All Digital
+ Reply to Thread
Results 1 to 40 of 40
Thread: All Digital
    Quote Originally Posted by jellis00 View Post
    ... Would like to know how to make this modification in DT's ALLDIGITAL.pbp for use as an INCLUDE
    It is an Include, and no modifications are required.
    Or maybe there's more to the question.
    Mar 2009
    Colorado
    Default ALLDIGITAL.pbp works OK with 18F4550
    Ignore my previous, Darrell. What I was saying is I wanted to modify the code in ALLDIGITAL.pbp so it would work with the 18F4550. I didn't think it was working because I wasn't getting any messages in the Assembly window when I uncommented the DEFINE statement that lists the configs made by ALLDIGITAL.pbp. Turns out I had mispelled DIGITAL in the statement as the reason it wasn't listing the messages. Once I fixed that I discovered that ALLDIGITAL.pbp version 1.3 does already work with the 18F4550. Sorry for the confusion.
    Apr 2011
    León
    Question Re: ALLDIGITAL.pbp works OK with 18F4550
    Sorry but how can you do ALL_DIGITAL = TRUE on PicBasic PRO?
    CMCON=7? is it correct?
    Default Re: ALLDIGITAL.pbp works OK with 18F4550
    Quote Originally Posted by ietcyberwolf View Post
    CMCON = 7 is comparators off for many of the pics, not for all, each pic family (read that family members all share a common data sheet) may have very different settings in order to enable digital ports. For you, For Now, go back to the very first post in this thread and get the all digital zip file, unzip it into your pbp directory and include it as Darrel instructed you to do. In his file he has taken the time to read and understand a variety of PIC families and built in enough code to select the appropriate settings. My recommendation to everyone is read those data sheets and struggle with them and ask questions until they begin to make sense. They will begin to make sense. You can find all registers your chip uses in the mpasm suite directory in files with the suffix .inc this chip will be P16F4550.inc . To set ports digital often requires setting several registers like ANSEL, ADCON, CM0CON . . . the data sheet explains what each register does and what each bit controls.
    Read carefully POST #1.
  1. Replies: 5
    Last Post: - 16th October 2009, 18:29
  2. Digital Out on an A/D pin safe ?
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 21st January 2009, 22:48
  3. Replies: 4
    Last Post: - 24th January 2007, 22:20
  4. A/D versus Digital I/O
    By dallennn in forum mel PIC BASIC Pro
    Last Post: - 11th November 2006, 04:31
  5. Digital IC Tester
    Last Post: - 18th September 2006, 03:38
