Hello All
In my board i use a pic 18F452 that control two relays. This relays drive two contactors "power AC relays" that drive 3 phase motor for up and down motor movement
That all works, but sometimes when start or stop the motor, the pic reset, the 5v is clean with 0,1uF and 220uF, i tested with brownout disable and it is the same problem
I have changed the reset circuit from the pic with many resistor values that is paralell to the diode and the ESD resistor from the anode from the diode to the reset pin of the pic, the reset 0,1uF have changed to 1uF. With some values it is better but never total elimnate this reseting
What can i make to eliminate the reseting of the pic?
Thanks for any help and sugestion
Best regards
Pedro
