[setup.main.Window]
'-----Begin code for #main
nomainwin
WindowWidth = 550
WindowHeight = 225
UpperLeftX=int((DisplayWidth-WindowWidth)/2)
UpperLeftY=int((DisplayHeight-WindowHeight)/2)
'-----Begin GUI objects code
statictext #main.statictext1, "Code Path and Name", 5, 47, 155, 20
' TextboxColor$ = "white"
textbox #main.name, 5, 67, 530, 25
statictext #main.statictext3, "Program Memory", 5, 122, 120, 20
statictext #main.statictext4, "Chip", 10, 17, 27, 20
textbox #main.chip, 45, 17, 100, 25
statictext #main.statictext6, "Free", 240, 102, 105, 20
textbox #main.ByteWord, 130, 122, 50, 25
textbox #main.FreeWord, 210, 122, 100, 25
statictext #main.statictext8, " Used", 355, 102, 55, 20
textbox #main.UsedWords, 325, 122, 100, 25
statictext #main.statictext12, "Percent Used", 440, 102, 82, 20
textbox #main.PercentWord, 435, 122, 100, 25
button #main.btOPEN,"OPEN",[btOPEN], UL, 345, 17, 80, 25
button #main.btREFRESH,"REFRESH",[btREFRESH], UL, 440, 17, 95, 25
statictext #main.statictext16, "SRAM (BYTES)", 35, 152, 120, 20
' statictext #main.statictext15, "EEPROM (BYTES)", 30, 177, 140, 20
textbox #main.ramF, 210, 152, 100, 25
' textbox #main.eepF, 210, 182, 100, 25
textbox #main.ramU, 325, 152, 100, 25
' textbox #main.eepU, 325, 182, 100, 25
textbox #main.ramP, 435, 152, 100, 25
' textbox #main.eepP, 435, 182, 100, 25
statictext #main.txtWORKING, "WORKING", 185, 17, 85, 20
statictext #main.txtFINISHED, "FINISHED", 185, 17, 75, 20
'-----End GUI objects code
open "LST VIEW" for window as #main
print #main.UsedWords, "!font ms_sans_serif 10 bold"
print #main, "font ms_sans_serif 10"
print #main.statictext3, "!font ms_sans_serif 10 bold"
print #main.statictext16, "!font ms_sans_serif 10 bold"
' print #main.statictext15, "!font ms_sans_serif 10 bold"
print #main.txtWORKING, "!font ms_sans_serif 10 bold"
print #main.txtFINISHED, "!font ms_sans_serif 10 bold"
print #main, "trapclose [quit.main]"
[main.inputLoop] 'wait here for input event
' print #handle.ext, "!hide"
print #main.txtWORKING, "!hide"
print #main.txtFINISHED, "!hide"
wait
[btOPEN] 'Perform action for the button named 'btOPEN'
filedialog "OPEN ","C:\*.lst", openfile$
if openfile$ = "" then wait
[rFresh]
open openfile$ for input as #Lfile
print #main.name, openfile$
print #main.txtWORKING, "!show"
[LOOPcn]
line input #Lfile, line$
if mid$(line$,29,9)= "RAM_START" then RS$ = mid$(line$,68,6)
if mid$(line$,29,7)= "RAM_END" then RE$ = mid$(line$,68,6)
if mid$(line$,69,11)= "RAM_START +" then RFIN$ = mid$(line$,81,6)
' if mid$(line$,29,9)= "RAM_START" then #main.ramF,mid$(line$,68,6)
' if mid$(line$,29,7)= "RAM_END" then #main.ramU,mid$(line$,68,6)
if mid$(line$,1,26)= "Program Memory Bytes Used:" then #main.UsedWords,mid$(line$,27,92)
if mid$(line$,1,26)= "Program Memory Words Used:" then #main.UsedWords,mid$(line$,27,92)
if mid$(line$,1,26)= "Program Memory Bytes Free:" then #main.FreeWord,mid$(line$,27,92)
if mid$(line$,1,26)= "Program Memory Words Free:" then #main.FreeWord,mid$(line$,27,92)
if mid$(line$,1,2)= "__" then #main.chip,mid$(line$,3,12)
if eof(#Lfile) = -1 then [closeFILE1]
goto [LOOPcn]
[closeFILE1]
close #Lfile
[LOOPpm]
if mid$(line$,1,26)= "Program Memory Bytes Used:" then #main.ByteWord,mid$(line$,16,5)
if mid$(line$,1,26)= "Program Memory Words Used:" then #main.ByteWord,mid$(line$,16,5)
if eof(#Lfile) = -1 then [closeFILE2]
goto [LOOPpm]
[closeFILE2]
close #Lfile
print #main.chip, "!contents? cName$"
bFile$ = "C:\PBP\";(trim$(cName$));".bas"
' print #main.eepP,bFile$
goto [closeFILE]
wait
[btREFRESH] 'Perform action for the button named 'btREFRESH'
if openfile$ = "" then [rfERROR]'notice "SELECT FILE"
goto [rFresh]
wait
[closeFILE]
' close #Lfile
print #main.UsedWords,"!contents? UW"
print #main.FreeWord,"!contents? FW"
TW = UW + FW
PW = (UW / TW) * 100
print #main.PercentWord,using("###.##",PW)
ramS = hexdec(RS$)
ramE = hexdec(RE$)
ramT = ramE - ramS + 1
ramF = hexdec(RFIN$)
ramU = ramF - ramS
ramFree = ramT - ramU
ramP = (ramU / ramT) * 100
print #main.ramF,ramFree
print #main.ramU,ramU
print #main.ramP,using("###.##",ramP)
print #main.txtFINISHED, "!show"
wait
[rfERROR]
goto [main.inputLoop]
wait
[quit.main] 'End the program
close #main
