Approprite baud
Results 1 to 4 of 4
Thread: Approprite baud
    Feb 2009
    Post Approprite baud
    I'm using serial comms to transmit data from a PIC16F84A to PIC16F877A.
    F84A uses SEROUT and 877A uses Hardware USART, HSERIN. Both processors run @ 4 MHz with an XTAL oscillator. There is a distance of about 1.2 meters between the processors.
    What would be an approprite baud for serial comms between these two peocessors? And could someone possibly give an example of what such PBP code might look like.
    Essentially the F84A scans a keypad, stores the key pressed in a byte variable and sends this value to the F877A, the F877A then recieves this, stores the value in its own byte variable and acts on it accordingly.
    I have managed to get this working, but I am seeing different values on my LCD (attached to the F877A) as to what were sent serially by the F84A. FOr example, sending a "1" would display a "10" and sending a "2" would display a "40" but sometimes this would change to a "60".
    As a fairly novice user I assume I am missing something obveous, so I thought I would ask the experts for some advise.
    Thank you in advance.
    My F84A code is as follows:
    INCLUDE "modedefs.bas"
    ' Declare Variables...
    Col1      VAR PORTA.0
    Col2      VAR PORTA.1
    Col3      VAR PORTA.2
    Row1      VAR PORTB.4
    Row2      VAR PORTB.5
    Row3      VAR PORTB.6
    Row4      VAR PORTB.7
    LED       var PORTB.1
    SERTX     var PORTB.2
    SERoK     var PORTB.3
    Key       var byte
    ' Setup Ports (I know theres an easier way with the TRIS registers, but this makes it easier to understand)
    input row1 : input row2 : input row3 : input row4
    output col1 : output col2 : output col3 : output SERTX
    ' Setup Var
    key  = 20                               ' Initialize "Key" var with "20".
    ' Program Start
    Boot:                                   ' Do the whole unnessesary light show
        high led
        low led
        high led
        low led
        pause 2000
        high serok                        ' Tell the F877A you ready to be useful (finally).
        goto main                         ' Start the important stuff.
        gosub ScanKeys                    ' Scan the keypad.
        if key <> 20 then gosub transmit  ' If Key var is NOT = 20, transmit the value.
        goto main                         ' Repeat the process.
    ScanKeys:
        high col1                         ' Make Col1 logic 1 for checking.
        pause 50                          ' Debounce.
            if row1 = 1 then Key = 1      ' Check for logic 1 on the rows, if found, thats ur numba!
            if row2 = 1 then Key = 4
            if row3 = 1 then Key = 7
            if row4 = 1 then Key = 10
        low col1
        high col2                         ' Same thing for Col2 if nothing is found on Col1.
        pause 50
            if row1 = 1 then Key = 2
            if row2 = 1 then Key = 5
            if row3 = 1 then Key = 8
            if row4 = 1 then Key = 0
        low col2
        high col3
        pause 50
            if row1 = 1 then Key = 3     ' And again for Col3.
            if row2 = 1 then Key = 6
            if row3 = 1 then Key = 9
            if row4 = 1 then Key = 11
        low col3
        return                           ' Go back to main routine.
    Transmit:
        gosub flash                      ' Do another quick unessesary light show
        serout sertx,T2400,[key]         ' Send the "Key" value to the F877A
        pause 50                         ' Dont rush!
        key = 20                         ' Reset the "Key" var.
        low led                          ' Stop the light show.
    Flash:
        high led                         ' The other unessesary light show.
        pause 50
        low led
        pause 50
        high led
        pause 50
    My F877A code is as follows:
    Define    LCD_DREG     PORTA
    Define    LCD_DBIT     0
    Define    LCD_RSREG    PORTA
    Define    LCD_RSBIT    4
    Define    LCD_EREG     PORTA
    Define    LCD_EBIT     5
    DEFINE    LCD_LINES    4
    ' Define HSER Registers
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    ' Set baud rate
    DEFINE HSER_BAUD 2400
    'Define Aliases
    RHF       var          PORTB.0
    RHB       VAR          PORTB.1
    LHF       VAR          PORTB.2
    LHB       VAR          PORTB.3
    LineCom   var          PORTB.4
    LEDS      var          PORTB.5
    SERoK     var          PORTB.7
    SERRX     var          PORTB.6
    'Define Vars
    Dat       var          byte
    ADCON1 = 7
    'Begin program
    Boot:
        dat = 20        ' Initialize Dat var with "20".
