Pic16f57 + lcdout=error
Results 1 to 8 of 8
    Sep 2009
    Question Pic16f57 + lcdout=error
    When I try to compile I get this:
    ERROR: Macro LCDOUTCOUNT?C not found in macro file.
    ERROR: Macro LCDOUTNUM?W not found in macro file.
    ERROR: Macro LCDOUTDEC? not found in macro file.
    All Done, PCB, soldering. Project must be finished tomorow
    Does anybody know why this happens and how to solve this problem?
    I'm using PBP 2.60A & MCS 4.0
    Is there any hope for this project to be completed on time?
    Can you give any more information? I put a simple lcdout command in pbp 2.60a for a 16F57 (MCS 3.0.0.5), and just got a crossing page boundary warning. No errors.
    There is always hope.....
    http://www.scalerobotics.com
    Sep 2009
    Yes of course.
    All comments are in Serbian.
    Programm:
    '@ DEVICE XT_OSC,WDT_OFF,PROTECT_ON
    'DEFINE LCD_BITS 4
    'DEFINE LCD_DREG PORTB
    'DEFINE LCD_DBIT 0
    'DEFINE LCD_RSREG PORTB
    'DEFINE LCD_RSBIT 4
    'DEFINE LCD_EREG PORTB
    'DEFINE LCD_EBIT 5
    'DEFINE LCD_LINES 2
    DEFINE LCD_BITS 4
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 3
    DEFINE LCD_LINES 2
        Tz var word
        Tt Var Word
        Set var byte
        Ton var byte
        Toff var byte
        Mode var byte
        CR Var Byte
        Sn var byte
        Ss var byte
        Znak1 var byte
        Znak2 var byte
        Znak3 var byte
        Znak4 var byte
        I var byte
        symbol DQ = portb.4
        symbol Tmode= portb.5
        symbol Tp=portb.6
        symbol Tm=portb.7
        symbol Rele=porta.1
        SYMBOL SCL = portc.4
        SYMBOL SDA = portc.5
        input tmode
        input tp
        input tm
        output rele
        'adcon1=7
        clear
    ss = tm
    rele=0
    set=0
    i=0
    lcdout $fe,1, " ....."
    Lcdout $fe, $C0," www.....hr"
    pause 2000
    I2Cread SDA,SCL,$A0,0,[tz.lowbyte,tz.highbyte,toff,ton]
    if tz>600 then tz=200
    if toff=>100 then toff=5
    if ton=>100 or ton=0 then ton=5
    Pocetak:
    sn = tmode
     if sn<ss then  set= set + 1
      if set>3 then
       set = 0
    ss=sn
    select case set
        CASE 0
         znak1=" "
         znak2=" "
         znak3=" "
         call izmeri
         i=0
        CASE 1
         znak1=">"
         znak2=" "
         znak3=" "
         if tp=0 and tz<600 then
          tz=tz+5
          i=0
         if tm=0 and tz=>5 then
          tz=tz-5
          i=0
          I2CWrite SDA,SCL,$A0,0,[tz.lowbyte,tz.highbyte]
        CASE 2
         znak1=" "
         znak2=">"
         znak3=" "
         if tp=0 and ton<100 then
          ton=ton+5
          i=0
         if tm=0 and ton=>5 then
          ton=ton-5
          if Ton=0 and toff=0 then ton=5
          i=0
         I2CWrite SDA,SCL,$A0,3,[ton]
        CASE 3
         znak1=" "
         znak2=" "
         znak3=">"
         if tp=0 and toff<100 then
          toff=toff+5
          i=0
         if tm=0 and toff=>5 then
          toff=toff-5
          if Ton=0 and toff=0 then toff=5
          i=0
         I2CWrite SDA,SCL,$A0,2,[toff]
    END SELECT
     if tz+ton<=tt and set=0 and znak4="+" then 'ako je zadata temp manja od trenutne
      rele=1                    'ukljuci rele
     if (tz=>toff and tz-toff=>tt and znak4="+") or (tz<toff and toff-tz<=tt and znak4="-" ) or set>0 then             'ako je zadata temperatura veca od trenutne ili si usao u meni
      rele=0
     i=i+1
     if i >100 then set = 4 'izadji iz menija
    call prikazi
    pause 150
    goto pocetak
    Prikazi:
           Lcdout $fe,1,znak1,"+",DEC2 (tz / 10), ".",#(tz dig 0),223, "C"
           if set=0 then lcdout $fe,$89,znak4,DEC2 (tt / 10), ".",#(tt dig 0) ,223, "C" '178
           Lcdout $fe, $C0, znak2,"+",DEC2 (ton / 10), ".",#(ton dig 0),223, "C",znak3,"-",DEC2 (toff / 10), ".",#(toff dig 0),223, "C"
    Izmeri:
     OWOut DQ, 1, [$CC, $44]      ' Start merenja temperature
     Cekaj:    OWIn DQ, 4, [cr]     ' Provera da li jos traje
            If cr = 0 Then Cekaj
            OWOut DQ, 1, [$CC, $BE]      ' Procitaj izmerenu temperaturu
            OWIn DQ, 0, [tt.LOWBYTE, tt.HIGHBYTE]', Skip 4, cr, cpc]
            If tt.bit15=1 then
             znak4="-"
             tt = abs(tt)
             znak4="+"
            tt=(tt>>1)*10+tt.0*5
    It's simple thermostat with hysteresis.
