOVE?PP now.
    Must have missed a version update somewhere in the mix. 1.2a works as expected.
    Nice find on the math routines. Very handy. Nice work on the PBP wrappers too.
    Thanks.
    What I had tested was the 1.1 Alpha 1/4/2010 ; fixes FSR conflict with DT_INTS-18
    in post #1, which changed to 1.2 alpha within just few minutes from posting.
    -Bruce
    tech at rentron.com
