Pic Speed / Instruction Speed etc
Hi all,
I've got some code im testing, basically to decode a trigger wheel, and output 3 pulses per rotation of the wheel which has 35 teeth.
CMCON = 7 ' set portA to digital
TRISA = %00100000 ' Port A all output but MCLR
TRISB = %00001000 ' Port B all output but 3 (CCP)
InPIN VAR PORTB.3 ' Define input pin
OutPIN VAR PORTB.5 ' Define output pin
LastState VAR BIT ' Last Pin State
PulseCount VAR BYTE ' Number of input pulses
PulseCount = 0
Low OutPin
MainLoop:
if InPIN <> LastState then ' If Input State Changed
LastState = InPIN
PulseCount = PulseCount + 1
Select Case PulseCount
Case 1
High OutPin
Case 4
Low Outpin
Case 12
High OutPin
Case 15
Low Outpin
Case 24
High Outpin
Case 27
Low Outpin
Case 35
PulseCount = 0
Low OutPin
Case is > 35
PulseCount = 0
Low OutPin
Case Else
End Select
GOTO MainLoop
at maxium wheel rotation speed, the pic input frequency is approx 5khz,
now, at 4mhz, should the pic be able to keep up, or does anyone have any alternative code ideas to help improve the performance?
Re: Pic Speed / Instruction Speed etc
I know this is an old post but I made a tach adapter using a PIC 16F1824. It basiclly takes a single cylinder engine signal (1 pulse /720 degrees) and multiplies it by 4 to use a 4 cylinder tach. Works real well if you are interested, I can send you the code. It can be adapted to other situations as well. I also designed a real stable interface to the coil if you don't have a crank trigger.
