Hello,
Someone can guide me to do a semaphore using a pic12f629 with which one can vary the speed of lighting of the LEDs.
Thanks for any suggestions
Hello,
By Semaphore you mean?
What do you want to control the speed with? A pot or have a set of pre determined speeds selected by button pushes or some other manner?
First we need to work on the schematic. The way it is drawn the red and green leds will never light up. Yellow is OK.
You will also want it rigged so if a green is on the corresponding red at the other fixture will be off.
Take a look here and see if you want to use a configuration something like the drawing with three pins (with a little tweaking)
http://www.mackrackit.com/mac/www/dave/LED/LEDs.html
That is doable. If GP4 is LOW, making GP0 or GP1 or GP2 High will make the connected LED light. The same for GP5.
Being I do not know the sequence you want them to light here is an idea.
Your code will have the "blinking" sequence with multiple pauses. The value of the pauses will be held in a variable. A button will connect to GP3 as an interrupt. Every time the button is pushed the variable will increase by the amount you want. Once the highest value is reached the variable will reset to the lowest.
Maybe something like that will work for you.Code:"VARIABLES
X VAR WORD:Y VAR WORD:Z VAR WORD
ON INTERRUPT GOTO MYINT
INTCON=%10001000
IOC = %00001000
'YOUR SEQUENCE
DISABLE
MYINT:
IF GPIO.3 = 1 THEN
X = X * 10
Y = Y ???
Z = Z ???
IF X => ? THEN X = ??
IF Y => ? THEN Y = ??
IF Z => ? THEN Z = ??
INTCON.1 = 0
RESUME
ENABLE
You can accomplish the result with only 3 output ports. Connect Red led A and Green led B from port one to ground; Green led A and Red led B from port one to + 5V (pay attention to the polarity). Yellow led A to port 2 and Yellow led B to port 3. When Port one is High the green/red leds (correctly polarized will lit) when port one will turn low you will switch on the second set of green/red leds.
With port 2 and 3 you modulate the yellows.
Well, ok.
But I accept no responsibility for the resulting accidents. :eek:
Code:@ device INTOSCIO, WDT_OFF, PWRT_OFF, MCLR_OFF, PROTECT_OFF, CPD_OFF
DEFINE OSCCAL_1K 1
Green CON 5000 ; mS to show Green Light
Yellow CON 1000 ; mS to show Yellow Light
Tcalibrate CON 480 ; Adjust for loop timing accuracy
Sequence VAR BYTE ; cycles through the 4 states
TimeCount VAR WORD ; Counts down sequence time
CMCON = 7 ; Disable comparator
GPIO = %110000 ; Start with all LED's off
TRISIO = %001000 ; Set LED ports to output
FOR Sequence = 0 to 3
LOOKUP2 Sequence,[ Green, Yellow, Green, Yellow], TimeCount
REPEAT ; Multiplex
LOOKUP Sequence,[%100001,%100011,%100100,%100100],GPIO ; Tr. Light #1
PauseUS Tcalibrate
LOOKUP Sequence,[%010100,%010100,%010001,%010011],GPIO ; Tr. Light #2
PauseUS Tcalibrate
TimeCount = TimeCount - 1
UNTIL TimeCount = 0
NEXT Sequence
GOTO Main
Pleeeeeeease don't install these traffic lights in Colorado.
My wife thinks;
Green = go
Yellow = go really fast
Red = stop if you can
Would really screw up the natural order of things..;o}
Hello friends,
Upss was wrong with the sequence of lights here correct.
http://img367.imageshack.us/img367/2...lightokyk2.gif
Hummm,
The code works very well but I want to change the sequence of image.
How can I change the code with this sequence.
Just change the numbers in the LookUp's.
Code:%100001
|| ||Red
|| |Yellow
|| Green
|0=Tr.Light #1
0=Tr.Light #2
Ready already got!.
I didn't see that you edited your post.
Oh well, I needed the Flash practice anyway.
<OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" CODEBASE="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0" WIDTH="600" HEIGHT="400" ><PARAM NAME="MOVIE" VALUE="http://www.pbpgroup.com/files/TrafficLight.swf"><PARAM NAME="PLAY" VALUE="true"><PARAM NAME="LOOP" VALUE="true"><PARAM NAME="QUALITY" VALUE="high"><EMBED SRC="http://www.pbpgroup.com/files/TrafficLight.swf" WIDTH="600" HEIGHT="400" PLAY="true" LOOP="true" WMODE="opaque" QUALITY="high" TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"></EMBED></OBJECT>
"didactic"
That was a new word for me.
I found several "definitions" for it. But I think this one fits exactly what I want to accomplish ... some day.
http://www.merriam-webster.com/dictionary/didactic
- a: designed or intended to teach
b: intended to convey instruction and information as well as pleasure and entertainment :)
Thanks!
