I wrote this app, which appears to function with the exception of powerup. The Hi setpoint appears to get set, but I never see the delays or the splash screen, I start out seeing main loop on the screen. I added delays and never could make it go away. Anyone else have this issue?
' Name : blink_Serial_test.pbp
' Compiler : PICBASIC PRO Compiler 2.6
' Assembler : PM or MPASM
' Target PIC : 16F or 18F types
' Hardware : Non specific
' Oscillator : internal or external
' Keywords : BLINK LED
' Description : PICBASIC PRO program to to blink an LED and write to a screen
' connectedto PORTB.7 about once a second
'The following program is a simple test to blink an LED on and off and write to
'a screen the color LED being blinked. Select a
'device in the dropdown list above, then click the Compile Only button on the
'toolbar to compile the program and generate a hex file.
'THIS FILE USES THE INTERNAL OSCILLATOR!
' Configure pins for digital operation (uncomment as needed).
' These settings are intended as simple examples. For more detail,
' see the appropriate device datasheet for register descriptions.
'ANSEL = %00000000 ' 16F88, 16F688, 16F690, 16F88x
'ANSELH = %00000000 ' 16F690, 16F88x
'ADCON1 = %00000111 ' 16F87x, 16F87xA, 18F452
'ADCON1 = %00001111 ' 18F4620
include "modedefs.bas"
OSCCON=%01101000
define osc 4
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
CMCON = 7 ' Disable analog comparator
ANSEL = %00000011 'enable A0-A2 as Analog inputs
ADCON1 = %10000000 'right justify
OPTION_REG.7 = 0
RED_LED VAR PORTB.2 ' Assign name "LED" to PORTB.2 - activity light
Green_LED VAR PORTB.0 ' Assign name "LED" to PORTB.0 and start relay
Yellow_LED VAR PORTB.1 ' Assign name "LED" to PORTB.1 and stop relay
LCD var PORTB.7 ' Assign name "LCD" to PORTB.7
AIN0 var word 'Battery Voltage
AIN1 var word 'Start Time
AIN2 var word 'Start Voltage
Volts_0 var word 'Battery Voltage
Volts_1 var word 'Start Time
Volts_2 var word 'Start Voltage
Start_Seconds var word
HI_0 var BYTE
LOW_0 var BYTE
HI_1 var BYTE
LOW_1 var BYTE
HI_2 var BYTE
LOW_2 var BYTE
HI_SP var BYTE
LOW_SP var BYTE
Hi_Side var byte
Low_side var byte
temp var word
temp1 var word
temp2 var word
Start_Try VAR byte
Low_Volts_Count var byte
Hi_Volt_SP var word
ACvolts_In VAR PORTB.6
ACvolts VAR BIT
Powerup:
High LCD
Pause 100
serout 7,n9600,[254,1]
Pause 100
serout 7,n9600,[254,1,"Covey Off Grid"]
serout 7,n9600,[254,192," Monitor V0.5"]
Hi_Volt_SP = 275 'Setpoint*10 to turn off Gen.
HI_SP = Hi_Volt_SP/10
LOW_SP = Hi_Volt_SP//10
Pause 2000
Low_Volts_Count = 0
if PORTA.7 then Goto Mainloop 'for future setup jumper
if NOT PORTA.7 then Goto Mainloop 'for future setup jumper
Mainloop:
serout 7,n9600,[254,1," Mainloop"]
Start_Try = 0
Low Green_LED
low Yellow_LED
High RED_LED ' Turn on LED connected to PORTB.0
Pause 500
Gosub Analog_In_0 'Battery Voltage
pause 30
Gosub Analog_In_1 'Start Time
pause 30
Gosub Analog_In_2 'Start Voltage
pause 30
Gosub Display_Stats
Low RED_LED ' Turn off LED connected to PORTB.0
if AIN0 < AIN2 then Low_Volts_Count = Low_Volts_Count+1
if AIN0 < AIN2 then serout 7,n9600,[254,1," Low Volts Count"]
if AIN0 < AIN2 then serout 7,n9600,[254,192," ",#Low_Volts_Count]
if Low_Volts_Count >= 3 then Goto EngineStart
if Low_Volts_Count < 3 then goto Mainloop
Analog_In_0:
serout 7,n9600,[254,1," Analog_In_0"]
ADCIN 0, AIN0
Volts_0=AIN0*50/51/2
HI_0 = Volts_0/10
LOW_0 = Volts_0//10
Analog_In_1:
serout 7,n9600,[254,1," Analog_In_1"]
ADCIN 1, AIN1
Volts_1=AIN1*50/51/2
Start_Seconds=AIN1*50/51/2
HI_1 = Volts_1/100
LOW_1 = Volts_1//100
Analog_In_2:
serout 7,n9600,[254,1," Analog_In_2"]
ADCIN 2, AIN2
Volts_2=AIN2*50/51/2
HI_2 = Volts_2/10
LOW_2 = Volts_2//10
Display_Stats:
serout 7,n9600,[254,1," Display_Stats"]
serout 7,n9600,[254,128,"Bat Volts =",#HI_0,".",#LOW_0]
serout 7,n9600,[254,192,"Start Volts=",#HI_2,".",#LOW_2]
Pause 2000
serout 7,n9600,[254,1," Crank Sec=",#HI_1,".",#LOW_1]
Pause 1000
EngineStart:
ACvolts = ~ACvolts_In
serout 7,n9600,[254,1," EngineStart"]
Low_Volts_Count = 0
If (ACvolts = 0 AND Start_Try < 3) THEN High Green_LED 'High Starter Relay
serout 7,n9600,[254,192,"Start Try# ", #Start_Try]
Pause Start_Seconds*10 '5v ~ 5 seconds
Low Green_LED 'Low Starter Relay
Pause 10000 'pause to re-try starting
If (ACvolts = 0 AND Start_Try < 3) THEN Start_Try = Start_Try +1
If (ACvolts = 0 AND Start_Try < 3) THEN GOTO EngineStart
IF (ACvolts = 0 AND Start_Try >= 3) THEN GOTO LockedOut
If ACvolts = 1 THEN GOTO Charging
LockedOut:
serout 7,n9600,[254,1," LockedOut"]
Low RED_LED ' Turn off LED connected to PORTB.2
Pause 2000 ' Delay for .5 seconds
High RED_LED ' Turn on LED connected to PORTB.2
Pause 250 ' Delay for .5 seconds
Pause 150 ' Delay for .5 seconds
GOTO LockedOut
Charging:
serout 7,n9600,[254,1,"Charging SP=",#HI_SP,".",#LOW_SP]
serout 7,n9600,[254,192,"Bat Volts =",#HI_0,".",#LOW_0]
Pause 3000 ' Delay for .5 seconds
pause 30
'Gosub Display_Stats
If ACvolts = 0 and Volts_0 < Hi_Volt_SP-30 THEN GOTO LockedOut
If ACvolts = 1 and Volts_0 < Hi_Volt_SP THEN GOTO Charging
if Volts_0 > Hi_Volt_SP then Goto Stop_Generator
Stop_Generator
High Yellow_LED ' Turn on LED connected to PORTB.1 and stop relay
Pause 10000
Low Yellow_LED ' Turn off LED connected to PORTB.1 and stop relay
Goto mainloop
