Problems starting an 18F8720
High i try to start a basic blinking led, on a 18f8720, but no success, anyone knows config bits i should set to make this chip works ?
My code looks something like this.
HIGH PORTA.1
PAUSE 300
LOW PORTA.0
PAUSE 300
I tried disabling WDT, HSPPL, and multiple different combinations of config bits but nothing did it.
Its not a code problem but i have no clue on how i can debug/ troubelshoot the pic, this is pre-build card with the pic and pinouts.
Should I consider that, because the pic is programmable, its most likkely not blown, i just have to find the right bits, or can it be that it's programmable but will never start because its faulty ?
Regards.
i will try it this evening
Thanks for the reply i will give it a try when going home,
i know adcon can give unexpected behavior sometimes, but i did'nt know it can simply avoid you pic to run a simple blink led.