        Pause 500       ' Wait for LCD to startup.
        gosub display   ' Go to Display subroutine.
        low leds        ' Turn on the decor!
        repeat
            Lcdout $FE, $C0, "!! Insert Ctrl !!" ' Ask user to plug in F84A Keypad
            Lcdout $FE, $94, "Waiting..."
            Lcdout $FE, $D4, "Dat = ",#Dat       ' Display value of Dat variable.
            pause 100                            ' Dont rush.
        until serok = 1                          ' Wait until F84A is connected and ready.
        goto modeselect                          ' Get user's commands.
    ModeSelect:
        Lcdout $FE, $C0, "!! Select Mode !!"     ' Inform the user to select mode with kaypad.
        HSERIN 5000,Modeselect,[str Dat\1]       ' Recieve keypad value serially from F84A.
    Discon:
        repeat
            Lcdout $FE, $94, "Pls Discon..."     ' Once value is recieved, ask user to disconnect F84A.
        until serok = 0                          ' Wait until F84A is disconnected.
        goto gomode                              ' Find out what to do with the value recieved.
    GoMode:
        if dat <> 20 then                        ' If Dat id NOT = 20 then find the mode.
        select case dat
            case 1                               ' Should Dat = 1,
                goto linefollow                  ' Go to LineFollow Routine.
        end select
    goto boot                                    ' Otherwise, if nothing chnaged, start the process again.
    Display:
       Lcdout $fe, 1   ' Clear LCD screen
       Lcdout "PIC-Bot... v1.0"
       Lcdout $FE, $94, "Pls Wait..."
       Pause  1000
    'Check for controler
    ChkCtrl:
    if serok = 1 then modeselect                ' Here we check is the F84A has been connected (used in Mode routines).
    include "LineFollow.bas"                    ' Include the Line Follow mode routine.
    There's no real such thing as Best Baudrate, but you need to consider the limitation of a software based Serial communication against Hardware.
    If it was me, I would never have use Grandpa 16F84, let him alone on the shelf, he's retired anyways why Microchip still produce them anyways ... apart for money income & 100% compatible effortless drop-in replacement???
    However, in case you MUST deal with it for some museum (or available parts) reason, I would suggest you to forget SEROUT but use DEBUG instead. Compare both, DEBUG will work on higher speed than SEROUT on slow speed crystal such as 4 MHz.
    Using a built-in USART allow you to have at least interrupt... Way to go in most case as your software can do intelligent stuff in meantime.. what's the big deal to sit there and wait for something anyways
    If you look at the PIC datasheet (or use my PICmultiCalc), you'll discover that your PIC running @4MHz may provide a still efficient 250K baud... BUT this will not work in your case, using 19,200 (see the comma Darrel?) baud and still be efficient on both part... considering you're using USART interrupt on the receiver end.
    Feb 2009
    Now that you mention it, I think I do have a PIC16F627A floating around, perhaps it would be wise to use that instead of the F84A.
    The reason I still use the F84 is because I have lots of them, unfortunatly in South Africa I pay x14 what one would pay for a PIC chip in the UK, so as a hobby project it becomes pricy, lol.
    Anyway, I've found that F627A and i'm going to use it in my keypad along with its own hardware serial port, but I doubt it will solve the problem where the values displayed on the LCD don't correspond with the values which are supposed to be sent by the keypad (and which sometimes randomly change too, lol). And ideas on that one? I've commented my rather unorthadox code to make some sence of my mess, hehe.
    Thanks in advance.
    Quote Originally Posted by dgcarter View Post
    The reason I still use the F84 is because I have lots of them, unfortunately in South Africa I pay x14 what one would pay for a PIC chip in the UK, so as a hobby project it becomes pricy, lol.
    Damn . . what are they, Illegal there? Do you get them from a shadowy figure in a back alley?
    Thanks in advance.
    Check these 2 posts. the first one may have your solution, if not go to post 16 of the second post where there is a nice example featuring a ring buffer.
    http://www.picbasic.co.uk/forum/showthread.php?p=50654
    http://www.picbasic.co.uk/forum/showthread.php?t=4972
    Last Post: - 8th March 2010, 21:58
  2. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 01:39
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 23:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
