RX TX modules - intermitent communication
Hi guys,
I'm starting to play with Rx/Tx modules.
I've bought a couple of Cy2198TR-a modules ( http://www.sure-electronics.net/rf,audio/GP-GC010.pdf ) and connected them to a couple of 16F88 pics.
I was able to communicate from pic to module, choose the channel and when transmitting/receiving i can see the Busy led on on both of them.
The transmitter is sending a simple message ( a 4 digit value ) every second.
The problem is the receiver side.
Sometimes skips messages, sometimes shows the entire message ( 4 digit value ), sometimes shows just on or two digits of the message.
Here is the code for the RX and TX:
RX
CCP1CON = %00000000 ' Disable CCP
SSPCON.5 = 0 ' Disable SSP Module
CMCON = %00000111 ' comparator off
TRISA=%00010001
TRISB=%00000111
'DEFINEs
@ DEVICE PIC16F88, HS_OSC
@ DEVICE PIC16F88, MCLR_OFF
@ DEVICE PIC16F88, PROTECT_OFF
DEFINE OSC 8
@ DEVICE PIC16F88, CPD_OFF
@ DEVICE PIC16F88, LVP_OFF
@ DEVICE PIC16F88, BOD_OFF
@ DEVICE PIC16F88, PWRT_OFF
@ DEVICE PIC16F88, WDT_OFF
@ DEVICE PIC16F88, CCPMX_OFF
'ADC
DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
ANSEL=%00000001
ADCON1=%10000000 'no Vref - Right Justify
ADCON0=%11000001
' DEFINE LCD pins
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 3
DEFINE LCD_EREG PORTA
DEFINE LCD_EBIT 2
DEFINE LCD_BITS 4
DEFINE LCD_LINES 4
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
'debug defines
INCLUDE "modedefs.bas"
DEFINE DEBUG_REG PORTB
DEFINE DEBUG_BIT 3
DEFINE DEBUG_BAUD 19200
DEFINE DEBUG_MODE 1
DEFINE DEBUGIN_REG PORTB
DEFINE DEBUGIN_BIT 2
DEFINE DEBUGIN_BAUD 19200
DEFINE DEBUGIN_MODE 1
'PINS
adc var PORTA.0 'analog input
in var PORTA.1 'n/a
A2 var porta.2 'lcd
A3 var porta.3 'lcd
A4 var porta.4 'n/a
pgm var porta.5 'n/a
RsBit var porta.6 'xtal
EBit var porta.7 'xtal
BUT1 var portb.0 'button
stat var portb.1 'reserved for buSY
led2 var PORTB.2 ' in
nc var PORTB.3 ' out
lcd4 var portb.4 'Data pin for LCD
lcd5 var portb.5 'Data pin for LCD
lcd6 var portb.6 'Data pin for LCD
lcd7 var portb.7 'Data pin for LCD
'variables
media var WORD 'average
ME var WORD '
ps4 var WORD '
value var WORD 'value received
ra var word
MYDATA var word
'contants
Row1 CON 128 'constant for LCD line1
Row2 CON 192 'constant for LCD line2
Row3 CON 148 'comstant for LCD line3
Row4 CON 212 'constant for LCD line4
cl con 254 'constant for LCD clear line
clear
INCLUDE "lcdbarIN.bas"
DEFINE LCD4X20 1
INIT:
pause 400
lcdout $fe,1," TX demo "
lcdout $fe,$c0," ... "
pause 1500
debug $55
if but1=1 then
goto chann
man:
high pgm
me=0
for ra=0 to 15
adcin adc,value
pause 50
me=me+value
next ra
me=me/16
media=me
media=(media*/5000)>>2
lcdout cl,row1," adc ", dec value
lcdout cl,row2," average ", dec media
transmit:
lcdout cl,row4,"transmiting - ",dec value ," "'change B1 for B2
debug $55,"ok", dec value dig 3, dec value dig 2, dec value dig 1, dec value dig 0
goto man
chann:
low pgm
pause 50
while but1=1
debug $af, $00
wend
goto man
and the RX
ANSEL = %00000000 ' digital mode
TRISA=%00111100
TRISB=%00000111
'DEFINEs
DEFINE OSC 8
' DEFINE LCD pins
DEFINE LCD_DBIT 4
DEFINE LCD_RSBIT 1
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 4
'debug defines
DEFINE DEBUG_BIT 3
DEFINE DEBUG_MODE 1
'PINS
a1 var PORTA.0 'lcd
a2 var PORTA.1 'lcd
led var porta.2 'n/a
A3 var porta.3 'n/a
A4 var porta.4 'n/a
pgm var porta.5 'frequency
BUT1 var portb.0 'button1
'variables
ME var WORD '
ps4 var WORD '
value var WORD '
ra var word
MYDATA var word
'contants
clear
DEFINE LCD4X20 1
INIT:
pause 400
lcdout $fe,1," RX demo "
pause 1500
if but1=1 then
goto chann
man:
high pgm
me=0
lcdout cl,row2," media ", dec media
rec:
debugin [wait ("ok"),dec4 MYDATA]
lcdout cl,row4," "
lcdout cl,row3," "
lcdout cl,row4, "received - ",DEC MYDATA
goto REC
chann:
low pgm
pause 50
while but1=1
debug $af, $00
wend
goto man
Any ideas for this to occur ?
I thank in advance
