DIV32 Questions ...
Results 1 to 6 of 6
    Question DIV32 Questions ...
    For my last hair sake ...
    The attached program ( 18F452 @ 4 Mhz ) / PbP 2.47 / MPLAB 7.61a is a RPM counter for 4 Stroke 1 cyl engines ...
    Based on Period Measuring ( w/ TMR3 ) and DT instant interrupts.
    What goes wrong is the DIV32 calculation ... I've verified everything before: period is good, period measurement is right , Stable, and all data furnished to DIV 32 are "legal" ...
    But result is quite FALSE !!!
    The worse thing is I have successfully used DIV32 very often !!!
    Placing DIV32 outside the interrupt stubb gives the same results, even when cancelling interrupts while Dummy and DIV calculating ...
    I'm certainly missing something ... but what ???
    Thanks to our gurus
    PS for DARREL: All other parts of the lawn tractor computer work well ... just missing this part !!! Grrrrrr !!!
    	Dummy	 = 2500*3000		'Prédiviseur à 8 !!!
    	Vitesse  = DIV32 Periode2
    The constants are being multiplied at Compile Time. So the system registers don't have the values they would if it were multiplied at Run Time.
    If at least one of the numbers is in a WORD variable, it should work better.
    <br>
    jpohl's Avatar
    jpohl Guest
    Hi Darrel,
    just a question about the use of DIV32 instructions in the same program with your great instant interrupts lib.
    In the documentation one can read the necessary use of disable/enable command before and after the DIV32 instructions.
    Should I use also disable/enable in my program even there is no "On Interrupt" instruction? I use a timer and RBC interrupt via your interrupt interface.
    Thanks in Advance.
    Joerg
    Hi Joerg,
    Nope, no need to disable interrupts when using DIV32 with DT_INTS.
    System variables are saved and restored on each Interrupt.
    ON INTERRUPT GOTO doesn't do that, so it has problems.
    Good question though.
    <br>
    jpohl's Avatar
    jpohl Guest
    Hi Darrel,
    very good, thank you for your very fast reply.
    Best Regards,
    Joerg
    Jul 2006
    USA
    Your code doesn't resemble the code example in the manual:
    b = 500
    c = 1000
    dummy = b * c
    a = DIV32 100
    Your code:
    Periode2 = Periode / 2
    Dummy = 2500*3000
    The right numbers are not on the stack when the DIV32 occurs.
  1. Problem with Div32
    Last Post: - 22nd April 2008, 02:54
  2. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 04:33
  3. Div32
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2007, 20:26
  4. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 07:23
  5. Retrieving Div32 Remainder
    Last Post: - 20th August 2003, 03:53
