EasyHID and USB for Newbies?? - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 69 of 69
  1. #41
    I had tried with VB Express but had quickly ditched it for VB6 from EBay. There were several things about VB Express; it lacks several features like Package Deployment which I require. I don't remember all the other reasons why I dropped it, but I "REALLY" didn't like it.
    Check out EBay for VB6, there were several cheap auctions for the academic versions of VB6. I ended up getting the full corporate version for just a bit more, with all the manuals and tutorials.
    Here's a NEW package for $125USD:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160004563299
    This kit includes:
    *Microsoft Visual Basic 6.0 Learning Edition
    *Learn Microsoft Visual Basic 6.0 Now
    *Microsoft Visual Basic 6.0 step by step
    *Microsoft Visual Basic 6.0 Programmer's Guide
    *The MSDN Library on two CD-ROMs
    Some more learning editions:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=250004751173
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=160005627793
    Here's a professional edition:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=300005730012
    The action includes:
    Microsoft Visual Basic 6.0 Professional Edition. One CD in Original Case.
    Microsoft Visual Studio 6.0 Service Pack 5.0 One CD in a jewled case.
    MS MSDN Libray-Visual Studio 6.0. 2 CDs in the original case.
    MS Visual Studio 6.0 PLUS PACK. 4 CDs in the original case.
    These are the full functional sets, not educational settings or demos.
    Good luck!
  2. #42
    Feb 2005
    Essex, UK
    Default Easy Hid Problems
    I suspect a lot of you that have posted on this thread are subscribed to it. I'm having problems with Easy HID and have posted a new subject. Obviously a lot of you guys have used it and I'm wondering what I'm doing wrong. Please chack my post out - it's driving me mad:
    http://www.picbasic.co.uk/forum/showthread.php?t=4304
    I am ONLY having problems with the PIC program on compile
    Thanks a lot
    Rob
  3. #43
    Default VB6 vs. VB Express
    I just got an started using VB Express. Yes, it's a bit different, but it works great. You do have to learn a new way of writing things, but it's "the new way of doing things" according to Micro$oft.
    If you use the "Upgrade Wizard", you can take your older VB6 type programs and import them into VB Express without much problem at all. VB Express uses a bunch of compatibility files to make it work with the old code just fine. Took me about 2 minutes to get an old serial port program with with VB Express...and the price was right too...
    JDG
  4. #44
    bigbear's Avatar
    bigbear Guest
    I am working to convert the VB file from easyHID to a REALBASIC file. I am almost there but need some help. Anyone here do anywork in realbasic? You can check out the thread here:
    http://forums.realsoftware.com/viewt...b170185ab69b24
    I will post the files for anyone who wants them when the conversion is done. Advantage of RB is it compiles into Windows, Mac OS, and Linix. Not sure if the app will work in non windows apps, but I'll find out. Looks like it should work.
  5. #45
    bigbear's Avatar
    bigbear Guest
    Also ordered free samples from microchip! Great deal!!!!!
  6. #46
    bigbear's Avatar
    bigbear Guest
    Do you guys recommend PicBasic or PIcbasic PRO? I know pro is better, but do I need it?
  7. #47
    It's up to you to decide but for the price difference between the two... it worth to invest a bit much and save tons of headaches... even if Aspirins, Advil or else are cheap
  8. #48
    Quote Originally Posted by bigbear
    It depends on what you want to do. Take a look at the commands available in each and decide:
    http://www.melabs.com/resources/pbpmanual/
    http://www.melabs.com/resources/pbcmanual/
  9. #49
    Quote Originally Posted by sean-h
    Hi rocky
    USBBufferSizeMax con 64 ' maximum buffer size
    USBBufferSizeTX con 64 ' input
    USBBufferSizeRX con 64 ' output
    I think min is 8 bytes and max 64.
    Sean.
    Nope, 1 to 64 bytes for both input and output buffers according to EasyHID help files under Configuration Details.
  10. #50
    bigbear's Avatar
    bigbear Guest
    Is there somewhere that I can see a list of the assembly codes for a PIC such as the 18F4550? From what I understand there are not a huge list of them. It has been a while since I did assembler, but I would like to have the ability to combine PBP and assembler.
  11. #51
    You'll have better luck getting an answer to an Assembler-related question if you start a new thread in the General forum:
    http://www.picbasic.co.uk/forum/forumdisplay.php?f=7
    This thread is about EasyHID and interfacing via USB.
