Serial Relays
Results 1 to 4 of 4
Thread: Serial Relays
    Smile Serial Relays
    After looking at http://www.rentron.com/PIC16F84.htm I thought I would try some experimenting with the serial I/O expander. Using a keypad to send the data with the [254] qualifier I am able to turn each relay on, however, I would like to be able to turn a relay on and hold it on while I am pressing the button on the keypad but as soon as I let go of the button I want the relay to turn off.
    Also I am using PicBasic Pro compiler and have read through the manual but a lot of things remain unclear. Is there any supplement to this manual or other clear examples to shed some light on things like i=i+1? Here is the code I've been trying to make work the original version is www.rentron.com/PIC16F84.htm Any suggestion?
    INCLUDE "bs2defs.bas"
    relay VAR b3 'relay number storage variable
    stat VAR b4 'relay status ON/OFF variable
    serpin VAR porta.4 'serial input pin
    trisa = %00010000
    trisb = %00000000
    loop:
    SERIN serpin,N2400,[254],relay,stat
    IF relay = 1 THEN outr1
    IF relay = 2 THEN outr2
    IF relay = 3 THEN outr3
    IF relay = 4 THEN outr4
    IF relay = 5 THEN outr5
    IF relay = 6 THEN outr6
    IF relay = 7 THEN outr7
    IF relay = 8 THEN outr8
    IF relay = 9 THEN outr9
    IF relay = 10 THEN outr10
    IF relay = 11 THEN outr11
    IF relay = 12 THEN outr12
    GOTO loop
    outr1:
    IF stat = 1 THEN high1
    LOW 0: GOTO loop
    high1:
    HIGH 0:
    gosub loop1
    low 0: GOTO loop
    outr2:
    IF stat = 1 THEN high2
    LOW 1: GOTO loop
    high2:
    HIGH 1:
    gosub loop1
    low 1: GOTO loop
    outr3:
    IF stat = 1 THEN high3
    LOW 2: GOTO loop
    high3:
    HIGH 2:
    gosub loop1
    low 2: GOTO loop
    outr4:
    IF stat = 1 THEN high4
    LOW 3: GOTO loop
    high4:
    HIGH 3:
    gosub loop1
    low 3: GOTO loop
    outr5:
    IF stat = 1 THEN high5
    LOW 4: GOTO loop
    high5:
    HIGH 4:
    gosub loop1
    low 4: GOTO loop
    outr6:
    IF stat = 1 THEN high6
    LOW 5: GOTO loop
    high6:
    HIGH 5:
    gosub loop1
    low 5: GOTO loop
    outr7:
    IF stat = 1 THEN high7
    LOW 6: GOTO loop
    high7:
    HIGH 6:
    gosub loop1
    low 6: GOTO loop
    outr8:
    IF stat = 1 THEN high8
    LOW 7: GOTO loop
    high8:
    HIGH 7:
    gosub loop1
    low 7: GOTO loop
    outr9:
    IF stat = 1 THEN high9
    porta.0 = 0: GOTO loop
    high9:
    porta.0 = 1:
    gosub loop1
    outr10:
    IF stat = 1 THEN high10
    porta.1 = 0: GOTO loop
    high10:
    porta.1 = 1:
    gosub loop1
    outr11:
    IF stat = 1 THEN high11
    porta.2 = 0: GOTO loop
    high11:
    porta.2 = 1:
    gosub loop1
    outr12:
    IF stat = 1 THEN high12
    porta.3 = 0: GOTO loop
    high12:
    porta.3 = 1:
    gosub loop1
    loop1:
    IF relay = 1 THEN loop
    IF relay = 2 THEN loop
    IF relay = 3 THEN loop
    IF relay = 4 THEN loop
    IF relay = 5 THEN loop
    IF relay = 6 THEN loop
    IF relay = 7 THEN loop
    IF relay = 8 THEN loop
    IF relay = 9 THEN loop
    IF relay = 10 THEN loop
    IF relay = 11 THEN loop
    IF relay = 12 THEN loop
    I am using a 4Mhz resonator, and have set my config at XT, is this correct?
    Thanks to all of you for any help.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Quote Originally Posted by tazntex View Post
    Hmm - Perhaps, if the keypad issues another serial command to tell the controller when a key has been released.
    skimask's Avatar
    skimask Guest
    PBP is PicBasicPro...emphasis on BASIC. There really isn't a supplement to the manual for BASIC, because the whole manual is about BASIC. I can't cite any specific BASIC tutorial other than to Google it and see what you find. Your question on the 'i = i + 1' is reference, albiet indirectly in the manual. i is a variable stored in local memory. = and + are the operators. Whatever is on the right side of the = goes to the left side of the =. Therefore, whatever was in 'i', gets 1 added to it and put back in 'i'.
    And your program needs fixing..........
    Check the PBP manual under branch, save some space and headache
    outr1:
    LOW 0: GOTO loop
    high1:
    HIGH 0:
    gosub loop1
    low 0: GOTO loop
    HIGH 0: will be recognized as a label and not a command, same thing with the rest of the chunks in the rest of the program. You can't have a colon at the end of a line unless it's a label.
    How about this instead:
    IF relay => 0 AND relay <= 12 THEN GOTO LOOP
    T.Jackson's Avatar
    T.Jackson Guest
    Post Few Down-to-earth examples
    As Ski pointed out, i is a variable. It's called a variable because, unlike fixed constants it changes. If i is a byte sized variable it can take on any form between (0-255) Whilst if it's a word sized it can be assigned with anything up to 65,536.
    When we see something like this:
    i = i + 1
    It's basically just adding 1 to the existing contents of i. This is referred to as incrementing. So, if i = 100 and we encounter i = i + 1, the new value of i will be 101.
    For Next Loops:
    FOR i = 1 TO 10
        j = j + 20
    NEXT
    Strangely enough, more than often we encounter i as a variable within these loops. It could be anything actually. J, K - doesn't matter. FOR NEXT loops will execute the contents between FOR and NEXT a predefined number of times which is set by the numbers after TO minus the numbers after FOR. In the example above, j will have 20 added to it 10 times. The final result of j will be 200 when the loop has finished. However, this assumes that the initial starting value of j was 0.
    <br/>
  1. Replies: 33
    Last Post: - 19th March 2010, 04:02
  2. Dynamic USB Serial Number (PIC18F4550)
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 16th July 2009, 18:03
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  5. Serious Serial Situation Setbacks...
    By Dansdog in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 04:46
