Same with DT_INT...
INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
INT_Handler TMR1_INT, _RTC, PBP, yes
INT_Handler TMR3_INT, _CNT, PBP, yes
DEFINE OSC 4 ' We're using a 10MHz oscillator
'Define INTHAND myint ' Define interrupt handler
DEFINE HSER_BAUD 2400
OSCCON=%01010110
OSCCON2.2=0
OSCTUNE.7=1
OSCTUNE.6=1
REFCON0=0
REFCON1=0
ADCON1=0
ADCON2=0
ANSEL =0
ANSELH=0
CM1CON0=0
CM2CON0=0
SRCON0=0
SRCON1=0
WPUA=0
WPUB=0
WDTCON=0
SLRCON=0
RCON.7=0
RCON.6=0
UCON=0
IOCA=0
IOCB=0
T0CON=0
T1CON=%00001111
T2CON=0
T3CON=%00000110
INTCON=192
INTCON2=0
INTCON3=0
PIR1=0
PIR2=0
PIE1=1
PIE2=2
IPR1=0
IPR2=0
porta=0
portb=0
portc=0
trisa=255
trisb=255
trisc=255
'RTC_________________________
Seconds VAR BYTE bankA ' variables within myint must be in bank 0.
Minutes VAR Byte bankA ' Elapsed minutes
Hours var byte bankA
Day var byte bankA
Month var byte bankA
Year var byte bankA
Ticks var byte bankA
DMonth var byte bankA
'IO________________
SYMBOL Ul1 =PORTB.5
SYMBOL Ul2 =PORTB.6
SYMBOL Pull =PORTC.4
SYMBOL UWp =PORTC.3
'TRIS______________
INPUT Ul1
INPUT Ul2
OUTPUT Pull
INPUT uwp
'Brojaci___________
Brojac VAR LONG[3] bankA
PomBroj VAR WORD[2] bankA
Mtp1 VAR BYTE[2] bankA
Mtp2 VAR BYTE[2] bankA
Add VAR BYTE[2] bankA
Xn VAR BYTE bankA
Xs VAR BYTE bankA
Wp VAR BIT bankA
Trf VAR BIT bankA
Smpl VAR BIT bankA
year=0
month=0
day=0
hours = 4
minutes = 0 ' Pre Set time here then add seconds to clock using button
seconds = 0
ticks=0
smpl=0
PomBroj[0]=0
PomBroj[1]=0
Brojac[0]=0
Brojac[1]=0
mtp1[0]=1
mtp1[1]=1
mtp2[0]=1
mtp2[1]=1
add[0]=1
add[1]=1
Trf=0
@ INT_ENABLE TMR3_INT
@ INT_ENABLE TMR1_INT
GoTo mainloop ' jump over the interrupt handler and sub
RTC:
TMR1H=252
@ INCF _Ticks,F
if ticks=32 then
@ INCF _Seconds,F
@ CLRF _Ticks
if seconds > 59 then
@ CLRF _Seconds
@ INCF _Minutes,F
if minutes > 59 then
@ CLRF _Minutes
@ INCF _Hours,F
if hours > 23 then
@ CLRF _Hours
@ INCF _Day,F
If month=2 then
If year//4<>0 then
DMonth=29
DMonth=28
Dmonth=30+month.0
If day>Dmonth then
@ CLRF _Day
@ INCF _Month,F
If month>12 then
@ CLRF _Month
@ INCF _Year,F
if year>99 then year=0
Pull=1
TMR3H=255
IF Smpl=1 then
TMR3L=207
TMR3L=240
T3CON=%00000111
@ INT_RETURN
CNT:
T3CON=%00000110
Wp= Wp & uwp
Xn.0=ul1
Xn.1=ul2
Pull=0
IF (Xn.0<Xs.0 AND Trf=0) OR (Xn.0<Xs.0 AND Xn.1=1 AND Trf=1) THEN
@ INCF _PomBroj,F 'PomBroj[0] = PomBroj[0] + 1
IF PomBroj[0] = Mtp2[0] OR (PomBroj=256 AND Mtp2[0]=0)THEN
Brojac[0]=Brojac[0] + Add[0]
@ CLRF _PomBroj'PomBroj[0]=0
IF (Xn.1<Xs.1 AND Trf=0) OR (Xn.0<Xs.0 AND Trf=1 AND Xn.1=0) THEN
PomBroj[1] = PomBroj[1] + 1 ' @ INCF _PomBroj+1,F '
IF PomBroj[1] = Mtp2[1] OR (PomBroj[1]=256 AND Mtp2[1]=0)THEN
Brojac[1]=Brojac[1]+Add[1]
@ CLRF _PomBroj+1 'PomBroj[1]=0
Xs=Xn
@ INT_RETURN
mainloop:
if ticks = 0 then
trisb.7=0
' 2 portb.7,84,
hserout ["B1: ",dec9 brojac[0]," B2: ",dec9 brojac[1],13,10]'["Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds,13,10]
GoTo mainloop ' Repeat main loop
Edit:
With the DT_INT code is twice bigger than it was. Maybe I could try to get rid of arrays.
But it complicates the rest of my code... But on the other hand we will slightly extend the battery life...
