Here is some code to determine tilt using at least a two axis accelerometer. It uses trig.inc
This does not do the a/d conversions, or pulse measurement conversions, that would have to be added.
here is the location of the trig.inc fileCode:define OSC 20 'code working with PIC-MT-USB include "TRIG.inc" main: define LED PortD.3 DEFINE LCD_DREG PORTD ; Set LCD Data port B C D DEFINE LCD_DBIT 4 ; Set starting Data bit (0 or 4) 4 0 DEFINE LCD_RSREG PORTD ; Set LCD Register Select port A A DEFINE LCD_RSBIT 0 ; Set LCD Register Select bit 3 2 DEFINE LCD_EREG PORTD ; Set LCD Enable port A A DEFINE LCD_EBIT 2 ; Set LCD Enable bit 1 5 DEFINE LCD_BITS 4 ; Set LCD bus size (4 or 8 bits) 4 4 DEFINE LCD_LINES 2 ; Set number of lines on LCD 2 2 define LCD_RWREG PORTD define LCD_RWBIT 1 ADCON1=15 TRISA=%00000011 ' Set PORTA 0-1-3 used for AD TRISB=%00000000 ' Set PortB TRISC=%00000000 TRISD=%00000100 ' Vdd 5 volts ' Vss Ground ' Vo 20K potentiometer (or ground) ' DB0-3 No connect a var word xresult var word 'result of accelerometer sensor in x axis yresult var word 'result of accelerometer sensor in y axis zresult var word 'result of accelerometer sensor in z axis correct var bit 'able to keep equation the same, and flip angle xdir var bit 'shows direction of x tilt ydir var bit 'shows direction of y tilt zdir var bit 'shows direction of z tilt Lcdout $fe, 1 ' Clear LCD screen Pause 500 ' Wait for LCD to startup toggle portD.3 xresult = 553 'is 41 away from center zresult = 297 'is 215 away from center 'to try it on your calculator tan^-1(41/215) = 10.796543 degrees 'xresult is acceleration allong the x axis if xresult > 512 then 'get difference from neutral to gravity reading xresult = xresult - 512 'since we are using 10 bit result, half is 512 xdir = 0 else 'accelerometer reads 512 with no gravity xresult = 512 - xresult 'and above or below depending on direction tilt xdir = 1 endif if yresult > 512 then 'yresult is acceleration allong the y axis yresult = yresult - 512 ydir = 0 else yresult = 512 - yresult ydir = 1 endif if zresult > 512 then 'zresult is acceleration allong the z axis zresult = zresult - 512 zdir = 0 else zresult = 512 - zresult zdir = 1 endif if xresult < zresult then 'if x/z is < 1 then x/z xresult = xresult * 30000 'we will have to correct angle if this is case y = div32 zresult correct = 0 else zresult = zresult * 30000 'else z/x to keep our equation within limits y = div32 xresult correct = 1 endif x = 30000 'multiply this by same value 30000 as above call atan2 if correct = 0 then y = 9000 - y '90.00 degrees - y = corrected angle lcdout $FE,1,#y/100,".",#y//100," degrees" 'y = angle 1080 = 10.80 degrees lcdout $FE,$C0,"x=",#xdir," y=",#ydir," z=",#zdir end
http://www.picbasic.co.uk/forum/atta...4&d=1234739854
