Stable ADC readings - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 91
  1. #41
    Default Re: Stable ADC readings
    Simple, there's no voltage in there as it is right now. You'll need to modify the circuit to add some voltage there. The pull-up thing should work.
    Do yourself a big favor, output the value of the ADC reading to a LCD or to your computer, push on a single button, note the value and modify the IF-THEN value in the code.
    What are your pull-up value?
  2. #42
    On F877 or F877A there are NO pull-ups on port A. Only on Port B.
    Check this thread, seems you want to do something really alike
    http://www.picbasic.co.uk/forum/showthread.php?t=15229&
  4. #44
    Aug 2011
    10k for pull up external.
    i have only two wires to tie at right and two wires to tie ar left of steering wheel.
    So 12 buttons in fact .
    If i tie like the thread you provided , so many wires and this is the first part of entire PIC system .
    i am not sure there are enough wires after this.
    I have 25 inputs/outpouts tie to PIC .(without components reserved operation )
    Perhaps the eight outpouts/input reserved to LCD (for test before FIS tachometer connected) .
  5. #45
    The link I provided was about the OUTPUT not the input. It show how to connect your resistor and how to code it.
    your whole system to the car should be more than 6 wire... but 3 of them should already be GND or +5v/+12V.
    Plug the steering wires, push on each button, for each button you have a diffferent ADC reading.
    OR use a multimeter and measure the resistor value when you push on a single button.... also when you don't push on any button. From there we can also work out a solution.
    Also, we still have NO information about your radio, no brand, no model no nothing. At least do you know the resistor value needed for each function?
  6. #46
    Aug 2011
    Yes i tried last month , i have the value.
    I have already put schematic.
    my radio is pioneer 6900IP , only a jack remote input.
    My intension is to keep the wires buttons .
    With more wires , i have to change all connections.
  7. #47
    I know the input... how about the output?
    BTW, as per the service manual, this radio seems to use a stereo Jack... maybe you need a resistor on the tip, another on the ring? Whatever, the method on the previous link will work for the OUTPUT section.
  8. #48
    Aug 2011
    I try assembler but i have some errorsName:  assembleur bmf.jpg
  9. #49
    Assembler, C, Fortran or Pascal will not solve the problem here. The problem is not the ADC reading, it is what you do with.
  10. #50
    Aug 2011
    the soft ? picbasic pro ?????
    i have the same error with mplab
    thanks to be explicit .
    it is an example from a guy - it works for him !
    it is not easy to spend all days to arrive ( only ADC) to nothing !
    Herve
  11. #51
    Hervé, je veux bien t'aider du mieux que je peut, mais tu va devoir faire une partie des devoirs de ton coté.
    Ok, let's observe the schematic you posted
    OK, please answer the following question:
    Q1: The Resistor attached to the button are built-in the remote/Steering and you can't modify anything in right?
    A1:_______________________________________
    Q2: You have a 10K pull-up On RA0, and another on RA1... true?
    A2:________________________________________
    Q3: If so, assuming you don't push on any button, Between GND and RA0 AND between GND and RA1 with your multimeter you should read something like 1.4Volt RIGHT?
    A3:________________________________________
    From there, we need to etablish at least 4 conditions
    1) ADC reading when no push button are pressed
    2) ADC Reading when you push on Button 1 alone
    3) ADC Reading when you push on Button 2 alone
    4) ADC Reading when you push on Button 3 alone
    We can use maths to do so OR output each ADC reading to a LCD OR send the data do your PC via serial communication OR store them in the PIC EEPROM. Choice is yours. Let's see if the maths could work here.
    Without any push button pressed, I said around 1.4. Using the voltage divider theory
    (3902/(3902+10000))*5 = 1.403
    so the ADC should return something like
    (1.4/5)*1023 = 287
    Do the same with the other resistor value and you should be able to evaluate
    1) when no push button are pressed
    V = 1.4
    ADC Reading = 287
    2) When you push on Button 1 alone
    V = 0.37
    ADC Reading = 76
    3) When you push on Button 2 alone
    V = 0.58
    ADC Reading = 119
    4) When you push on Button 3 alone
    V = 0.82
    ADC Reading = 168
    Now, try this.
