Re: I2C lcd ( arduino ) with PICBASIC, help
Hi Steve,
I am back again on this LCD ...
I have repaired the programmer and so I had the occasion to test the program.
> Back light does not come on at all .
> nothing is displayed on the LCD
If you have something more to suggest, I am ready to go on .
Ambrogio
iw2fvo
Hi Steve,
Ambrogio
Not good news then!
I need to refresh my memory. Post the full code you are using please.
here it is:
DEFINE OSC 40 ' 10 MHz XTAL AND X 4 INTERNAL PLL
DEFINE I2C_SLOW 1
SDA VAR PORTD.2 ; I2C Data pin
SCL VAR PORTD.3 ; I2C Clock Pin
LCD_Addr CON 78
'LCD_BuffSize CON 30
'LCD_Buff VAR BYTE[LCD_BuffSize]
'LCD_BuffAddr CON EXT : @LCD_BuffAddr = _LCD_Buff
'LCD_BuffLen VAR WORD ; Length of data in buffer
LCD_Data VAR BYTE ; Data to Send to LCD
LCD_Byte VAR BYTE ; Nibbles to Send
LCD_RS VAR LCD_Byte.0 ; Register Select bit
LCD_RW VAR LCD_Byte.1 ; Read/Write bit
LCD_E VAR LCD_Byte.2 ; Enable bit
LCD_BackLight VAR LCD_Byte.3 ; Backlight 0=ON
LCD_WriteMode VAR BYTE ; 1=LowNibble, 2=HighNibble, 3=Both
LCD_CommandMode VAR BIT ; Indicates next byte is a command
LCD_Byte2 VAR BYTE ; Same nibble without E bit
LCD_Idx VAR BYTE
testmode var byte
;----[Initialize the LCD]-------------------------------------------------------
PAUSE 250 ; LCD Power-on delay
LCD_Backlight = 1 ; Backlight OFF
LCD_RW = 0 ; Write to LCD
LCD_RS = 0 ; Command Register
LCD_WriteMode = 1 ;-- Low Nibbles only
LCD_Data = 3 ; Reset 3 times
gosub LCD_Write_
PAUSEUS 6000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
LCD_Data = 2 ; Start 4-bit mode
gosub LCD_Write_
PAUSEUS 1000
LCD_WriteMode = 3 ;-- Both Nibbles
LCD_Data = $28
gosub LCD_Write_ ; Function Set, 4-bit, 2-line, 5x7
LCD_Data = $0C
gosub LCD_Write_ ; Display ON
LCD_Data = $01
gosub LCD_Write_ ; Clear Screen
PAUSE 2
LCD_Data = $06
gosub LCD_Write_ ; Entry Mode
PAUSE 2 ; Let command finish
LCD_RS = 1 ' this is data
LCD_WRITE_:
LCD_E = 1
IF LCD_WriteMode.1 = 1 THEN ; Write High Nibble
LCD_Byte = (LCD_Byte & $0F) | (LCD_Data & $F0)
LCD_Byte2 = LCD_Byte & $FB
I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
IF LCD_WriteMode.0 = 1 THEN ; Write Low Nibble
LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
LCD_Data = "T"
gosub LCD_Write_
LCD_Data = "e"
gosub LCD_Write_
LCD_Data = "s"
gosub LCD_Write_
LCD_Data = "t"
gosub LCD_Write_
Please use code tags as it is easier for me to read.
iw2fvo
here it is:
DEFINE I2C_SLOW 1
LCD_Addr CON 78
LCD_Idx VAR BYTE
testmode var byte
gosub LCD_Write_
PAUSEUS 6000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
LCD_Data = $28
LCD_Data = $0C
LCD_Data = $01
PAUSE 2
LCD_Data = $06
LCD_WRITE_:
LCD_E = 1
LCD_Data = "T"
gosub LCD_Write_
LCD_Data = "e"
gosub LCD_Write_
LCD_Data = "s"
gosub LCD_Write_
LCD_Data = "t"
gosub LCD_Write_
Need to add pauseus!
