PBP array in ASM statements
Results 1 to 20 of 20
    Sep 2009
    Default PBP array in ASM statements
    I have defined a variable Counters VAR BYTE [4] bankA, and I'm using it in ISR.
    Instead Counters[0] = Counters[0] +1, I want to use @ INCF _Counters, F because it is faster.
    This is for first byte in array
    @ INCF _Counters, F
    and it works.
    For the second byte in array I tried this:
    @ INCF _Counters+1, F
    But does not work, if I use Counters[1] = Counters[1] +1 then it works.
    How to fix that?
    Default Re: PBP array in ASM statements
    ...nevermind... keep thinking...
    Sep 2009
    The same is happening with @ CLRF _Counter +1.
    And ISR stops, sometimes begins to run, sometimes I have to reset my pic
    I'm tad rusty, for ease... I would bet your should assign your array to BANK0 instead...
    post your PIC model and code, we'll try to help
    Sep 2009
    Here it is ISR
    if PIR2.1=1 then
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=IN1
       Xn.1=IN2
       IF (Xn.0<Xs.0 AND Trf=0) OR  (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN
    @     INCF _Counter,F 'this work
          IF Counter[0] = Mtp2[0] OR (Counter=256 AND Mtp2[0]=0)THEN
    @      CLRF _Counter ' and this
              CNT[0]=CNT[0] + Add[0]
       IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN
    @     INCF _Counter+1,F 'Counter[1] = Counter[1] + 1  'won't work
          IF Counter[1] = Mtp2[1] OR (Counter[1]=256 AND Mtp2[1]=0)THEN
    @      CLRF _Counter+1'Counter[1]=0 'won't work
              CNT[1]=CNT[1]+Add[1]
       Xs=Xn
    @  CLRF PIR2
    Pic is 18LF14K50
    EDIT:
    bank0 or bankA is same...
    I tried RTC,it works fine with both.
    weird... a simple loop works here,
    start:
        asm
            incf _MyArray,F
            incf _MyArray+1,F
        endasm
        myvar=myarray[0]
        myvar2=myarray[1]
        goto start
    but as you're using a blend mix of ASM and PBP in an ISR, you must make sure you're always on the good BANK case not, hell yeah it may goes to lalaland... what you could try is to set all variable that goes in the ISR to BANKA.
    And yes I know I miss something
    EDIT: The more I think, the more it looks like a bank switching issue,
        MyArray VAR BYTE[8] BANK1
        MyVar var byte BANK0
        MyVar2 var byte BANK0
        clear
    start:
        asm
            CHK?RP _MyArray
            incf _MyArray,F
            incf _MyArray+1,F
        endasm
        myvar=myarray[0]
        myvar2=myarray[1]
        goto start
    The above work... commentout the CHK?RP line.. and nope... it doesn't.
    And NOPE, BANK0 !=BANKA
    BANKA   $0000, $005F
    BANK0   $0060, $00FF
    Finger crossed before the real ASM/Compiler gurus came here and slap me a good one
    Sep 2009
    As you can see, my isr have both and asm and pbp... All variables is in bankA.
    Somewhere i read that bank for 18F doesn't matter...
    How to setup correctly banks?
    But if I use i = i +1 instead INCF everything works. INCF and CLRF work if I make a array to separate variables...
    Since we don't have the full code, or .LST file, I'll leave the more in deep & technical explanation of Access Ram, BSR and plah plah plah of section 3.3.3 to better guys (I hope I'm right though ).
    Again, the compiler keep track of everything for you, hence why the PBP lines will always works.
    add
    @ CHK?RP _Counter
    just before your INCF, DECF and or CLRF to see what happen
    Are all of your variables in the same bank?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2009
    Same thing...
    Here it's complite code
    DEFINE        OSC 4         ' We're using a 10MHz oscillator
    Define        INTHAND myint    ' Define interrupt handler
    DEFINE HSER_BAUD 2400
            OSCCON=%01010110
            OSCCON2.2=0
            OSCTUNE.7=1
            OSCTUNE.6=1
            REFCON0=0
            REFCON1=0
            ADCON1=0
            ADCON2=0
            ANSEL =0
            ANSELH=0
            CM1CON0=0
            CM2CON0=0
            SRCON0=0
            SRCON1=0
            WPUA=0
            WPUB=0
            WDTCON=0
            SLRCON=0
            RCON.7=0
            RCON.6=0
            UCON=0
            IOCA=0
            IOCB=0
            T0CON=0
            T1CON=%00001111
            T2CON=0
            T3CON=%00000110
            INTCON=192
            INTCON2=0
            INTCON3=0
            PIR1=0
            PIR2=0
            PIE1=1
            PIE2=2
            IPR1=0
            IPR2=0
            porta=0
            portb=0
            portc=0
            trisa=255
            trisb=255
            trisc=255
    'RTC_________________________
    Seconds        VAR BYTE bankA  ' variables within myint must be in bank 0.
