Darrel Taylor
Ha, It's exactly the same. Except EVERYTHING'S different.
And I come back to reading the manual once again...
You've changed the SYMBOL's to VAR's, removed the LET's and changed a binary number to decimal. And while the program now looks completely different. After compiling, the HEX file will be byte for byte identical to the original code. No changes. No fixes.
The manual says 'Symbol can only be used to alias a variable, not to create it'. As far as the LET and SYMBOL, I referenced both of those at the beginning of the post... No changes, no fixes? I'm wondering...
Since it doesn't look anything like the original program, the "guy that wrote it" now has to spend probably several hours searching colon by colon, trying to find what it was that you changed. (took me an hour)
Huh...I'm fairly handy with an 'Enter' key, and maybe a little bit of the 'Delete' key. Only took me about a couple of minutes or so to get one command per line. And again, the guy should be able to recognize what's where in the first place.
And won't he be pissed after doing all that, only to find out that it doesn't make any difference.
Maybe so, but maybe he'll learn a bit of something here and there and fix his own problem.
There's no way to follow the flow of the program. You can't see any type of structure. It's just a bunch of lines of code. Very long lines at that. My guess is that you have a Wide screen monitor and make the code fit a maximized window, all the way across the screen. For anyone with a normal sized screen, they're now scrolling left and right, instead of up and down.
Could be... I run 16 x 12, turned 90 degrees. And who's to say what's normal? What does your newspaper, comic book, any other book look like? I'll bet if you put a page from one of those across your screen, it would fit a lot better if the screen was rotated about 90 degree, left or right... If anything, I'd say the way 'normal' people use a monitor is 'abnormal' compared to the way people have been reading printed material for years.
And one last problem ... There's no room for comments. Come back to that program in 6 months, and you're going to need some laxitives for those Colon's.
True...but I won't be coming back to it.
On a scale of 1-10, I'd give this formatting a 9 for the the best way to NOT write your program.
I think what you really mean is that you'd give this formatting a 9 for the best way NOT to write YOUR program.
However, I'd give this formatting a 10 for the BEST way to write MY program.