    I tested it on easypic5 and PIC16F877, everything works great,but when I tried to compile for the PIC16F57, I got errors...
    When I remove LCDOUT comands, then I get this:
    Called Adresses must Reside in Lower Half of Page
    I tried to reorganize the code, remove LCDOUT, but then i get an error when using I2C commands...
    'DEFINE LCD_BITS 4
    'DEFINE LCD_DBIT 0
    'DEFINE LCD_RSBIT 4
    'DEFINE LCD_EBIT 5
    'DEFINE LCD_LINES 2
    DEFINE LCD_BITS 4
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EBIT 3
    DEFINE LCD_LINES 2
        Tz var word
        Tt Var Word
        Set var byte
        Ton var byte
        Toff var byte
        Mode var byte
        CR Var Byte
        Sn var byte
        Ss var byte
        Znak1 var byte
        Znak2 var byte
        Znak3 var byte
        Znak4 var byte
        I var byte
        symbol DQ = portb.4
        symbol Tp=portb.6
        symbol Tm=portb.7
        symbol Rele=porta.1
        input tmode
        input tp
        input tm
        output rele
        'adcon1=7
        clear
    ss = tm
    rele=0
    set=0
    i=0
    'lcdout $fe,1, "....."
    'Lcdout $fe, $C0," www....r"
    pause 2000
    'I2Cread SDA,SCL,$A0,0,[tz.lowbyte,tz.highbyte,toff,ton]
    Pocetak:
    sn = tmode
      if set>3 then
       set = 0
    ss=sn
    select case set
        CASE 0
         znak1=" "
         znak2=" "
         znak3=" "
         'call izmeri
            If tt.bit15=1 then
             znak4="-"
             tt = abs(tt)
             znak4="+"
         i=0
        CASE 1
         znak1=">"
         znak2=" "
         znak3=" "
          tz=tz+5
          i=0
          tz=tz-5
          i=0
          'I2CWrite SDA,SCL,$A0,0,[tz.lowbyte,tz.highbyte]
        CASE 2
         znak1=" "
         znak2=">"
         znak3=" "
          ton=ton+5
          i=0
          ton=ton-5
          i=0
         'I2CWrite SDA,SCL,$A0,3,[ton]
        CASE 3
         znak1=" "
         znak2=" "
         znak3=">"
          toff=toff+5
          i=0
          toff=toff-5
          i=0
         'I2CWrite SDA,SCL,$A0,2,[toff]
    END SELECT
      rele=0
     i=i+1
    'call prikazi
           'Lcdout $fe,1,znak1,"+",DEC2 (tz / 10), ".",#(tz dig 0),223, "C"
           'if set=0 then lcdout $fe,$89,znak4,DEC2 (tt / 10), ".",#(tt dig 0) ,223, "C" '178
           'Lcdout $fe, $C0, znak2,"+",DEC2 (ton / 10), ".",#(ton dig 0),223, "C",znak3,"-",DEC2 (toff / 10), ".",#(toff dig 0),223, "C"
    pause 150
    goto pocetak
    If uncomment I2C or LCDOU, I get an error...
    Sorry for bad English...
    The 16F57 is a 12-bit core, which only has 2 stack levels.
    This puts restraints on what PBP can do.
    Therefore you cannot use modifiers like DEC HEX STR etc. in your LCDOUT statements.
    And I2C commands can only use fixed pins that are declared with DEFINE's.
    DEFINE I2C_SCL PORTA,1
    DEFINE I2C_SDA PORTA,0
    You can do it by tomorrow ... maybe
    Sep 2009
    Thanks Darrel.
    I read a datasheet, and again I have not paid attention to the MCU ...
    I made a new PCB, the 16LF76, and works great ... now that I know what the problem is, I try to write a program that runs on 16F57. Now it should not be a problem.
    Thanks again.
    Maybe...
    You can use SHIFTIN/OUT in place of I2C
    http://www.picbasic.co.uk/forum/cont...-EEPROM-Part-1
    You can use the I2C statements with 12-bit cores.
    You just need to DEFINE the SCL and SDA pins.
    They still need to be specified in the I2C statements, but can't be changed at run-time.
    Sep 2009
    mackrackit,very nice explanation. I did not know exactly how I2C works, now I know. It is easier to use and I2CREAD I2CWRITE, but this is also useful.