  12. #52
    you can mix both of them using ASM and ENDASM. You can have the asm list if you open the .COD file or the .LST file
  13. #53
    Ok, I've reread this thread hoping to find a hint why the device is not recognized by windows.
    I had it working using HIDMaker FS, but I'm trying to use EasyHID since the resulting code is MUCH more compact. Here's what I've done so far:
    - generated code with EasyHID, 1 byte to PC, 30 bytes to PIC.
    - modified generated PBP program to include an LCD, that works great.
    - move MCHID.dll to VB6 working folder.
    - compiled the generated VB code using VB6.
    - started up the executable.
    - reset the PIC and that's when the error appears in Windows.
    Can the generated VB6 code work without doing any input or output? I was trying to just get a skeleton VB6 program working first, and then add 1 feature at a time.
  14. #54
    Sure the VB program can work without any in/out.
  15. #55
    Well that's good news.
    One thing that I find strange is that I don't get the same number of generated files between each software. I would have expected that both would have to override the same number of files.
    EasyHID:
    - DESCProject.ASM
    - USBDESC.ASM
    - Project.ASM
    - Project.PBP
    HIDMaker:
    - descript.ASM
    - usb18.ASM
    - usb18.INC
    - usb18mem.ASM
    - usbdesc.ASM
    - Project.BAS
    Is that normal?
  16. #56
    sure it is as log it's two diferent company.
    Let's see a common example.. Darrel's codes have more INCLUDE than mine and all other folks here... is it normal? Sure
  17. #57
    Yup, the includes are normal. I compiled the original generated code from EasyHID and the device is recognized. I'm in the process of trying to get an interrupt working for USBSERVICE. After that I'll add basic I/O between the PC and PIC and then I'll post the results.
  18. #58
    bigbear's Avatar
    bigbear Guest
    I have converted the easy HID VB template to a RealBasic Template, and it was tested by Sean (thanks again) and it works. You can download the template here.
    http://www.members.cox.net/walachcnc/usb.html
  19. #59
    Using easyhid is not that bad.
    If you wanted to receive say 10 bytes ... Just tell it to jump off to that routine and as soon as data is received it will come back from that routine with the usbbuffer(0) to usbbuffer(63) filled as such.
    So if your PC sent 10 bytes then the variables usbbuffer(0-9) will hold those 10 bytes, if your pc sent 20 bytes then usbbuffer(0-19) will hold those bytes.
    Hope this helps.
    Regards Sean.
    (yup, I saw the correction in another post about byte 0 containing the endpoint and the data being in bytes 1 to 10.)
    So if I understand this properly, we don't have to worry about any of the USB registers when we receive data. I assume this is all done by the generated assembler code?
    The important thing is for us to know the exact length of our transferred data and that's it. We don't need any interrupt either, the USBIN command will execute until all the bytes are received (returning to the label DoUSBIn until complete).
    That leaves one thing, how do we handle an error? Are we to assume everything will always work? Are there flags provided by the assembler routines? Or are we supposed to use the USB error registors described in the PIC datasheet?
  20. #60
    Quote Originally Posted by rocky79 View Post
    I am using easyHID sofware to generate a Visual basic code 6.0. I have the visual basic .net installed. So when i copy the file from vb.6 to vb.net , Vb.net upgrades the file to the .net configuration.Except for one thing that gave me an error:it's the upgrade warning about adding a delegate.
    I couldn't figure out how to fix it, Any idea??
    Sorry for the about 1 year later reply but anyways, this will be handy for new VBExpress 2005 user... probably .NET ones too.
    Today, while trying to port USBDemo From VB6 to VBExpress, i came across the same issue. The simple fix is to add those 2 lines bellow in the mcHIDInterface.vb module, right under all Declare statement
        '   adding delegate to suite VBExpress 2005 requirement
        Delegate Function SubClassProcDelegate(ByVal hwnd As Integer, ByVal msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer
        Declare Function SetWindowLong Lib "USER32.DLL" Alias "SetWindowLongA" (ByVal hwnd As Integer, ByVal attr As Integer, ByVal lVal As SubClassProcDelegate) As Integer
    HTH
  21. #61
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    .net No way for me! I will be using .com (VB5 & 6) for life. There will always be backwards compatibility for .com, no matter what. Out of interest, even the latest versions of MS Office still use .com Microsoft will never completely abandon .com, willing to bet my life on it.
