SerIn2 ASCII Conversion
Results 1 to 13 of 13
    Default SerIn2 ASCII Conversion
    Hello Folks, Been a long time.
    I have a program I'd written awhile back that uses modbus RTU and now we need to add the Modbus Ascii to it so either can be used. Of course the protocol is determined at start up by a jumper. RTU is tried and tested, just have to squeeze in the ASCII portion.
    The hit list:
    On Power Up Check Jumper then Set Protocol Variable
    Set Baud Rate, Parity and other Port Settings to proper values for Protocol
    Modify HSerIn to decode accordingly
    Modify HSerOut to Encode accordingly
    Using HSerin2, which is the easiest way to convert ASCII to Decimal values.
    I will be placing the values into an array of byte called BufRx.
    The incoming Ascii is like this, with out the spaces.
    :01 03 00 00 00 05 13 10
    When Decoded, after skipping the Colon, and the CRLF I should have this:
    BufRX[0] = 1
    BufRX[1] = 3
    BufRX[2] = 0
    BufRX[3] = 0
    BufRX[4] = 0
    BufRX[5] = 5
    Below, I Wait for the Colon, grab 2 char and convert to decimal and store in array until CR LF.
    I know there has to be an easier way but I'm way rusty. Not even sure if this is correct.
    HSerIn Timeout,Receive,[WAIT(":"),DEC2 BufRX[0], DEC2 BufRX[1], DEC2 BufRX[2], DEC2 BufRX[3], DEC2 BufRX[4], DEC2 BufRX[5],13,10 ]
    Richard
    Hi Richard,
    For statements that use square brackets for the parameters, like HSERIN ... The array elements must use Round brackets. Otherwise PBP gets a bit confused.
    And the 13,10 on the end isn't needed. They'll be ignored on the next WAIT.
    HSerIn Timeout,Receive,[WAIT(":"),DEC2 BufRX(0),DEC2 BufRX(1),DEC2 BufRX(2), _
                                      DEC2 BufRX(3),DEC2 BufRX(4),DEC2 BufRX(5)]
    Or, you could do it this way. Not better, just different ...
    FieldCount  VAR byte
    HSerIn Timeout,Receive,[WAIT(":")]
    For FieldCount = 0 to 5
        HSerIn Timeout,Receive,[DEC2 BufRX(FieldCount)]
    Next FieldCount
    The DEC2 should also be HEX2. Thanks for the tip on the brackets. Didn't remember that.
    Anyone remember how to change parity at runtime, not using a define?
    Quote Originally Posted by rwskinner View Post
    That whole deal went way too easy.
    Feb 2008
    Dear rwskinner
    i am looking for a modbus (RTU) slave sample code for the PIC16F877A,
    can you please share your code?
    Sorry, No. The company will not allow me to post source. However if you can tell us where your having problems at or post your code then maybe we can help.
    I found most folks are not willing to help or share code for Industrial Protocols. Mainly because there is lots of money invested in development, or in sales.
    Some code and Examples Can be found here:
    http://www.modbus.pl/microchip.htm
    Some Actual code can be found here on the list...
    http://www.picbasic.co.uk/forum/show...=&threadid=316
    It works but really needs to be doctored up some.
    Modbus Specifications and Examples in C can be found here:
    http://www.modbus.org/docs/Modbus_ov...al_line_V1.pdf
    and
    http://www.modbus.org/docs/PI_MBUS_300.pdf
    Do yourself a favor and try real hard not to try and do the 3.5 character timeout. If your a slave, look for the 8 byte request, then check the ID, if good then check CRC, then Check FC and Process or Reject with Error Code. So on. Build the packet and ship back off and be done with it.
    If your wanting to be the Master then there is a little more to it (not much) but some.
    As in the documentation
    RTU as follows:
    Slave ID 1 byte, Function Code 1 Byte, Start Register 2 Bytes, Number of Regs to Get 2 Bytes, CRC16 2 Bytes
    RTU example: 01 03 00 00 00 01 CRCH,CRCL
    Ascii as follows:
    Start of Message is a colon, Slave ID 1 byte, Function Code 1 Byte, Start Register 2 Bytes, Number of Regs to Get 2 Bytes, LRC 1 Byte, CRLF to end the message.
    Ascii is sent as Ascii Hex. :01 03 00 00 00 01 LRC 0D 0A
    I prefer to check the Slave ID first so I'm not checking CRC's all day long on other nodes messages.
    You can handl ASCII and RTU with all the same routines, except for the following.
    When Receiving the Data, you have to decode it a little differently
    When Sending the Data, you have to encode it a little differently
    LRC or CRC checks depending on the Protocol your using.
    Under my Belt so Far.
    Modbus RTU
    Modbus ASCII
    CAN STD and EXT
    J1939
    Numerous proprietary industrial protocols. Frick, Cat....
    Suppose to Start on AB DF1 soon. Arghhhh Not looking forward to it.
    Richard
    As an additional thought, I normally use the HSERIN and grab all 8 bytes of the packet, then compare the Slave ID to my own, if it matchs, then check the CRC/LRC and go from there.
    Since I'm having to use SERIN2 without the hardware USART, it might be better it I just check for the correct Slave ID in the Wait portion.
    I'm not sure it will actually make any difference would it, if there is a 20ms timeout, its still going to sit there for 20ms waiting for the message regardless right? Ah, but I remove the over head of collecting data and checking the Slave ID each time when there is other traffic on the line.
    receive:
    Gosub GetADCReadings '8 of them
    Serin2 stuff here - Timeout goes back to receive (Wait for : and grab all bytes)
    If SlaveID doesn't match go back to receive else
    Check CRC if Bad go back to receive
    Start processing message
    Send Reply
    goto Receive
    Seems to me, if the Serin2 waits for the Slave ID Byte I end up still in the wait for 20ms, but then I immediately exit back to receive, instead of processing every packet on the line, checking ID then going back to receive. Might make a little difference.
    Thoughts
    Feb 2008
    dear rwskinner
    thank you for your reply.
    at least can you please give me a working code for generating CRC for modbus RTU (in PICBASIC Pro)
    assuming that i have received from the HSERIN these byte
    BYTe_1 BYTe_2 BYTe_3 BYTe_4 BYTe_5 BYTe_6 CRC1 CRC2
    for example
    01 03 00 00 00 0A C5 CD
    how to calculate the CRC1 and CRC2
    i am using this with PIC16F877A
    Best Regards
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by mech962784 View Post
    dear rwskinner
    Best Regards
    Did you look at your other thread? There's code already there...
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 10:47
  2. ASCII to Long conversion
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 00:43
  3. ascii conversion help needed
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 13th January 2007, 07:33
  4. Hanging on SERIN2 - SOLVED!
    By blainecf in forum Serial
    Last Post: - 13th July 2006, 18:55
  5. Conversion of 10-bit word into ASCII
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 16th January 2005, 15:26