    Minutes        VAR Byte bankA       ' Elapsed minutes
    Hours          var byte bankA
    Day            var byte bankA
    Month          var byte bankA
    Year           var byte bankA
    Ticks          var byte bankA
    DMonth         var byte bankA
    'IO________________
    SYMBOL Ul1  =PORTB.5
    SYMBOL Ul2  =PORTB.6
    SYMBOL Pull =PORTC.4
    SYMBOL UWp  =PORTC.3
    'TRIS______________
    INPUT  Ul1
    INPUT  Ul2
    OUTPUT Pull
    INPUT  uwp
    'Brojaci___________
    Brojac  VAR LONG[3] bankA
    PomBroj VAR WORD[2] bankA
    Mtp1    VAR BYTE[2] bankA
    Mtp2    VAR BYTE[2] bankA
    Add     VAR BYTE[2] bankA
    Xn      VAR BYTE    bankA
    Xs      VAR BYTE    bankA
    Wp      VAR BIT     bankA
    Trf     var byte    bankA
        year=0
        month=0
        day=0
        hours = 4
        minutes = 0       ' Pre Set time here then add seconds to clock using button
        seconds = 0
        ticks=0
        PomBroj[0]=0
        PomBroj[1]=0
        Brojac[0]=0
        Brojac[1]=0
        mtp1[0]=1
        mtp1[1]=1
        mtp2[0]=1
        mtp2[1]=1
        add[0]=1
        add[1]=1
        Trf=0
       GoTo mainloop
    @myint
    If PIR1.0 =1 then
       TMR1H=252
    @  INCF _Ticks,F
       if ticks=32 then
    @     INCF _Seconds,F
    @     CLRF _Ticks
          if seconds > 59 then
    @        CLRF _Seconds
    @        INCF _Minutes,F
             if minutes > 59 then
    @          CLRF _Minutes
    @          INCF _Hours,F
               if hours > 23 then
    @             CLRF _Hours
    @             INCF _Day,F
                  If month=2 then
                     If year//4<>0 then
                        DMonth=29
                        DMonth=28
                  Dmonth=30+month.0
                  If day>Dmonth then
    @                CLRF _Day
    @                INCF _Month,F
                     If month>12 then
    @                   CLRF _Month
    @                   INCF _Year,F
                        if year>99 then year=0
       Pull=1
       TMR3H=255
       TMR3L=207
       T3CON=%00000111
    @  CLRF PIR1
    if PIR2.1=1 then
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=ul1
       Xn.1=ul2
       Pull=0
    @     INCF _PomBroj,F 'PomBroj[0] = PomBroj[0] + 1
          IF PomBroj[0] = Mtp2[0] OR (PomBroj=256 AND Mtp2[0]=0)THEN
           Brojac[0]=Brojac[0] + Add[0]
    @      CLRF _PomBroj'PomBroj[0]=0
          PomBroj[1] = PomBroj[1] + 1  '  @     INCF _PomBroj+1,F '
          IF PomBroj[1] = Mtp2[1] OR (PomBroj[1]=256 AND Mtp2[1]=0)THEN
           Brojac[1]=Brojac[1]+Add[1]
           @ CHK?RP _PomBroj
    @      CLRF _PomBroj+1'PomBroj[1]=0'
       Xs=Xn
    @  CLRF PIR2
    @ retfie  FAST
    mainloop:
    if ticks = 0 then
     trisb.7=0
     hserout ["B1: ",dec9 brojac[0]," B2: ",dec9 brojac[1],13,10]'["Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds,13,10]
    GoTo mainloop
    If i don't use PBP for clearing and increment variable here
           @ CHK?RP _PomBroj
    Counter(Brojac) Is incremented only on first falling edge. If I use PBP, everything work fine, but code is larger for 6 bytes. I need 4 counter. Becouse device have cr3203 batery, I'm trying to make smallest possible code. Maybe I can save on space by removing or's from IF's.
    STOP THE PRESS! your problem is right here
    In theory, this is valid only for 100% Assembler ISR.
    Check for ON INTERRUPT or Darrel Taylor's INST interrupts (http://www.pbpgroup.com/modules/wfse...p?articleid=19)
    Sep 2009
    Hm...
    I did not know ...
    I've seen in the example for the RTC, so I assume...
    I will try dt_int...
    By the way banksel isn't help either.
    Thank you very much
    BANKSEL is an MPASM directive, and PBP compiler doesn't keep track of it.
    CHK?RP is an equivalent Macro to use with PBP.
    Sep 2009
    I tried, but problem stays....
    Maybe with DT_int will work.
    I will test now, and come back with the results.
    Sep 2009
    Same with DT_INT...
