PIC to serial with visual basic
		Hello,
I am trying to hook up my PIC18F4550 to my serial port and send data using Visual Basic.  The code for the PIC is below.  I have a 22K resistor on the RX line of the PIC.  The RTS and CTS lines I have working (thanks to skimask) but I can't seem to get the RX to work.  The PC should transmit a "4" and the PIC should receive it and test its value.  For visual basic the instruction I am using is: SerialPort.Write("4").  I believe I have the right baud and everything setup (9600) but I can't be sure (the rest is the default setup).  Any help is appreciated!  Thanks,
-Mike
Code on PIC:
Include "modedefs.bas"
define HSER_CLROERR  1
define HSER_RCSTA    90h
define HSER_BAUD     9600
define HSER_TXSTA    20h
define OSC 4
rts var porta.2
cts var portd.3
led var portd.2
rx  var portc.7
OK var word
input rts
output cts
output led
ADCON1 = %00001111
low led : low cts
while rts = 1
    high cts
    SERIN rx,N9600,OK
    if ok = "4" then
        high led
wend
low cts
