'* Name : Nested ForNextDemo.BAS *
'* Author : [Joe S. ] *
'* Notice : Copyright (c) 2009 [ ] *
'* : All Rights Reserved *
'* Date : 6/7/2009 *
'* Version : 1.0 *
'* Notes :MPASM Assembler, PIC 16F690 *
@ __config _INTOSCIO & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF
include "modedefs.bas"
ANSEL = 0
ANSELH = 0
CM1CON0 = 0
CM2CON0 = 0
index var byte
index2 var byte
index3 var byte
value var byte
value2 var byte
value3 var word
array var byte[6]
pause 50
serout PortB.7,T2400,[254,1] 'Cleasr LCD
serout PortB.7,T2400,[254,2,"Nested For Next Demo"]
loop:
Value = 0
Value2 = 0
Value3 = 0 ' Perform for next counters nested 3 levels deep
for index = 1 to 10 step 1 ' Do whole routine 10 times, count
lookup index,[0,"0123456789"],value
pause 1
serout PortB.7,T2400,[$FE,2,"value ",value]
for index2 = 1 to 8 step 1 'do this count 8 times in each of the 10 loops
lookup index2,[0,"0123456789"],value2
pause 1
serout PortB.7,T2400,[254,$C0,"value2 ",value2]
for index3 = 1 to 5 step 1 'do this 5 times in each of the 80 loops
lookup index3,[0,"0123456789"],value3
pause 2
serout PortB.7,T2400,[254,$94,"value3 ",value3]
pause 100 ' this delay gives you time to see the numbers change
' increase this to slow counters
next index3 ' this next goes first as it was the last to start
next index2 ' started in the middle, it stays in the middle
next index ' "the first will be last and the last will be first" . . . God.
index = 0
for index = 0 to 5 'Index is the pointer used in the array and the counter
array[index] = index + 48 'convert to ASCII & write zero to 5 into index and transfer ASCII to array
serout PortB.7,t2400,[254,$D4,"array is ",array[index]] 'read from array and display on line 4
next index
goto loop ' do for as long as there is power
