an easy way to add timer?
Results 1 to 8 of 8
    Default an easy way to add timer?
    Hello Melanie & Everyone. Up until now when I wanted to run a program for a specific time I would simply count a variable:
    high portb.0
    low portb.0
    let X = X + 001
    if X >= 10 then XXXXXX
    This program will flash an LED 10 times and jump to a different loop. However, is there a way, an EASY way, to substitute the last 2 lines with a "backround timer" that will automatically jump to XXXXXX after say 5 minutes or whatever regardless of what the PIC is currently doing? Thank you. - Peter
    Dec 2003
    Wichita KS
    Hello Peterdeco1,
    PC1>>high portb.0
    low portb.0
    let X = X + 001
    This program will flash an LED 10 times and jump to a different loop. However, is there a way, an EASY way, to substitute the last 2 lines with a "backround timer" that will automatically jump to XXXXXX after say 5 minutes or whatever regardless of what the PIC is currently doing?<<
    Ouch.. this is called multi-tasking, and PICS do not multi-task. I was trying to think of something like the PWM, which can put out a signal while other things are goin on in the chip.
    I would like to see if anyone comes up with a idea...
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    This sounds like something the timer and interrupt could be used for. How to actually do it though is totally greek to me.
    Watch this space... I have a topical example of timer/interrupt usage that I'll post shortly... just as soon as I shoot a couple of awkward clients first...
    Finally...
    "How to actually do it though is totally greek to me."
    It's Athen's Olympics time... and we do need to go Greek...
    see Olympic Timer in the Code examples section...
    http://www.picbasic.co.uk/forum/show...=&threadid=632
    Re Multi-tasking.
    Usually you need multiple or parallel processors to do multitasking. Most computers give the illusion of multitasking through a process of time-slicing - ie devoting a portion of the overall CPU time to a given job, then switching to another task. If done fast enough then you have your multi-tasking illusion (typical example is Microsoft Windows).
    Actually PICs do genuinely multitask quite well. They're able to sample an ADC channel, perform multiple Timer functions, execute PWM trains, catch data in the USART and perform Analogue Comparisons all genuinely simultaneously whilst your program is doing something completely different. It's called using the features provided within your PIC and the secrets of exploiting these multitasking features are... in the Datasheet.
    Melanie
    Default backround timer
    WOW Melanie! I downloaded your Olympic Timer. You're program is a work of art and is lightyears ahead of my question about a backround timer. I wish I knew a fraction of what you know about PBP (I think I said this before). Here is a simple program using a PIC16F818. It is transferring data from porta to portb.0. The problem is if I make it count time (let X = X + 001 : pause 1000 : if X = 60 then loopXXX : goto begin) I lose the data transfer during pause time, even if pause time is reduced to milliseconds. Is there an EASY way I can make it jump to loop XXX after 1 minute?
    OSCCON = $60 'set int osc to 4mhz
    ADCON1 = 7 ' set inputs to digital
    TRISA = %11111111 'porta inputs
    TRISB = %00000000 'portb outputs
    begin:
    let portb.0 = porta.0
    goto begin
    ***AFTER 1 MINUTE JUMP TO LOOPXXX***
    loopXXX:
    let portb.0 = porta.1
    goto loopXXX
    Thanks everyone for your input (pun intended!) - Peter
    Well, just take the Olympic Timer as an example and strip it out and refit it to your requirements (after all that's why I created it)... First let's take that interrupt handler and rebuild it to toggle a Flag every minute instead of keeping track of actual Minutes, Hours and Overflow which are unnescessary for your needs....
    	'	Timer Interrupt Handler
    TickCount:
    	Gosub SetTimer
    	Hundredths=Hundredths+1
    	If Hundredths>99 then
    		Hundredths=0
    		Seconds=Seconds+1
    		If Seconds>59 then
    			Seconds=0
    			MinuteFlag=MinuteFlag^1
    	Resume
    The SetTimer subroutine can be simplified to junk the Calibration value like so...
    	'	Subroutine Loads TMR1 values
    SetTimer:
    	T1CON.0=0
    	TMR1RunOn.Highbyte=TMR1H
    	TMR1RunOn.Lowbyte=TMR1L
    	TMR1RunOn=TMR1Preset+TMR1RunOn
    	TMR1H=TMR1RunOn.Highbyte
    	TMR1L=TMR1RunOn.Lowbyte
    	T1CON.0=1
    	PIR1.0=0
    Finally we lose our entire Main program body, Reset Code, Calibration Set-Up, and all the unnescessary subroutines, EEPROM settings etc etc leaving us just your desired application... and if you notice the main body is pretty much the exact code that you've written... so in effect you were already 99.9% of the way to your own solution...
    	'	Software Defines
    	Hundredths var BYTE
    	MinuteFlag var BIT
    	Seconds var BYTE
    	TMR1RunOn var WORD
    	'	Software Constants
    	TMR1Preset con $D910
    	'	Start Program
    		'	Initialise Processor
    		'	Put your TRIS and Register initialisation statements here
    	MinuteFlag=0
    	Hundredths=0
    	Seconds=0
    		'	Initialise TMR1 Interrupts
    	Gosub SetTimer
    	On Interrupt goto TickCount
    	PIE1.0=1
    	INTCON.6=1
    	INTCON.7=1
    	'	Main Program Loop
    	Enable
    Begin:
    	If MinuteFlag=1 then goto LoopXXX
    	goto begin
    loopXXX:
    	goto loopXXX
    	Disable
    Just remember that no command in your Main Program Loop can exceed 10mS execution time otherwise you will lose your timing integrity (program won't die, but you won't get a 1 Minute timing interval for the Flag to toggle, it'll be 1 Minute plus the number of 10mS interrupt ticks you've missed).
    If accuracy in your minutes is important to you, adjust the TMR1Preset constant. Increase the value to speed up by 100uS per minute, Decrease the value to slow down by 100uS per minute (at 4MHz clock).
    See... easy peasy... don't be afraid to take any of my code and trash it into anything that you need... it's posted for you to learn from.
    Melanie
    Just a final note... I estimate the Interrupt Handler to take less than 100uS to execute once every 10mS (with a 4MHz PIC). If your application still loses data, then there are only two options...
    1. Go to a faster PIC
    Naturally all the Interrupt timings will be shot and will have to be recalculated for a new value for TMR1Preset - but that's no big deal... should take less than a minute out of your life to do that...
    2. Rehash the SetTimer and TickCount Subroutines
    Rather than have one interrupt every 10mS, engaging TMR1's prescaler we have a potential interrupt range of 1uS through to 524.288mS... so we can redesign the routines to interrupt every 500mS (only 120 times in a minute) rather than every 10mS (6000 times in a Minute).
    Melanie
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 08:41
