Problem with ports help plz
Results 1 to 34 of 34
Threaded View
  1. #32
    Quote Originally Posted by Mus.me View Post
    im using 16f84 but when i change ldata var byte to ldata var bit it complier but it doesnt work it keeps blinkin leds,i think the problem in the code and scrolling, and pic16f84 it takes 1024 words i think but i see just between 258 to 300 word, it works when i change to var bit but it doesnt scroll it shows LEDs blinkin and all off them on ????
    AND I WANT TO USE DATA EPPROM INSTEAD THE VARIABLE ldata IF SOMEONE CAN HELP ME
    Hi Mus.Me,
    OK the 16F84 does not have enough code space to do that, it will fit into a 16F628A, BUT ah say BUT, you will have to reorder the listing of the variables to avoid a bank error from PBP, and no it is not the crossing boundries error either. So I did like so:
    	ldata 		VAR BYTE[59] 'when i change to bit it shows all leds on?
    	column		var	byte
    	dchange		var	byte
    	scan 		var byte
    	scroll		var	byte
    EEprom is not so hard to do . . .why not use a lookup table ?
    for index = 0 to 19
            'ldata 0 1  2  3  4  5  6  7  8 9 10 11 12 . . . . .
    lookup index,[31,31,31,31,31,8,10,10,31,0,27,0,31,1,26,1,31,6,2,12]ldata
    Portb = ldata
    next index
  1. sleep problem help plz >>>.
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 16th November 2009, 09:21
  2. Replies: 6
    Last Post: - 10th January 2008, 11:38
  3. ESC problem plz help
    By al000y in forum mel PIC BASIC Pro
    Last Post: - 21st January 2007, 11:21
  4. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 17:46
  5. Problem with intensity.. plz help
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 18:25
