I2c write&read
Results 1 to 16 of 16
Thread: I2c write&read
    Dec 2007
    Finland
    Post Small bug
    Sorry, I had one bug there. One pause missing.
    <code><font color="#000000">CMCON = 7
    TRISA = %11000000
    TRISB = %00000000
    SDA                 <b>VAR </b>PortA.3
    SCL                 <b>VAR </b>PortA.4
    LED                 <b>VAR </b>PortB.0     <font color="#000080"><i>'Indicator LED (change if needed)
    </i></font>I2CDeviceEEprom     <b>VAR BYTE
    </b>I2CAddressEEprom    <b>VAR WORD
    </b>TEMP1               <b>VAR BYTE
    </b>TEMP2               <b>VAR BYTE
    </b>I2CDeviceEEprom=$A0     <font color="#000080"><i>'DeviceID 10100000 = $A0 = %1010 A2=0, A1=0, A0=0 R/W=0
    </i></font><b>DEFINE </b>OSC 4
        I2CAddressEEprom = 0
        TEMP1 = 1
        <b>GOSUB </b>Write_I2C
        <b>PAUSE </b>10
        <b>GOSUB </b>Read_I2C
        <b>IF </b>TEMP1 = TEMP2 <b>THEN
                HIGH </b>LED        <font color="#000080"><i>'If OK then 0.5s LED blink
                </i></font><b>PAUSE </b>500
                <b>LOW </b>LED
            <b>ELSE
                HIGH </b>LED        <font color="#000080"><i>'If FAIL then 2s LED blink
                </i></font><b>PAUSE </b>2000
                <b>LOW </b>LED
        <b>ENDIF</b>
        <b>PAUSE </b>1000        <font color="#000080"><i>'PAUSE ADDED</i></font>
        <b>GOTO </b>Main
    Write_I2C:
        <b>I2CWRITE </b>SDA, SCL, I2CDeviceEEprom, I2CAddressEEprom,[ TEMP1 ]
        <b>RETURN
    </b>Read_I2C:
        <b>I2CREAD </b>SDA, SCL, I2CDeviceEEprom, I2CAddressEEprom,[ TEMP2 ]
        <b>RETURN
    </b></code>
    Now it will blink.
    BR,
    -Gusse-
    Apr 2008
    Hello Gusse,
    thanks for your help,
    the eeprom is wrong. I replace a another one. it is ok now.
    and the R_SCL and R_SDA are either 13K or 3,3 k the light intensity and frequency does not change (by naked eyes)
    thanks again
    Minh le
    Apr 2008
    Hello Gusse,
    actually it is not necessary to " define OSC 4" it is defined in fuse ("INTCLOUT.."
    the 24lc256 it takes only 5ms to write
    thanks
    regards
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
