Multiple HPWM question
Hello,
I just made an experiment with 18F4431 again.
The blinky program works, and now I want to have multiple / simultanous HPWM
My code did not work, How to setup so the RB0,1,2,3 become PWM PORT ? Is there any other register to modify ? Thanks
DEFINE OSC 8 ' Oscilator HS
TRISA = %00000000 ' Set PORTA to all output
TRISB = %00000000 ' Set PORTB to all output
TRISC = %00000000 ' Set PORTC to all input
TRISD = %00000000 ' Set PORTD to all output
TRISE = %00000000 ' Set PORTE to all output
ANSEL0= %00000000 ' Analog channel AN0-AN7 off
ANSEL1= %00000000 ' Analog channel AN8 off
hpwm 0, 100, 7000 'RB0 as hpwm output
hpwm 1, 180, 7000 'RB1 as hpwm output
hpwm 2, 250, 7000 'RB2 as hpwm output
See the example in this thread http://www.picbasic.co.uk/forum/showthread.php?t=7095
Between that & the data sheet you should be able to get it going.
Thank you Bruce,
It works :)