LCD_Data = "T"
gosub LCD_Write_: PAUSEUS 50
LCD_Data = "e"
LCD_Data = "s"
LCD_Data = "t"
And to test backlight is working try
LCD_Backlight = 0
LCD_Data = "T"
LCD_Data = "e"
LCD_Data = "s"
LCD_Data = "t"
LCD_Backlight = 1
LCD_Data = "-"
Steve,
I uploaded the two codes you have sent to me and checked them one at the time :
> backlight is still not working
> lcd show nothing
Ambrogio
Is the address correct? It is 78 in the code.
Try your code from post #24 as this did control the backlight.
Steve,
this code still works well:
Thanks ,Ambrogio
DEFINE I2C_SLOW 1
C VAR portd.3 ' S_CLOCK
D VAR portd.2 ' S_DATA
ADDR VAR BYTE
ADDR = %01001110 ' dec 78 , hex 4E
CMD VAR BYTE
LCD_CMD VAR BYTE
E VAR LCD_CMD.BIT2
RS VAR LCD_CMD.BIT0
E=0:RS=0
LCD_CMD = 0
PAUSE 1000
MAIN:
I2CWRITE D, C, ADDR, [%00000000] ' bck_lt= off
PAUSE 200
I2CWRITE D, C, ADDR, [%00001000] ' bck_lt=on
PAUSE 200
GOTO MAIN
iw2fvo
Steve,
Thanks ,Ambrogio
DEFINE I2C_SLOW 1
ADDR VAR BYTE
CMD VAR BYTE
LCD_CMD VAR BYTE
E VAR LCD_CMD.BIT2
RS VAR LCD_CMD.BIT0
E=0:RS=0
LCD_CMD = 0
PAUSE 1000
MAIN:
PAUSE 200
PAUSE 200
GOTO MAIN
This works because you can see the backlight turn on and off. This tells me the LCD is working and the address is correct. Unfortunately that has eliminated the obvious. I will dig deeper into Darrel's code as I can not see anything that would stop it working.
EarlyBird2
I have studied the HD44780 and PCF8574 datasheets and compared them to Darell's code and found as expected that his code follows the datasheets precisely. I compared the code
DEFINE I2C_SLOW 1
ADDR VAR BYTE
CMD VAR BYTE
LCD_CMD VAR BYTE
E VAR LCD_CMD.BIT2
RS VAR LCD_CMD.BIT0
E=0:RS=0
LCD_CMD = 0
PAUSE 1000
MAIN:
PAUSE 200
PAUSE 200
GOTO MAIN
with Darrel's and noticed the I2C_SLOW definition is not included in his code. I then looked at I2CWRITE in the manual and noticed that PAUSE 10 is used to allow time for the transfer to complete again this is not included in Darrel's code.
What does this indicate is the question?
I compared PBP2.5 and pbp3 manuals and the I2CWRITE instruction is the same. I wondered if the pause in PBP3 is not needed as the compiler takes care of the I2C being busy.
One step at a time.
First remove the I2C_SLOW and test
'DEFINE I2C_SLOW 1
LCD_Addr CON 78
LCD_Idx VAR BYTE
testmode var byte
gosub LCD_Write_
PAUSEUS 6000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
LCD_Data = $28
LCD_Data = $0C
LCD_Data = $01
PAUSE 2
LCD_Data = $06
LCD_WRITE_:
LCD_E = 1
LCD_Backlight = 0
LCD_Data = "T"
LCD_Data = "e"
LCD_Data = "s"
LCD_Data = "t"
LCD_Backlight = 1
LCD_Data = "-"
Then add pause 10 delays
'DEFINE I2C_SLOW 1
LCD_Addr CON 78
LCD_Idx VAR BYTE
testmode var byte
gosub LCD_Write_
PAUSEUS 6000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
LCD_Data = $28
LCD_Data = $0C
LCD_Data = $01
PAUSE 2
LCD_Data = $06
LCD_WRITE_:
LCD_E = 1
I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte]
PAUSE 10
I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte2]
PAUSE 10
PAUSE 10
PAUSE 10
LCD_Backlight = 0
LCD_Data = "T"
LCD_Data = "e"
LCD_Data = "s"
LCD_Data = "t"
LCD_Backlight = 1
LCD_Data = "-"
and let me know the outcome.
I will continue looking for answers.
Hi Steve,
no change using both codes.
I still have no backlight and no text.
I appreciate your assistance on this matter: thanks a lot.
I am not skilled enough to go deeper in those kind of codes ...
Ambrogio
Can I make one suggestion?
First connect few led on output of PCF8574, and control them. So you are sure that I2C communication woks.
