Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
Attachment 8321
as close as I can get . it has a glitch after the last bit sent
'* Name : MODULATOR.BAS *
'* Notice : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 5/29/2016 *
'* Version : 1.0 *
'* Notes : *
'* : 16F1825 *
__config _CONFIG1, _FOSC_INTOSC & _CP_OFF & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CLKOUTEN_OFF
__config _CONFIG2, _PLLEN_OFF & _LVP_OFF
OSCCON=$70
DEFINE OSC 8
' PIC 16F1825
TRISA = %011111 '
trisc = %001111 ;
ANSELA=0
ANSELC=0
MDSRC= %00000000
MDCARH =%01000100
MDCARL =%00000000
X VAR byte
darta VAR byte[4]
TIMER1 VAR WORD EXT
clear
modout var latc.4
darta.0[14]=1
darta.0[15]=1
t2con=6
pr2=158
CCPR1L =318>>2
ccp1con=12
MDCON.0 = 0
modout =1
Main_Loop:
lata.5=1 ; cro trigger
while !pir1.1 :wend
modout=0
pauseus 9900
modout =1
pir1.1=0
while !pir1.1 :wend
pir1.1=0
while !pir1.1 :wend
MDCON= %11000001
pir1.1=0
while !pir1.1 :wend
for x = 0 to 31
if darta.0[x] then
MDCON.0 = 0
pir1.1=0
while !pir1.1 :wend
pir1.1=0
while !pir1.1 :wend
MDCON.0 = 1
pir1.1=0
while !pir1.1 :wend
MDCON.0 = 1
pir1.1=0
while !pir1.1 :wend
next
modout = 1
MDCON = 0
lata.5=0
PAUSE 200
goto Main_Loop
Thanks!
I guess, your code can run on 16F1829 ?
should do they are the same except for a few extra pins
well the dsp module is interesting but for this project perhaps its easier to do it the old way
'* Version : 1.0 *
'* Notes : *
'* : 16F1825 *
__config _CONFIG2, _PLLEN_ON & _LVP_OFF
OSCCON=$70
DEFINE OSC 32
' PIC 16F1825
TRISA = %001111 ' Make some pins Input
trisc = %001111 ;Make some pins Input
ANSELA=0
ANSELC=0
X VAR byte
darta VAR byte[4]
clear
modout var latc.4
darta.0[14]=1
darta.0[15]=1
modout =1
lata.5=0 ;cro triger
Main_Loop:
lata.5=1
modout=0
pauseus 9900
modout =1
pauseus 1880
for x = 0 to 30
modout =0
if darta.0[x] then
pauseus 2000
pauseus 780
modout =1
pauseus 635
next
modout =1
lata.5=0
PAUSE 200
goto Main_Loop
Did you try code I posted a month ago, or looked at it to determine it won’t work?
It’s used in an IR remote receiver for a game controller (so has to be reliable)
to interpret exactly the same pulse coded signal, with the timings being the only difference.
No, I haven't used it, because protocol is different from IR protocol.
Just tried Henrik's code, it gives error on:
LSB VAR BitArray.LowWord
"bad variable size modifier .lowword"
Corrected the errors, to level of my knowledge. Code compiles now, but it does not do anything. Here it is:
;----[16F1829 Hardware Configuration]-------------------------------------------
#IF __PROCESSOR__ = "16LF1829"
#DEFINE MCU_FOUND 1
cfg1 = _FOSC_INTOSC ; INTOSC oscillator: I/O function on CLKIN pin
cfg1&= _WDTE_OFF ; WDT disabled
cfg1&= _PWRTE_OFF ; PWRT disabled
cfg1&= _MCLRE_OFF ; MCLR/VPP pin function is digital input
cfg1&= _CP_OFF ; Program memory code protection is disabled
cfg1&= _CPD_OFF ; Data memory code protection is disabled
cfg1&= _BOREN_OFF ; Brown-out Reset disabled
cfg1&= _CLKOUTEN_OFF ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
cfg1&= _IESO_ON ; Internal/External Switchover mode is enabled
cfg1&= _FCMEN_OFF ; Fail-Safe Clock Monitor is disabled
__CONFIG _CONFIG1, cfg1
cfg2 = _WRT_OFF ; Write protection off
cfg2&= _PLLEN_OFF ; 4x PLL disabled
cfg2&= _STVREN_ON ; Stack Overflow or Underflow will cause a Reset
cfg2&= _BORV_19 ; Brown-out Reset Voltage (Vbor), low trip point selected.
