I2C Read and Write
Results 1 to 15 of 15
    Apr 2008
    Default I2C Read and Write
    Hi I was wondering if anyone could give me a clue as to what's going wrong here, it's driving me nuts? Signals look ok as far as I can see, 4k7 pull ups fitted on both lines
    I've got a P18f252 interfaceing with a 24LC84 eeprom, it's in HS PLL mode, the eeprom is the only device on the bus...
    Any help would be appreciated.
    My code is sitting in a loop with the following code...
    'defines
    'DEFINE OSC 40 ' Operating frequency
    'DEFINE I2C_SLOW 1
    'I2C_CON CON %10100000 ' Memory I2c control byte
    'i2c_sda var PORTA.0 ' I2C serial data line
    'i2c_scl var PORTA.1 ' I2C serial clock line
    mem_off = 0;
    MyWordWr = MyWordWr+1
    i2cwrite i2c_sda, i2c_scl, I2C_CON, mem_off, [MyWordWr]
    i2cRead i2c_sda, i2c_scl, I2C_CON, mem_off, [MyWordRd]
    ram[F05_HI] = MyWordRd/256 'This register can be read over modbus
    ram[F05_LO] = MyWordRd
    ram[F10_HI] = MyWordWr/256 'This register can be read over modbus
    ram[F10_LO] = MyWordWr
    Mar 2008
    Texas, USA
    change this to a var, not con
    from the pbp manual:
    " Constants should not be used for the address as the size can vary dependent on the size of the constant. "
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Apr 2008
    Hi thanks for replying... though the 'I2C_CON CON %10100000 ' is my control byte, not the address which is 'mem_off' and declared as a word.
    I'll give it a shot though.
    Thanks again.
    Derek
    Apr 2008
    Defining the control byte as a var didn't help... so I need to keep looking (
    Also I've noticed that if I put a 10ms Pause between my write and read my serial coms stops responding, does the PAUSE command disable the interupts or something?
    Make sure you have disabled all multiplexed Analog modules on the pin you're using. (ADCs and/or comparators)
    Could be interesting to see your config fuses setting... and the whole code.
    Well, I did a search for a 24LC84 and could not find a data sheet anywhere. What size is this part? If it is bigger than 32 kbits, then it probably needs a word size value for mem_off. For your ram_lo data I think you should mask off the upper byte by and'ing MyWordWrite and MyWordRead with 0xFF. Or use the .lowbyte and .highbyte modifiers. In fact, I don't see size definitions for any of your variables. Is mem_off a byte or word variable? Is ram a byte or word array? What are F05 and F10 defined as?
    Tim Barr
    Apr 2008
    First of all sorry it was a typo.... it trying to talk to a 24LC64.
    I am switching the ADC off with ADCON1 = $07, been caught with this one before. Though in this project I'm reading one of the ADC channels, so this might be worth a look.
    Fuse setting's are all default apart from HS PLL enabled.
    Mar 2008
    Texas, USA
    Is the "mem_off" variable word size? The 24C64 uses a word sized address. Your variable "mem_off" is being sent as the address. Also, just asking, but you do have the A0:A2 pins on the IC grounded for the device address "1010000", right?
    Your lines:
    are a bit odd and are going to run up a lot of code space. I'd use:
    ram[F05_HI] = MyWordRd.Highbyte
    ram[F05_LO] = MyWordRd.Lowbyte
    Alright let's try some simple things. Are the A0, A1,and A2 pins are tied to ground or VCC? These address pins also need to be correctly selected in the control byte. For the control byte you are using they should be all grounded. Is the WP pin floating or connected to gnd?
    You definately need some way of waiting 10 msec between writing and reading or you will get a NACK from the part and no read data. Also, if you want to use interrupts to manage the serial port, you will probably have to write your own serial port interrupt routine. The PB code is not really interrupt driven itself. From the PBP manual:
    "Since PBP statements are not re-entrant (PBP must finish the statement that is being executed before it can begin a new one) there could be considerable delay (latency) before the interrupt is handled."
    edit: Like minds, eh JD??
    Tim Barr
    Mar 2008
    Texas, USA
    Seems so, Tim. I didn't notice the lack of a 10ms pause though. Good catch.
    Quote Originally Posted by DerekMacom View Post
    Serial rate of 9600 baud is about 1 msec per character so a 10 msec pause could definately cause problems. The manual says this about HSERIN:
    "As the hardware serial port only has a 2 byte input buffer, it can easily overflow if characters are not read from it often enough."
    You might have to break up the pause into chunks and do a serial read in between. Maybe do 3-4 HSERIN or SERIN calls with a 2-3 msec timeout.
    Tim Barr
    Mar 2008
    Texas, USA
    Tim, it doesn't look like he's using the HSERIN. Ports RA.0 and RA.1 aren't the serial ports on this PIC.
    Apr 2008
    Hi there....
    I have a project I've 'adopted' that I've been asked to add a feature to. I'm soon going to be starting again from scratch as there are many things about the code in it's current form that aren't good. Mostly that there is way too much stuff going on in the interrupts. I was hoping to add this feature quickly but looks like this is going to be another thing to add to my 'reason's to start from fresh' list. I'm useing the internal eeprom for the time being to buy me some time until I get a chance to start fresh.
    Thank you to you all for trying to help.
    Derek
    Quote Originally Posted by JD123 View Post
    Yeah, but Derek mentioned at one point that when he put in a PAUSE he had problems with his serial comm. I figured he must have more code than the snippet he has posted.
    Tim Barr
    Heh! Saw this thread reference in another I2C thread. Looks like it might apply here to.
    http://www.picbasic.co.uk/forum/showthread.php?t=587
    Tim Barr
  1. I2C Master/Slave 16F88/16F767 working code
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  3. HARDWARE I2C SAMPLE CODE question
  4. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  5. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