    '       Hardware setup
            '       I/O
            TRISA = %00000011       ' RA0 et RA1 en entrée
            TRISB = 255             ' Disconnect all resistor from the circuit
            PORTB = 0               '
            '       ADC
            DEFINE ADC_BITS 10      ' Set number of bits in result
            DEFINE ADC_CLOCK 3      ' Set clock source (rc = 3)
            DEFINE ADC_SAMPLEUS 50  ' Set sampling time in
            ADCON1 = %10000010      ' RA0 à RA3
    '       Software Variable
            ADRes       VAR WORD    ' ADC Reading
            BTN         var byte    ' Data to be sent to PORTB
            i           VAR BYTE    '
            ADCChannel  VAR BIT     '
            ADCButton   VAR BYTE [3]'
    '       Software constant
            ADCSafety   CON 10              ' min/max range for ADC Reading
            ADCNone     CON 287 - ADCSafety '
            ADCButton[0]  = 76              ' button 1 or 4
            ADCButton[1]  = 119             ' button 2 or 5
            ADCButton[2]  = 168             ' button 3 or 6
    Start:
            ADCIN ADCChannel,ADRes          ' Read ADC
            if (ADRes < ADCNone) Then       ' Any button down?!?
                                            ' - Yes!
                    FOR i = 2 TO 0 STEP -1  '   Loop through all 3 calculated posibilities
                                            '   Test against calculated ADCresult
                                            '   and allow a range of +/- ADCSafety
                            IF (ADRes > (ADCButton[i]-ADCSafety)) AND  (ADRes < (ADCButton[i]+ADCSafety)) THEN
                                            '   Valid ADC result, clear the coresponding I/O
                                    TRISB = ((DCD i) << (ADCChannel*3)) ^255
                                    PAUSE 200
                                    i=0     '   and getOut of here
                                    ENDIF   '
                            NEXT            '
                    else                    ' - NO!
                                            '   Switch to the other ADC channel
                    ADCChannel = ADCChannel ^ 1
            GOTO Start                      '
    Button 1, enable PORTB.0, Button 2 PORTB.1 etc etc.
    For testing purpose use LEDs to VDD. It works here.
  12. #52
    I Bet there are no pull ups on port A inputs.
    Aug 2011
    Guadalajara, México
    mazoul72, I'm really new to picbasic, but I note in your schematic that you don't have pull-up resistor, so please try something like this:
    Also, try to code something like the below example, if you rotate the bits of your ADC reading, you can leave only the 2 most significating bits, this way, you can know the exact button pressed (of course you must calculate correctly the resistors values):
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    ADVal var byte
    Switch var byte
    Principal:
    adcin 3,adval
    switch = (adval >> 6) 'Shift for 2 MSB for values 0 to 3 representing each button
    SELECT CASE switch
    CASE 0
    'Put your code here
    gpio=0
    CASE 1
    'Put your code here
    high gpio.0
    CASE 2
    'Put your code here
    high gpio.1
    CASE 3
    'Put your code here
    high gpio.2
    END SELECT
    goto principal
    Post #44
    Quote Originally Posted by mazoul72 View Post
    I guess it's an omission on it's schematic. At least I hope
  15. #55
    Aug 2011
    Guadalajara, México
    That's right Master mister_e, he mention the 10k pull-up before, but I want to be sure he is assembling his circuit properly (just to have peace of mind)
    By the way Master, I'm new to this forum as well to picbasic and since I first read your posts you became my "Personal Jesus"
    Regards!
  16. #56
    Don't do that, Depeche Mode have some Copyright on that quote
    Welcome aboard!
  17. #57
    Aug 2011
    Hello,
    First many thanks to your answers .
    A1:_Yes , it is too little inside because it is cms components .
    A2: Yes , it is an omission but it is 10Komhs for test ( 3.96 Volts with no action)
    A3: No , i read 3.96 Volts on 10K resistors and RA0,RA1.
    So , (3902/(3902+10000))*5 = 1.403 .
    i will verify if there is another resistors but i see 3902 ohms (i am sure) , perhaps an error . I will tell you about.
    I don't understand : TRISB = ((DCD i) << (ADCChannel*3)) ^255
    Best regards
    Hervé
  18. #58
    Aug 2011
    i don't know why 3.96 V and not 1.4 V ....
  19. #59
    3902 is actually 39K, so the other resistor are also bad... ok then. So be it.
    modify what's in red
    '       Software Variable
            i           VAR BYTE    '
            ADCButton   VAR WORD [3]'
    '       Software constant
            ADCNone     CON 814 - ADCSafety '
            ADCButton[0]  = 90              ' button 1 or 4
            ADCButton[1]  = 164             ' button 2 or 5
            ADCButton[2]  = 270             ' button 3 or 6
    should work
    This is Why I asked to measure with your ohmmeter a couple of post back... and nope I'm not going to decipher a PCB
    You have everything on hand....