Second connect LCD to PIC directly, get timing and control right.
Then just combine that two.
Try again
DEFINE I2C_SLOW 1
LCD_Addr CON 78
LCD_Idx VAR BYTE
testmode var byte
PAUSE 1000 ; LCD Power-on delay
gosub LCD_Write
PAUSEUS 6000
gosub LCD_Write
PAUSEUS 1000
gosub LCD_Write
PAUSEUS 1000
gosub LCD_Write
PAUSEUS 1000
LCD_Data = $28
gosub LCD_Write ; Function Set, 4-bit, 2-line, 5x7
LCD_Data = $0C
gosub LCD_Write ; Display ON
LCD_Data = $01
gosub LCD_Write ; Clear Screen
PAUSE 2
LCD_Data = $06
gosub LCD_Write ; Entry Mode
LCD_WRITE:
LCD_E = 1
I2CWRITE SDA,SCL, LCD_Addr, [%00000000] ' bck_lt= off
PAUSE 200
I2CWRITE SDA,SCL, LCD_Addr, [%00001000] ' bck_lt=on
PAUSE 200
LCD_Data = "T"
gosub LCD_Write: PAUSEUS 50
LCD_Data = "e"
LCD_Data = "s"
LCD_Data = "t"
LCD_Data = "-"
goto Main
The problem could be with the delay on power up not being long enough for the LCD to initialise before the PIC starts.
Adjust this line and test
and please let me know the result.
Dear Steve:
Your suggested test gave me the response on the lack of operation. ( see the attached).
The pcf has P0, P5 and P6 not working. This is the reason of the trouble.
I will no longer buy components on Ebay expecially if chinese. That is very bad.
I have no words to express my state. I want to apologize .
Thanks for the help given to me since the beginning.
Will try to buy another expander board: do you know some reliable seller in Europe ?
Ambrogio
iw2fvo
Dear Steve:
Ambrogio
No problem and no need to apologise. Could you do some more testing on this board?
Check the voltages on the P0 to P7 pins when this program is running.
DEFINE I2C_SLOW 1
ADDR VAR BYTE
CMD VAR BYTE
LCD_CMD VAR BYTE
E VAR LCD_CMD.BIT2
RS VAR LCD_CMD.BIT0
E=0:RS=0
LCD_CMD = 0
PAUSE 1000
MAIN:
I2CWRITE D, C, ADDR, [%00000000] ' port off
PAUSE 200
I2CWRITE D, C, ADDR, [%11111111] ' port on
PAUSE 200
GOTO MAIN
If all pins change then the PCF8574 chip is good indicating that the fault is either bad soldering or bad PCB track. It is possible to solder jumper wire direct to pins for a temporary repair.
are you sure the new board has 8574t on it not a 8574A ?
that might make a world of difference
=richard;127791]are you sure the new board has 8574t on it not a 8574A ?
It is definitely a 8574T as shown in #36 and copied below.
http://www.picbasic.co.uk/forum/atta...1&d=1404048736[
2 Attachment(s)
is that the current device or the one that got zapped ?
I found a 8574a in my junk box and fed your code into it (no lcd) and it seems ok (address is $78 for a version)
the attached pcf8574a.txt file is really a salea logic data/setting file and should be renamed to pcf8574a.logicdata , if you don't have a salea logic analyser you can download the software from salea logic and view the complete data
Steve,
I did run the program:
P0, P5 and P6 do not toggle: they are always at 0vdc as seen by the scope.
I did check the tracks : there is good continuity between each pin of the PCF and the display pins.
I assume the pcf is gone or the module has been sent with a broken pcf.
As you have seen in the photos, I have changed the contrast pot because it was shorting the 5 vdc to ground , I fit a new one with a "crossed" pins.
Will order a new board from a reliable seller ... I am searching for it here.
Thanks for all.
Ambrogio
richard
It is the current device.
The PCF8574 and PCF8574A are identical, except for the different fixed portion of the slave address. The address used is 78 which fits with it being a PCF8574T and you use $78 which again fits with yours being a PCF8574AT.
Thanks Richard,
I confirm that the address is OK since I can get some pins toggling correctly.
the PCF has definitively some "broken" port pins.
I still have the suspect that this is a fake board: It has the contrast pot error ... and now it has this issue !
