SOLVED - IOC works on B0 but not B5
Solved in post #8: https://www.picbasic.co.uk/forum/sho...142#post156142
I had set my CCP defines to CCP4 and CCP5 by mistake, I meant it to be to CCP3 and cCP4.
PIC 16F18877
I've:
- moved CCP3 from B5 to D2
- moved CCP4 from B0 to D3
- disabled PPS on pins B0 and B5
I can detect a negative edge on B0, but not on B5.
@ ERRORLEVEL -306 ; turn off crossing page boundary message
' Default in file: PBP3_1\DEVICES\PIC16F18877.PBPINC *
' List in file: PBP3_1\DEVICE_REFERENCE\PIC16F18877.INFO *
' Note: PIC18 devices, the __CONFIG directive has *
' been superceded by the CONFIG directive *
__config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
;--- Defines -------------------------------------------------------------------
DEFINE OSC 32
DEFINE LCD_DREG PORTD ' Set LCD data port
DEFINE LCD_DBIT 4 ' Set starting data bit
DEFINE LCD_RSREG PORTD ' Set LCD register select port
DEFINE LCD_RSBIT 1 ' Set LCD register select bit
DEFINE LCD_EREG PORTD ' Set LCD enable port
DEFINE LCD_EBIT 0 ' Set LCD enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size
DEFINE LCD_LINES 4 ' Set number of lines on LCD
DEFINE LCD_COM1MANDUS 1000 ' Set COM1mand delay time in microseconds
DEFINE LCD_DATAUS 50 ' Set data delay time in microseconds
define CCP4_REG PORTD ' PWM Pulse out to LCD contrast
DEFINE CCP4_BIT 2 ' 2N2907 PNP with 1K on base
define CCP5_REG PORTD ' PWM Pulse out to LCD backlight
DEFINE CCP5_BIT 3 ' 2N2222A NPN with 1K on base
;--- Setup registers -----------------------------------------------------------
'INTCON = %10000000 ' Controlled by DT-INTS
'PIE0 = %00010000
IOCBP = %00000000 ;IOC Interrupt, Positive Edge, low-to-high
IOCBN = %00100001 ;IOC Interrupt, Negative Edge, from high-to-low
'IOCDP = %00000000 ;...not available
'IOCDN = %00000000 ;...not available
'IOCEP = %00000000 ;...not available
'IOCEN = %00000000 ;...not available
WPUB = %00100001
' CCP3 moved from B5 to D2 !
' CCP4 moved from B0 to D3 !
PinD2 CON %011010 ' Datasheet table 13-2
PinD3 CON %011011
CCP3PPS = PinD2 ' CCP3 Peripheral input selection
CCP4PPS = PinD3 ' CCP4 Peripheral input selection
PeripheralCCP3 CON %001011 ' Datasheet table 13-3
PeripheralCCP4 CON %001100
RD2PPS = PeripheralCCP3 ' Pin D2 output source selection
RD3PPS = PeripheralCCP4 ' Pin D3 output source selection
RB0PPS = 0 ' Disable CCP4 on pin B0 (moved to D3)
RB5PPS = 0 ' Disable CCP3 on pin B5 (moved to D2)
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00000000
ANSELE = %00000000
TRISA = %00000000
TRISB = %00100001
TRISC = %00000000
TRISD = %00000000
TRISE = %00000000
Pause 500
HPWM 3,250,1953 ' Pulse Contrast
HPWM 4,150,1953 ' Pulse Backlight
IOCBF = %00000000
LCDOUT $FE, 1 : Pauseus 1
LCDOUT $FE, $80, "COM/NAV ENCODER TEST" : Pauseus 1
PAUSE 500
Mainloop:
if IOCBF.0 = 1 then
LCDOUT $FE, $94, "... Swap B0 ..." : Pauseus 1
IOCBF.0 = 0
if IOCBF.5 = 1 then
LCDOUT $FE, $D4, "... Swap B5 ..." : Pauseus 1
IOCBF.5 = 0
goto mainloop
I've gone through the datasheet, but I can't see anything else "special" about pin B5...?
Re: IOC works on B0 but not B5
you need to read and adhere to the PBP3_PPS_notes.txt file in your pbp3 directory
THIS FILE HAS BEEN UPDATED FOR PBP 3.1.1
Devices with full Peripheral Pin Select (PPS) may be manipulated with the
DEFINEs listed below. Default values shown may be subject to change due to
Microchip pre-defined values. If in doubt, use the DEFINES to override defaults.