  20. #60
    Check your manual about DCD, logical and bitwise operators. It's all there
    Anyone wants to explain it?
    Yes I've put some black magic in
  21. #61
    Aug 2011
    Hello Steve ,
    i have some erratic values on BTN result ( BTN = TRISB ) under pic smulator ide 6.91 .
    like 1 . 2 . 4 .255 and cycle infinite .
    But i will try this evening on led test or resistors.
    I note in 16f877x datasheet that with "1" TRISB , we have High Impedance so we can choose whose resistor to be put off .
    But with other state bit of TRISB , i don't understand how tie to common +5V of car radio (TIP) to the RB0,RB1,RBx..... ???
    We have agree that it is a result of a resistor between common ground (sleeve) and +5V (tip) on jack "grip" .
    Hervé.
  22. #62
    Never trust a sim... as simple as that. They're on the market for laziness and to make good money out of it. Good enough to replace any xBox, Nintendo... or some porn.
    You tie the resistor like the guy in that previous thread. One side on the PIC the other side are tied together and sent to the Radio.
  23. #63
    Aug 2011
    Hi Steeve,
    i test intensity value with some résistors tie together to one led.
    But with your program , trisb stay at 255 , i put some select case for test but no trisbx.0 work (255 always)
    I will try to my test platine .
    I understand your "voodoo formule" , it is for have only one button put on , no action with 2,3 .. together .
    Regards.
    Hervé
  24. #64
    Aug 2011
    i repeat my question :
    how tie the resistors on the side of PIC together to have a resultant resistor in parallele ?
    i agree that the other side is tie together to the radio , but on the ground ,yes
    but the +5V for PIC RBx ?
    Regards.
    Hervé
  25. #65
    Aug 2011
    in fact , the simulator isn't reactif with adc , i must go slowly with an0/an1 choice .
    But step by step around button(i) , it works.
    I must add six other buttons in programm and .
  26. #66
    Aug 2011
    Can i use btn as word variable for a select case like 1110111111111111 ?
    (with your formule dcd(i).... )
    i can't for the moment ...
    i use adcchannel 0 to 3 .
    Regards.
    Hervé
  27. #67
    pbp 3 manual section 2.12
  28. #68
    Aug 2011
    Hello,
    it works all !
    great and many thanks.
    I made another "formule" in addition to yours (to work with 12 buttons and 4 channels__3 buttons on a wire)
    It is perhaps not proper .
    I add to this : PIC Simulator IDE 6.91 works great , all test with it and great.
    . btn = ((DCD i) << (ADCChannel*3))^255
    . if ADcchannel = 3 and btn = %11111111 then btn = (btn - (3*adcchannel)) << i
    . gosub choose
    ADCChannel = ADCChannel + 1 'Switch to the other ADC channel
    if ADCchannel = 4 then adcchannel = 0
    choose:
    select case btn
    ' first bloc of 6 buttons
    case %11111011 ' AN0-270 --- 47k and 5k = 4.6k
    TRISB.0 = 0 ' 5k and 5k = 2.5k
    TRISB.1 = 0
    case %11111101 ' AN0-164 --- 47k and 10k = 8.2k
    TRISB.1 = 0 ' 5k and 5k = 2.5k
    TRISB.2 = 0 ' 47k and 47k = 22k
    case %11111110 ' AN0-90 --- 47k and 22k = 15k
    Hervé
  29. #69
    Aug 2011
    i am so disapointed because it doesn't work on test real card and works on simu.
    strange...
    i have microcode studio with 15 days trial .(compiler 3.0.0.1)
    TRISA = %00001111 ' RA0 et RA1 en entrée
    TRISB = 255 ' Disconnect all resistor from the circuit (Haute impédance)
    PORTB = 0 '
    ' ADC
    ADCON1 = %10000010 ' RA0 à RA3 and RIGHT JUSTIFIED
    ' Software Variable
    ADCRes VAR WORD ' ADC Reading
    btn var byte ' Data to be scan
    i VAR BYTE '
    j var bit
    ADCChannel VAR byte '
    ADCButton VAR word [3]'
    ' Software constant
    j = 0
    ADCButton[0] = 90 ' button 1,7 or 4,10
    ADCButton[1] = 164 ' button 2,8 or 5,11
    ADCButton[2] = 270 ' button 3,9 or 6,12
    Start:
    TRISB = 255
    ADCIN ADCChannel,ADCRes ' Read ADC
    if (ADCRes < ADCNone) Then ' Any button down?!?
