Siemens c55 sms control help please
I cant put this simple sms sender to work in pic(the phone works pdu mode only on hterminal works all call and sms) . In my code you can see 2 parts 1 is the dailing that works fine the other was to be a sms sender but i cant put it to work can you please helpp me on that thans a lot.
By by
@ Device HS_OSC ' High Speed Crystal
define OSC 20
Include "modedefs.bas" ' Include serial modes
' Define LCD registers and bits this time not use it for later apps..
Define LCD_DREG PORTB 'Lcd D 4-bit parallel register starts at PortB.4 to PortB.7
Define LCD_DBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 2
Define LCD_EREG PORTB
Define LCD_EBIT 3
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 50 ' Data Delay (uS)
DEFINE OSC 20 'Define oscilator frequency
DEFINE LCD_LINES 4 'Number lines on LCD
DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
TrisC.5=0
TrisC.6=0
TrisC.7=1
B0 var byte
High portC.5 ' Led flashing to see if wardware are ok
Pause 500
Low portC.5
Pause 500
High portC.5
Pause 500
Low portC.5
Pause 500
HSEROUT ["AT", 13]
HSEROUT ["ATD+351xxxx31210;", 13] 'phone dials to number no problem here
pause 5000
' Now were is the problem is when i thange the dialing line command for the sms to send a sms and the phone do nothing.. :(
'HSEROUT ["AT", 13]
'HSEROUT ["AT+CMGS=16", 13]
'HSEROUT ["079153912601000011000C915391663921010000AA02EF35",13]
STOP