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
            INT_Handler    TMR1_INT,  _RTC,   PBP,  yes
            INT_Handler    TMR3_INT,  _CNT,   PBP,  yes
    'Define        INTHAND myint    ' Define interrupt handler
            OSCCON=%01010110
            OSCCON2.2=0
            OSCTUNE.7=1
            OSCTUNE.6=1
            REFCON0=0
            REFCON1=0
            ADCON1=0
            ADCON2=0
            ANSEL =0
            ANSELH=0
            CM1CON0=0
            CM2CON0=0
            SRCON0=0
            SRCON1=0
            WPUA=0
            WPUB=0
            WDTCON=0
            SLRCON=0
            RCON.7=0
            RCON.6=0
            UCON=0
            IOCA=0
            IOCB=0
            T0CON=0
            T1CON=%00001111
            T2CON=0
            T3CON=%00000110
            INTCON=192
            INTCON2=0
            INTCON3=0
            PIR1=0
            PIR2=0
            PIE1=1
            PIE2=2
            IPR1=0
            IPR2=0
            porta=0
            portb=0
            portc=0
            trisa=255
            trisb=255
            trisc=255
    Day            var byte bankA
    Year           var byte bankA
    'IO________________
    SYMBOL Ul1  =PORTB.5
    SYMBOL Ul2  =PORTB.6
    SYMBOL UWp  =PORTC.3
    'TRIS______________
    INPUT  Ul1
    INPUT  Ul2
    OUTPUT Pull
    INPUT  uwp
    'Brojaci___________
    Xn      VAR BYTE    bankA
    Xs      VAR BYTE    bankA
    Wp      VAR BIT     bankA
    Trf     VAR BIT     bankA
    Smpl    VAR BIT     bankA
        year=0
        month=0
        day=0
        hours = 4
        seconds = 0
        ticks=0
        smpl=0
        PomBroj[0]=0
        PomBroj[1]=0
        Brojac[0]=0
        Brojac[1]=0
        mtp1[0]=1
        mtp1[1]=1
        mtp2[0]=1
        mtp2[1]=1
        add[0]=1
        add[1]=1
        Trf=0
    @    INT_ENABLE  TMR3_INT
    @    INT_ENABLE  TMR1_INT
    GoTo mainloop          ' jump over the interrupt handler and sub
    RTC:
       TMR1H=252
    @  INCF _Ticks,F
       if ticks=32 then
    @     INCF _Seconds,F
    @     CLRF _Ticks
    @        CLRF _Seconds
    @        INCF _Minutes,F
    @          CLRF _Minutes
    @          INCF _Hours,F
               if hours > 23 then
    @             CLRF _Hours
    @             INCF _Day,F
                  If month=2 then
                     If year//4<>0 then
                        DMonth=29
                        DMonth=28
                  Dmonth=30+month.0
                  If day>Dmonth then
    @                CLRF _Day
    @                INCF _Month,F
                     If month>12 then
    @                   CLRF _Month
    @                   INCF _Year,F
       Pull=1
       TMR3H=255
       IF Smpl=1 then
          TMR3L=207
          TMR3L=240
       T3CON=%00000111
    @ INT_RETURN
    CNT:
       T3CON=%00000110
       Wp= Wp & uwp
       Xn.0=ul1
       Xn.1=ul2
       Pull=0
    @      CLRF _PomBroj+1         'PomBroj[1]=0
       Xs=Xn
    @ INT_RETURN
    mainloop:
    if ticks = 0 then
     trisb.7=0
      ' 2 portb.7,84,
    GoTo mainloop       ' Repeat main loop
    Edit:
    With the DT_INT code is twice bigger than it was. Maybe I could try to get rid of arrays.
    But it complicates the rest of my code... But on the other hand we will slightly extend the battery life...
    Aug 2010
    Maryland, USA
    It is likely when you enter your ISR, BSR is not 0. You can use PBP stuff in your ASM interrupt as long as you don't use any PBP stuff that uses system variables. These are things like serin/out, adcin, debug etc.
    The thing you MUST do when you first enter is BSR =0. Doesn't matter if you have all ASM or a mix. PBP assumes it is set to bank 0, when it needs a different bank, it will change to it, then change back when done that command. When your interrupt occurs, you may be in a different bank. Then none of you interrupt stuff will work correct. In fact, you may not even be able to clear the interrupt flag.
    This MAY not be the problem right now, but it will be. I spent 2 weeks trying to figure this out. Since then my interrupts work great! Give this a try.
    Now no need to worry if using on interrupt or DT_INT.
    -Bert
    Sep 2009
    I know that I can't use any PBP stuff that uses system variables. In myint I'm only using PBP If's and basic math function...
    Now I'm back to Define INTHAND. And I added BSR = 0 after @myint
    I didn't know how pbp handle banks. Thank you for your notification
    Is there need to return to the bank where he was?
    eg:
    @myint
    BSR_Save=BSR
    BSR=0
    ISR routine
    BSR=BSR_Save
    Aug 2010
    Maryland, USA
    If you are using 1 of the cool autocontex saving chips (interrupt section of the datasheet) BSR should be one of the registers saved and restored. If not, add it in to where you save w, status, and pcl. Then restore it with them.
    -Bert
    Sep 2009
    From datasheet:
    During interrupts, the return PC address is saved on
    the stack. Additionally, the WREG, STATUS and BSR
    registers are saved on the fast return stack.
    I have not thought before I asked that... Sorry...
    But I still can not find what causes problemon CLRF and INCF
    Sep 2009
    Ok...
    Let say that PomBroj is WORD not byte
    And i figure out reading .asm file... I need glasses!
    Thanks everybody.
