Why (or how to) make a port array for OW
Results 1 to 9 of 9
    The supplied code is NOT working unless i un-rem the Tris statement.
    Then un-rem the TRIS statement.
    Port pins are inputs at power-up since TRIS regs are all 1's. If you're using HIGH & LOW commands for port pin control, it clears TRIS bits for you. With PORTx = ? it doesn't. You need to clear TRIS bits for whatever pin you want to be an output.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2009
    Stockholm / Moscow
    Tnx for reply Bruce !
    I'v tried what You just said, but no success.
    the leds dont light up when i change it to "high portc.0[portnr]" instead of "portc.0 = 1"
    With or without a Tris statement.
    The 18B20 code is Yours from start (part 3 Ds1820&4 lines LCD) and what im try to do is a loop where i adress the port so i dont need 8 identical read parts.
    I have it working direct adressing on the read parts and then a common calculate part but it's not a effective coding i guess and im curius why it does'nt work.
    This work:
    Start_Convert:
    OWOUT porta.0, 1, [$CC, $44]' Skip ROM search & do temp conversion
    This does not:
    for portnr = 0 to 7
    Start_Convert:
    OWOUT porta.0[portnr], 1, [$CC, $44]' Skip ROM search & do temp conversion
    ( I can read the portnr on the LCD but not light leds or OW commands)
    Brgds Roy
    Hi Roy,
    Unfortunately, not all commands work with a variable index pointer to the port pin.
    For bit-twiddling - you can do something like this;
    Index VAR BYTE
    TRISC = 0
      FOR Index = 0 TO 7
          PORTC.0[Index] = 1
          PAUSE 100
          PORTC.0[Index] = 0
          PAUSE 100
      NEXT
      GOTO Main
    If you search here for port & pin indexing you'll find a TON of various ways to index pins.
    Here's one http://www.picbasic.co.uk/forum/showthread.php?t=3753
    And here's another that gets really interesting when Darrel steps in with his VirtualPort thing-a-ma-bob.
    http://www.picbasic.co.uk/forum/showthread.php?t=4074
    P.S. Welcome to the forum....;o}
    -Bruce
    tech at rentron.com
    Feb 2009
    Stockholm / Moscow
    Thanks Bruce !
    I'v tested your example and it works like a charm.
    But when I change it to Low and High instead of =1 it doesent work, neither
    does Toggle so its proven that it is as you said that it NOT given that diffrent statements really will work with port-pin arrays.
    Is it any list of what commands that is inoperative together ?
    It's a pity that its features (bugs?) like this so we all need to try out before we know if its working and then try workarounds to get the wanted result.
    Ok the whole thing with pics and basic is nice that its really IS possible in such a simple way to get such things running / results.
    It's very interesting to read the forum and see how you gurus tweak and find solutions to all the undocumented possibilities in PbP.
    Brgds Roy
    Hi Roy,
    Commands that require a pin # already know the pin is asociated with a port.
    So you just need to include the pin# for the command to use.
    From the manual for the HIGH command;
    Pin may be a constant, 0-15, or a variable that contains a number 0-15 (e.g.B0) or a pin
    name (e.g. PORTA.0).
    So you can still do what you want, but not with variable bit indexing.
    Just use the actual pin # in your loops Index variable.
    Index VAR BYTE
      FOR Index = 0 TO 15 ' PORTB.0 to PORTB.7 = 0-7. PORTC.0 to PORTC.7 = 8-15
          TOGGLE Index
          PAUSEUS 100
          TOGGLE Index
          PAUSEUS 100
      NEXT
      GOTO Main
    This same approach should work with any PBP command with a pin# in the argument list.
    If you're using all of PORTC on the 877A for OWOUT, then your loop Index variable would
    be from 8 to 15.
    On a different PIC, this may change since there may only be PORTA and PORTB. Look in the
    16F877A.BAS file for how the port pins are listed like this;
    PORTL VAR PORTB ' <-- 0-7
    PORTH VAR PORTC ' <-- 8-15
    In 16F84A.BAS
    PORTH VAR PORTA ' <-- 8-12
    Now the same code example above would operate a bit different. Starting on PORTB, and
    finishing on PORTA, with 0 TO 12 as the loop Index count.
    -Bruce
    tech at rentron.com
    Feb 2009
    Stockholm / Moscow
    Thanks Bruce !
    That was informative and explaind to me why i did'nt get it working the way i tried.
    I will now rewrite my working code and see how much smaller it will be by doing it by loops instead of repeatative sections.
    I had a feeling of that pins was a historic basicstamp commands that was inefffective compared to Portb.x and needed to have include files.
    Brgds Roy
    Feb 2009
    Stockholm / Moscow
    I'v tested it now with one loop instaed of multiple lines of almost identical code and it now half the size.
    Success !
    Tnx Bruce !
    Brgds Roy
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
    Last Post: - 14th November 2008, 18:25
  3. array and port
    By piombazzo in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 21:58
  5. pins in arrays?
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 17th September 2005, 09:18