Default output pins if no DEFINE is used:
Pins: 8 14/16 20 28/40/48 64
CCP1 RA2 RC5 RC5 RC2 RC2
CCP2 RA5 RC3 RC3 RC1 RC1
CCP3 RA2 RA2 RB5 RC3
CCP4 RC1 RA4 RB0 RG3
RX1 RA1 RC5 RB5 RC7 RC7
TX1 RA0 RC4 RB7 RC6 RC6
RX2 RC1 RC1 RB5* RG2
TX2 RC2 RC2 RB4* RG1
* RX2/TX2 defaults changed for some devices in PBP 3.1.1 to avoid ICSP lockout.
Note that on some devices, any pin that is assigned to a CCP channel
may not function as normal I/O. If a pin's CCP default inhibits a
desired function, you can cancel the default as described below.
HPWM
Use the following PBP DEFINE statements to specify the output pins for HPWM.
Check the Microchip datasheet (Peripheral Pin Select PPS) for the pins allowed
on each CCP channel. The PPS peripheral will automatically be configured
for the specified output pin upon execution of HPWM. When used on devices
without PPS, these defines will only control the Data Direction SFRs (TRIS).
These defines set PPS SFRs only once at program initialization. You may
change the PWM output pin at any point in your program code by modifying
the PPS SFRs. The HPWM command may be used without these DEFINEs if you
manually configure the PPS and TRIS SFRs.
As noted below, you may use DEFINE CCPx_REG 0 to inhibit PPS inititalization
and automatic TRIS settings for any channel. You should do this if you plan
to relocate pins with PPS settings at run-time to avoid erroneous TRIS settings.
DEFINE CCP1_REG PORTC 'Channel-1 port
DEFINE CCP1_BIT 2 'Channel-1 bit
DEFINE CCP2_REG PORTC 'Channel-2 port
DEFINE CCP2_BIT 1 'Channel-2 bit
DEFINE CCP3_REG PORTC 'Channel-3 port
DEFINE CCP3_BIT 3 'Channel-3 bit
DEFINE CCP4_REG PORTG 'Channel-4 port
DEFINE CCP4_BIT 3 'Channel-4 bit
DEFINE CCP5_REG PORTG 'Channel-5 port
DEFINE CCP5_BIT 4 'Channel-5 bit
DEFINE CCP6_REG PORTE 'Channel-6 port
DEFINE CCP6_BIT 6 'Channel-6 bit
DEFINE CCP7_REG PORTE 'Channel-7 port
DEFINE CCP7_BIT 7 'Channel-7 bit
DEFAULT CCP PINS SET FOR UNUSED HPWM CHANNELS! If CCP_REG DEFINEs are set
for unused channels, either explicitly or by default, the ports/pins specified
as CCP/PWM outputs may not function as normal I/O until the PPS SRFs are cleared
in your program code. To remove a default setting, define the CCPx_REG as 0,
for example:
DEFINE CCP2_REG 0 'Channel-2 UNUSED
DEFINE CCP2_BIT 0 'Channel-2 bit
DEFINE CCP3_REG 0 'Channel-3 UNUSED
DEFINE CCP3_BIT 0 'Channel-3 bit
DEFINE CCP4_REG 0 'Channel-4 UNUSED
DEFINE CCP4_BIT 0 'Channel-4 bit
Oooops, added edit to your post by mistake.... (- Demon)
I don't understand how you seem to have disabled the PPS for pins B0 and B5 without allocating something to them. Don't they need something allocated to them whether it's a port access or peripheral whatever if you plan to use the pins?
Apologies, I'm still learning this stuff,
Troy
richard
Aren't those DEFINES the exact same thing as:
Or is there an extra step going on in the background?
rocket_troy
Troy
Yeah, so am I.
I looked for a way to move "treat this like a GP pin" via PPS settings, but I don't see anything like that.
Unless you just can't recycle CCP pins, unless you move another peripheral to it (which is very possible).