cfg2&= _LVP_OFF ; High-voltage on MCLR/VPP must be used for programming
__CONFIG _CONFIG2, cfg2
#ENDIF
;----[Verify Configs have been specified for Selected Processor]----------------
; Note: Only include this routine once, after all #CONFIG blocks
#IFNDEF MCU_FOUND
#ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
#ENDIF
DEFINE OSC 16
include "modedefs.bas"
ANSELA = %00000000 ' Set PORTA pins to digital I/O
ANSELB = %00000000 ' Set PORTB pins to digital I/O
ANSELC = %00000000 ' Set PORTC pins to digital I/O
WPUB = %00000000 'DISABLE WEAK PULL UP
TRISB=%11110000 'SET PORTB TO OUTPUT
TRISA=%00000000 'SET PORTA TO OUTPUT
TRISC=%00000000 'SET PORTC TO OUTPUT
OSCCON = %01111111 'SET INTOSC TO 16MHZ
' Set LCD Data port
DEFINE LCD_DREG PORTC
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTA
' Set LCD Register Select bit
DEFINE LCD_RSBIT 5
' Set LCD Enable port
DEFINE LCD_EREG PORTA
' Set LCD Enable bit
DEFINE LCD_EBIT 4
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
' Set command delay time in us
DEFINE LCD_COMMANDUS 1500
' Set data delay time in us
DEFINE LCD_DATAUS 44
LCDOUT $FE, $C0, "TEST"
HighTime VAR WORD
LowTime VAR WORD
BitArray VAR WORD [2]
LSB VAR BitArray.lowbyte
MSB VAR BitArray.Highbyte
Signal var PORTB.6
i var word
WaitForStartBit:
GOSUB MeasureLow
IF (LowTime < 9500) OR (LowTime > 10500) THEN WaitForStartBit ' 9.5-10.5ms qualifies
GOSUB MeasureHigh
IF (HighTime < 1500) OR (HighTime > 2500) THEN WaitForStartBit ' 1.5-2.5ms qualifies
NextLevel:
For i = 0 to 31
GOSUB MeasureLow
IF (LowTime > 400) AND (LowTime < 800) THEN BitArray.0[i] = 1 ' 500-700us qualifies as 1
IF (LowTime > 1700) AND (LowTime < 2320) THEN BitArray.0[i] = 0 ' 1800-2200us qualifies as 0
NEXT
LCDOUT $FE,$01, "HighWord", DEC MSB
LCDOUT $FE,$C0, "LowWord", DEC LSB
Pause 1000
Goto WaitForStartBit
MeasureLow:
LowTime = 0
While Signal = 1 : WEND ' Wait for low level
While Signal = 0 ' Measure low level
LowTime = LowTime + 100 ' Resolution is 100us, change if needed
PauseUS 92 ' Tweak to calibrate, depends on actual loop time
WEND
MeasureHigh:
HighTime = 0
While Signal = 0 : WEND ' Wait for low
While Signal = 1 ' Measure high level
HighTime = HighTime + 1 ' Resolution is 100us, change if needed
PauseUS 92 ' Tweal to calibrate, depends on actual loop time
WEND
Modified measurelow subroutine, to show the value of LowTime:
MeasureLow:
LowTime = 0
WEND
LCDOUT $FE, $C0, "T:",DEC lowtime, " "
It returns 600.
This is quite strange, because I'm using 16F1829, running at 16mhz. DEFINE OSC is correct, I've launched series of pulses with 1ms duration, and checked by scope - all correct.
Modified HighTime routine too:
MeasureHigh:
HighTime = 0
WEND
LCDOUT $FE,$c0, "T2:",DEC hightime, " "
it returns 9.
Feels like MCU is operating very slow?
what are you expecting to see ?
how many times do you think 100uS will divide into a shade less than 1mS ?
Where it should returned something like 9000, it returns 600, is not this strange?
the code is expecting 10 mS pulse
I goofed there. Since the BitArray actually consists of two WORDs and you want the least and most significant WORD of that array the declaration should read
LSB VAR BitArray[0]
MSB VAR BitArray[1]
What should return 9000?
You've changed the MeasureHigh routine so it only adds 1 each time thru a loop that (ideally) takes 100us to execute. A pulse lasting for 10ms will (ideally) cause that loop to execute 100 times, you end up with 100 in (instead of 10000) in HighTime.