Thanks a lot
Ambrogio
iw2fvo
iw2fvo
Steve,
Thanks for all.
Ambrogio
Well done it is the PCF!
I am surprised I thought the PCF was the least likely cause the PCB track or soldering fault was the most likely cause.
I have tested this code and it works!
'DEFINE I2C_SLOW 1
LCD_Addr CON 78
LCD_Idx VAR BYTE
testmode var byte
gosub LCD_Write_
PAUSEUS 6000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
gosub LCD_Write_
PAUSEUS 1000
LCD_Data = $28
LCD_Data = $0C
LCD_Data = $01
PAUSE 2
LCD_Data = $06
LCD_WRITE_:
LCD_E = 1
LCD_Backlight = 0
LCD_Data = "T"
LCD_Data = "e"
LCD_Data = "s"
LCD_Data = "t"
LCD_Backlight = 1
LCD_Data = "-"
iw2fvo
I am not a good programmer and I would like to convert the PBP program that is normally used now to EASY control the I2C display.
At the moment I am using this piece of code:
INS CON 254 ' $FE: INSTRUCTION COMMAND MODE
CLR CON 1 ' CLEAR LCD , GOTO FIRST LINE, FIRST CHARACTER
DG CON 223 ' DEG SYMBOL °
LINE1 CON 128 ' $80: GOTO LINE 1
LINE2 CON 192 ' $C0: GOTO LINE 2
LINE3 CON 148 ' $94: GOTO LINE 3
LINE4 CON 212 ' $D4: GOTO LINE 4
And then I do the the following to write my own data on it:
LCDOUT INS, LINE2, " V=", DEC2 VLT/10, ".", DEC1 VLT
How could I translate the above in I2C enviroment for displaying ?
Thanks for the assistance
Ambrogio
IW2FVO
How to do this as neatly as possible are the next steps.
the ext modifier should help
lcdb VAR BYTE[22]
lcd_cmd = _lcdb
lcd_buff = _lcdb+2
these must be after the asm code
lcd_cmd var byte EXT
lcd_buff var byte EXT
lcdb[0]=$fe
lcdb[1]= your lcd command eg 1 $80 $c0
use arraywrite to load lcd_buff (max 20 chrs)
then you can pass
lcd_cmd to your lcd write code if you need to send a cmd with your lcd string
or pass lcd_buff if no cmd required
ps don't forget to add a dely after a cmd to give the lcd time to act
ps ps
the asm names are case sensitive
left a bit out
not sure if it needs to be try it and see
lcd_cmd var byte[2] EXT
lcd_buff var byte[20] EXT
richard
lcdb VAR BYTE[22]
lcd_cmd = _lcdb
lcd_buff = _lcdb+2
lcdb[0]=$fe
then you can pass
ps ps
left a bit out
Steve,
the point is that I do not have PBP_3.
My pbp is 2.50 B.
No arraywrite or read, no usercommand ... are available to me .
Ambrogio
Ambrogio is using pbp2.5 and I am even older on 2.46.
without arraywrite that's a lot of code
richard
and a lot more fun!
I am only along for the ride and to keep my brain ticking over. :smile:
does 2.5 have the dig command
The DIG modifier has been there forever....
Steve,
it is a very good new !
I am looking to place an order for a couple of new extender boards. The point is the lead time .
I will let you know.
I appreciate your assistance.
Ambrogio
Thanks to all of you for the assistance.
What is the dig modifier please ?
Thnaks
Ambrogio
From manual:
DIG returns the value of a decimal digit. Input the digit number (0 – 9, with 0 being the rightmost digit). DIG returns the value of the decimal digit that you specified. DIG is commonly used to distill BCD digits from numeric values and to isolate single digits for display on seven-segment LCD.
B0 = 123 ' Set B0 to 123
B1 = B0 DIG 2 ' Sets B1 to 1 (digit 2 of 123)
iw2fvo
Steve,
Ambrogio
No next day delivery in Italy?
I ordered my LCD and backpack for £9.30 including next day delivery, details in #66.
The test program is not very useful as it only tests the LCD is working. I will add commands so that the screen can be cleared and the cursor can be positioned anywhere on the screen.
That is clear to me now.
Ambrogio
Ambrogio
I am working on the program by adding commands as you can see in the picture.
Attachment 7394
Let me know when you are ready.
