I have a circuitry with 3 servo motors + pic.
I am using two parallel 7805 for the motors and one only for the pic.
Unfortunately I found that a choppy servo motor behaviour is due to not enough current being delivered - ie I am working with interrupts so two servos need current at the same time.
I found that one (of the parallel) 7805 remains cold while the other one is becoming very hot.
Should there be one 7805 for each motor + one for the pic, ie 4x7805 or should my current configuration be sufficient but one 7805 is faulty or some other solution?
Maximum current per 7805 is 1A accord. to the data sheet.