I modified henriks code an tested it with my simulation , works fine
'* Name : deMODULATOR.BAS *
'* Author : richard's modified version of henriks *
'* Notice : 2016 *
'* Date : 10/10/2016 *
'* Version : 1.0 *
'* Notes : decodes missing pulse encoded data stream A.5 *
'* : 16F1825 *
OSCCON=$70
DEFINE OSC 32
' PIC 16F1825
TRISA = %111110 ' Make somepins Input
trisc = %111100 ;Make some pins Input
ANSELA=0
ANSELC=0
led var latc.0 ;DEBUG
led2 var latc.1 ;DEBUG
demod var porta.5 ;demod in
X VAR byte
darta VAR byte[4]
counter var word
dm_state VAR byte
lata.0=1 ;DEBUG
clear
led=0
DEFINE DEBUG_REG PORTA
DEFINE DEBUG_BIT 0
DEFINE DEBUG_BAUD 9600
DEFINE DEBUG_MODE 0
pause 2000
Debug "Start",13 ,10
DEFINE PULSIN_MAX 9000
HighTime VAR WORD
LowTime VAR WORD
WaitForStartBit:
GOSUB MeasureLow
IF (LowTime < 9500) OR (LowTime > 11000) THEN WaitForStartBit ' 9.5-10.5ms qualifies
led2=1
GOSUB MeasureHigh
led2=0
NextLevel:
For x = 0 to 31
GOSUB MeasureLow
IF LowTime < 1000 then
darta .0[x] = 0
darta .0[x] = 1
NEXT
led=1
Debug 13 ,10 ,bin8 darta[3],bin8 darta[2],bin8 darta[1],bin8 darta[0] ;DEBUG
Pause 1000
led=0
MeasureLow:
LowTime = 0
While demod = 1 : WEND ' Wait for low level
While demod = 0 ' Measure low level
WEND
MeasureHigh:
HighTime = 0
While demod = 0 : WEND ' Wait for low
While demod = 1 ' Measure high level
HighTime = HighTime + 100 ' Resolution is 100us, change if needed
WEND
for comparison I came up with this , oddly it uses mode code space
'* Author : richard *
'* Notice : Copyright (c) 2016 *
'* Version : 1.0 *
'* : 16F1825 *
OSCCON=$70
DEFINE OSC 32
' PIC 16F1825
ANSELA=0
ANSELC=0
X VAR byte
darta VAR byte[4]
counter var word
dm_state VAR byte
lata.0=1 ;DEBUG
clear
led=0
DEFINE DEBUG_BIT 0
DEFINE DEBUG_MODE 0
pause 2000
select case dm_state
case 0
PULSIN demod, 0, counter
if counter > 7800 then
dm_state=1
x=0
case 1
pir1.1=0
tmr2=0
t2con=7
while demod : wend
if pir1.1 | (tmr2 < 220) then
dm_state=0
dm_state=2
tmr2=0
case 2
while !demod : wend
t2con=0
if pir1.1 then
dm_state=0
led=1
if tmr2 < 150 then
darta.0[x]=0
darta.0[x]=1
tmr2=0
x=x+1
if x >31 then
dm_state=3
while demod : wend
t2con=7
case 3
led2=1 ;DEBUG
' Debug 13 ,10 ,hex2 darta[3] ,hex2 darta[2],hex2 darta[1],hex2 darta[0] ;DEBUG
pause 200
led2=0 ;DEBUG
dm_state=0
end select
the 1ms was just test, I used it to check MCU speed, whenever OSCCON and DEFINE OSC were correct, later it was removed.
I have Henrik's code running, I connect it to actual hardware, and width of large pulse, which should be 9000us, measured only 600 ?
I've copied all code from post #35, including timings.
http://www.picbasic.co.uk/forum/show...165#post138165
then you are doing something wrong ,plus you said in previous posts the pulse was 9900uS it makes a difference . whats correct ?
your looking more scatterlogical than my exwife
haha, no, I'm not blond :)
Just I'm multi-tasking very hard.
9000, 9900, it was just typo, exact timings are given on the previous page. I don't know what I'm doing wrong, since code is Henrik's. As I said, I verified MCU speed and OSC settings, and they are all correct. Pulse timings are also correct, verified using two different scopes. this is only what I can do.