    ' - Yes!
    IF (ADCRes > (ADCButton[i]-ADCSafety)) AND (ADCRes < (ADCButton[i]+ADCSafety)) THEN
    btn = ((DCD i) << (ADCChannel*3)) ^255
    if (ADcchannel = 3 and btn = 255) then btn = ((btn - (3*adcchannel)) << i)
    gosub choix
    pause 200
    ENDIF '
    NEXT '
    else ' - NO!
    GOTO Start
    choix:
    select case btn
    ' premier bloc de 6 boutons
    TRISB.1 = 0
    TRISB.2 = 0
    TRISB.3 = 0 ' 10k and 10k = 5k
    case %11011111 ' AN1-270 --- 47k and 2.2k = 2.1k
    TRISB.3 = 0 ' 47k and 15k = 11.3k
    case %11101111 ' AN1-164 --- 100k and 22k = 18k
    TRISB.4 = 0 '
    TRISB.0 = 0 '
    case %11110111 ' AN1-90
    TRISB.5 = 0
    TRISB.1 = 0
    TRISB.3 = 0
    ' deuxième bloc de boutons
    case %11111111 ' AN2-270 --- 47k and 5k = 4.6k
    TRISB.7 = 0 ' 5k and 5k = 2.5k
    TRISB.6 = 0
    case %01111111 ' AN2-164 --- 47k and 10k = 8.2k
    TRISB.5 = 0 ' 5k and 5k = 2.5k
    TRISB.4 = 0 ' 47k and 47k = 22k
    case %10111111 ' AN2-90 --- 47k and 22k = 15k
    TRISB.2 = 0
    case %11011000 ' AN3-270 --- 47k and 2.2k = 2.1k
    TRISB.7 = 0 ' 47k and 15k = 11.3k
    case %11101100 ' AN3-164 --- 100k and 22k = 18k
    TRISB.5 = 0 '
    TRISB.0 = 0 '
    case %11110110 ' AN3-90
    TRISB.5 = 0
    TRISB.7 = 0
    TRISB.3 = 0
    end select
    Dunno buddy, replace your resistor with LED to Vdd and see what happen, Code seems to be OK.
    On your PIC16F877, make sure you have all VDD and VSS pin connected, MCLR to VDD and the right capacitor around the crystal. If you're using an >4MHz one, set the HS_OSC fuse. Always make sure you also disable LVP in the configuration fuse too.
  31. #71
    Aug 2011
    Dunno buddy , your program Code works very well with some resistors and one led on my PIC Hardware platform test .
    With it , the intensity varies according to different buttons .
    Perhaps microcode studio with 15 days trial .(compiler 3.0.0.1) ?
    my programmer is willem with winpic800 .
  32. #72
    Aug 2011
    i 've just try compiler 2.60 plus patch 2.60c under microcode studio 3.0.0.5
    and verify fuse under willem (hs) , always the same .
    arg , no understand why if the code is good .........................../
  33. #73
    Aug 2011
    STUPID I AM , no pull-up resistors for RA2 and RA3....
  34. #74
    Post #52
  36. #76
    Aug 2011
    Hello,
    i tried with my car radio , it works well but a little slow for buttons reaction .
    Perhaps the pause ...
    I will try to integrate interrupts with it.
    many thanks Steeve.
    regards
    Hervé
  37. #77
    Good news! The code itself should be fast enough, I guess the radio need some time to process it, and sure enough, it's not on his high priority task.
    Post your code here, I'll check if I see something weird.
    PS: when you post a code here use the code tags, this way it appear in a code box, and we don't miss the outdent format. It is really simple to do.
    [code]
    paste your code here
    [/code]
  38. #78
    Aug 2011
    Steeve ,
    do you know where is the values for other functions like up/down/valid (press 2 or 3 seconds on function button) / EQ/Display ?
    I have all general functions under 100kohms .
    it is for DEH-6900IP Pioneer .
    Thanks.
  39. #79
    Nope, sorry. Their service manual makes no mention of it, and the only thing I found was something like,
    http://www.jvde.net/pioneer_wired_re...red_remote.htm
    Even the original wired remote from Pioneer make no mention of this specific feature
    http://www.pioneerelectronics.com/PU...ntrols/CD-MR70
  40. #80
    Aug 2011
    Do the diode zener serve to fix no Function if i have no +12V on input regulator ?
    Because when i put off +12V , i have a loop function (again and again.....)
