I'm considering an application which requires a 12F683 to perform a very fast A/D conversion - I don't need the full 10 bits the ADC normally supplies, probably just 4 bits of resolution is adequate. Reading the data sheet it says that if you terminate the conversion early (after say 5 TAD periods) nothing is stored. Is there a trick to get around this ?
Andrew
