The projects section now contains only sections that contain projects.
I think all wiki areas contain entries.
An index is something we'll have to look at, it wil take a lot of time to compile it manually, so i'll look into some way of automating articles into an index...some time...
Unless you'd like to volunteer some time, to assist with building an index and reviewing it as each new article is published?
Or maybe submit a code example for the areas that were empty??
Note, the recently introduced Include Files section - requested by a user- is empty.
A form is available to asssit with making a contribution: http://www.picbasic.co.uk/forum/misc.php?do=form&fid=1
ALL contributions to the wiki are usefull to someone at sometime - no matter how small or simple -
howabout a push to submit code examples, i'm sure that you all have little routines that you use regularly and larger programs that you've written and could donate?