the power on default state for RxyPPS regs is 0 ie pin is assigned to be gpio
so
RB0PPS = 0 assigned to pin RB0 TO be a gpio pin [which it already was ]
none of this serves any worthwhile purpose if you do the pbp3 HPWM defines correctly
PinD3 CON %011011
CCP3PPS = PinD2 ' CCP3 Peripheral input selectiowm in hpm mode the ccp modules have no input function
RD2PPS = PeripheralCCP3 ' Pin D2 output source selection all done with pbp define
RB0PPS = 0 ' Disable CCP4 on pin B0 (moved to D3) all done with pbp define
did i say ioc pin change is a bad way to do keys
try this and compare results
#CONFIG __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_OFF & _FCMEN_ON
__config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
DEFINE OSC 32
define CCP3_REG PORTD ' PWM Pulse out to LCD backlight
DEFINE CCP3_BIT 3 ' 2N2222A NPN with 1K on base
define CCP5_REG 0
DEFINE CCP5_BIT 0
ANSELA = 0
ANSELB = 0
ANSELC = 0
ANSELD = 0
ANSELE = 0
WPUC = % 00100000
WPUB = % 00110000
TRISA = % 00001111
TRISB = % 11111111
TRISC = % 11111111
TRISD = % 11110011
IOCBN = % 00100000
PushSwitchA VAR PortC.5 ;sw2
PushSwitchB VAR Portb.4 ;sw1
PushSwitchC VAR Portb.5
InterruptLED VAR Lata.4
anotherLED VAR Lata.5
polLED VAR Lata.6
notherLED VAR Lata.7
ButtonWasPressed VAR WORD[2]
lc var byte
Pause 500 ' Let PIC stabilize
InterruptLED = 0
anotherLED = 0
Mainloop:
lc=lc+1
if lc==50 then
polLED = !polLED
lc=0
ButtonWasPressed[0] = (ButtonWasPressed[0]<<1) + PushSwitcha
ButtonWasPressed[1] = (ButtonWasPressed[1]<<1) + PushSwitchb
if ButtonWasPressed[0] = $f then ' Check flag
anotherLED = !anotherLED
if ButtonWasPressed[1] = $f then ' Check flag
notherLED = !notherLED
if IOCBF then
InterruptLED = !InterruptLED
IOCBF = 0
pause 10
goto mainloop
pps , my way works fine even with no capacitor on the switches
FOUND IT!
define CCP3_REG PORTD ' PWM Pulse out to LCD contrast
DEFINE CCP3_BIT 2 ' 2N2907 PNP with 1K on base
define CCP4_REG PORTD ' PWM Pulse out to LCD backlight
DEFINE CCP4_BIT 3 ' 2N2222A NPN with 1K on base
The IOC on B0 and B5 now get detected.
Here's my complete code:
DEFINE OSC 32
'PIE0 = %00010000
WPUB = %00100001
PinD3 CON %011011
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00000000
ANSELE = %00000000
TRISA = %00000000
TRISB = %00100001
TRISC = %00000000
TRISD = %00000000
TRISE = %00000000
Pause 500
IOCBF = %00000000
PAUSE 500
Mainloop:
if IOCBF.0 = 1 then
IOCBF.0 = 0
if IOCBF.5 = 1 then
IOCBF.5 = 0
goto mainloop
richard
...none of this serves any worthwhile purpose if you do the pbp3 HPWM defines correctly...
I'm a very fast learner, as long as you explain very slowly a bunch of times and let me fumble around for a few hours/days. :D
I commented out all my PPS settings and those Defines were indeed all I needed for it to work.
richard
try this and compare results...
Richard, I have no doubt your way is leaner, faster and more efficient. I might even figure out what's going on after staring at it for a few hours with my PBP manual beside me.
But I have to adapt whatever code I come up with for 88 switches and 24 rotary encoders. So far, this way has worked reasonably well, and I understand what's going on.
I do appreciate the help and suggestions; I might even try it later, or someone else will.
Just to confirm, there definitely is something else required than my PPS settings.
I commented out the 4 DEFINES and used only my PPS settings and it didn't work.
I activated the 4 DEFINES and commented out all my PPS settings and it worked.
for what its worth
porta.4 also fails to operate as a normal gpio i/p when hpm is used
DEFINE CCP5_REG 0
DEFINE CCP5_BIT 0
is needed to restore operation
edit, i had mixed up cause and effect i had sw on c5 and led on a4 i assumed led failure to operate as intended was due to sw not working
but sw was fine led pin not so
moral to story
if you use hpm it will mangle all the default pins for normal use unless you take action
Demon
Yeah, so am I.
I was thinking outputs not inputs - [slapping forehead] my bad
Troy
richard
PinD3 CON %011011
I realize that now. I had just gone through the datasheet and picked up all the registers I thought related with PPS, then tried setting them up in my I thought would swap the CCP function from pins Bx to Dx.
EDIT: Apparently I was doing something wrong, or forgetting something altogether.
The HPWM command may be used without these DEFINEs if you manually configure the PPS and TRIS SFRs.
from PBP3_PPS_notes.txt in PBP3_1 folder
rocket_troy
Troy
I'm no better; look at the previous post when I was blindly setting inputs when I was using outputs only.
:D
If MCC can produce all the config code, why not use this tool?
For some reason I have not found why I am not able to use it on my PC. But I guess Richard can as we discussed that some time ago.
If MCC can produce all the config code, why not use this tool? ...
What is MCC, and what tool are you talking about?
:confused:
MCC is the tool. MPLAB Code Configurator.
Select a device, select peripheral(s), select configuration for those peripheral(s) and it outputs configuration code for you (in C syntax).
rocket_troy
Troy
(bottom of p. 239 of datasheet 16F18877)
Note: When RxyPPS = 0x00, port pin Rxy output value is controlled by the respective LATxy bit.
Took me a while to notice this line.