  22. #62
    Apr 2008
    Unhappy
    Like a lot of you I’m just starting to migrate some of my applications to USB. I’ve tried to us EasyHID to help me get started. I’ve read threw this post and it makes sense what I’m reading. My problem is that when I try to compile the PBP file it creates I get the compilation error
    ERROR: Macro USBINIT? not found in macro file.
    ERROR: Macro USBSERVICE? not found in macro file.
    ERROR: Macro USBIN?CBBL not found in macro file.
    ERROR: Macro USBOUT?CBBL not found in macro file.
    I’ve seen several posts’ that ask this question and I haven’t seen a good answer to what is causing it and how to fix it. I suspect it has to do with directory structure.
    I’m using MCSP 3.0.0.5 and PBP 2.47.
    PIC18F4550
    Please help,
  23. #63
    Feb 2005
    Essex, UK
    Hi mjwaldner,
    Using Microcode Studio, make sure you have the correct chip selected, 18F4550. The editor sometimes defaults to a different IC when you open it - this has caught me out a couple of times!
    Make sure that all the files that were generated by EasyHID are in the same folder as the file you are trying to compile - see attached image
    Let us know how you get on
    Cheers
    Rob
  24. #64
    Apr 2008
    Red face
    Thanks Rob,
    I started over form scratch and it worked this time. I must have moved something to the wrong directory.
    My next question is. Should the computer recognize the USB device and try to install it automatically? I understand that I will need to work on the PC software to make it work but when I plug the USB cable into the PC nothing happens. It doesn’t try to install. I haven’t modified the software the Easy HID created. I just programmed it to the PIC 18F4550. Is there more code needed to initialize it.
    I’m just taking baby steps threw this. Any information is helpful.
    Matt
  25. #65
    In case it have already worked and if you haven't change the PID, VID and all other settings, if you plug the device you're not going to have any bubbles on the task bar.
    If you want some, you'll need to uninstall the device. That's pretty easy to do with USBDeview
    http://www.nirsoft.net/utils/usb_devices_view.html
  26. #66
    Apr 2008
    I found out what was going wrong. It was a hardware problem. I did not turn on the USB Voltage Regulator in the melabs programmer. So now my PC is recognizing the USB HID.
    The problem I’m having now is that I can’t seem to get any data from the PIC to the VB.Net application. My VB application is recognizing that the device is plugged in or unplugged but nothing else. The application never seems to jump into the OnRead event.
    I must be missing something. What tells the VB aplication to jump to the OnRead event?
    Any suggestions.
    Matthew
    This is what I have.
    VB.Net----------------------------------------------------------------
        ' on read event...
        Public Sub OnRead(ByVal pHandle As Integer)
            ' read the data (don't forget, pass the whole array)...
            If hidRead(pHandle, BufferIn(0)) Then
                ' ** YOUR CODE HERE **
                ' first byte is the report ID, e.g. BufferIn(0)
                ' the other bytes are the data from the microcontrolller...
                TextBox1.Text = Chr(Val(BufferIn(1)))
            End If
        End Sub
    PICB----------------------------------------------------------------------
    ' * main program loop - remember, you must keep the USB      *
    ' * connection alive with a call to USBService every couple  *
    ' * of milliseconds or so...                                 *
    usbinit ' initialise USB...
    ProgramStart:
       gosub DoUSBIn
    USBBuffer(0)=32
    USBBuffer(1)=16
       gosub DoUSBOut
       goto ProgramStart
  27. #67
    Comment out the GOSUB DoUSBIn and see if works better.
    I suggest you to have a look on USBDemo.
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    Maybe this one too
    http://www.picbasic.co.uk/forum/showthread.php?t=6463&
  28. #68
    Nov 2015
    Default Re: EasyHID and USB for Newbies??
    Hello. I'm making a program who include easyhid for the 18f4550 but I have some questions:
    I want to pass 10 decimal 2 digit variables and 11 bit variables from the PIC to the PC, then something simmilar in return. Do the usb buffers support this just declaring de proper variables?
    Or I need some kind of conversion or trick?
    Thank you for your help.
    Luis
  29. #69
    USB doesn't really work like that. The buffer is just a string of bytes, the significance is determined by your application. For instance the first byte could be the status of a LED or the first digit of a number.
    George
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  2. EasyHID max usb buffer size
    By jizyjuice in forum USB
    Last Post: - 29th November 2007, 05:12
  3. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 22:21
  4. USB and EasyHID Problems
    By Rob in forum USB
    Last Post: - 6th January 2007, 18:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
