ds 1307
Results 1 to 15 of 15
Thread: ds 1307
    Question ds 1307
    having trouble finding post useing thgis dallas clock chip in pic basic pro
    searched under ds 1307 and rtc no listing
    can someone supply thread
    thanks
    try with ds1307 in one word.
    One nice code example HERE
    Question ds 1307
    great program must have taken a lot of work
    any way to get a schematic diagram or hook up sheet??
    Euh... i don't see why as almost everything is really well explained in the hardware assignment section of the code.
    Default hookup
    ok will try that
    one more question trying to use with a 16f877a
    get error messag but compiles
    102 crosses boundry at @800h
    already got protype board for this setup for this chip
    any ideas?
    http://www.picbasic.co.uk/forum/show...osses+boundary
    It's just a warning, nothing important. If you're using MPASM to compile your code, just add
    @    errorlevel -306
    and this will remove this stupid warning.
    And, here's another endorsement
    http://www.picbasic.co.uk/forum/show...02&postcount=1
    At least, i don't feel alone
    Default error
    ok howeve i am not using mpsam
    get lot more errors in program with this
    thanks
    for your help
    Mentor, Ohio
    Smile
    Hi jcleaver,
    You could save everyone alot of time and sanity if you would just post, for example, the errors you ARE getting and what compiler and assembler and version levels you are using. Perhaps even a screenshot of the list of errors from your program.
    The program Mister-E referred you to was written for a 16F628. You are using a 16F877A. I apologize if I assume something here but you will have to make a number of setting changes to port over to the 877A. Analog ports on the 877A not on the 628, config fuse settings, etc.
    We can help but give us the data we need!
    BobK
    Default more info
    did finally get something to work attached program but for some reason i am unable to duplicate this again seems to be the clock wont start
    using pbp and mcs tried using mpspam with this but too many errors to count if someone could look over this listing and explain why the clock is not starting once itruns which i dont know how i got there it does what i want
    thanks
    ' PicBasic Pro program to display result of
    ' 8-bit A/D conversion on LCD
    ' Connect analog input to channel-0 (RA0)
    @ DEVICE pic16f877a, HS_OSC, WDT_ON, PWRT_ON, LVP_OFF, PROTECT_OFF
    Define LCD_DREG PORTB ' Port for LCD Data
    Define LCD_DBIT 4 ' Use upper 4 bits of Port
    Define LCD_RSREG PORTB ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 3 ' Port Pin for RS bit
    Define LCD_EREG PORTB ' Port for Enable (E) bit
    Define LCD_EBIT 2 ' Port Pin for E bit
    Define LCB_BITS 4 ' Using 4-bit bus
    Define LCD_LINES 2 ' Using 2 line Display
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 50 ' Data Delay (uS)
    DEFINE OSC 20
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    define loader_used 1
    adval var byte ' Create adval to store result
    AD33 VAR BYTE
    W1 VAR WORD 'PUSHBUTTON
    I VAR WORD
    TRISD = %11111111 ' SET PORTD TO INPUT
    ADCON1 = %00000010 ' Set PORTA analog
    ' Low PORTE.2 ' LCD R/W line low (W)
    ' Define I2C bus ports
    B0 VAR BYTE
    B1 VAR BYTE
    B2 VAR BYTE
    SDA VAR PORTC.4 'DS1307 SDA pin
    SCL VAR PORTC.3 'DS1307 SCL pin
    DEFINE I2C_SLOW 1
    DEFINE I2C_HOLD 1
    DEFINE I2C_SCLOUT 1
    Pause 500 ' Wait .5 second
    ADDR VAR BYTE
    ADDR = 0
    PAUSE 1000
    CONT CON %11010000
    secs var byte
    mins var byte
    hrs var byte
    day var byte
    date var byte
    month var byte
    year var byte
    ctrl var byte
    I2CWRITE SDA,SCL,CONT,ADDR,[$00,$59,$11,$03,$25, $12 ,$03, $10]
    PAUSE 5000
    I2CREAD SDA,SCL,CONT,ADDR ,[b2]
    loop:
    COUNT portd.1,750,w1
    lcdout $fe,1
    lcdout $fe,$80+4 ,"count: ", dec w1
    I2CREAD SDA,SCL,CONT,ADDR ,[secs,mins,hrs,day,date,month,year,ctrl]
    ADCIN 0, adval ' Read channel 0 to adval
    ADCIN 1, AD33
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "Value: ", # adval ' Display the decimal value
    LCDOUT $FE,$C0, "VALUE : ", DEC AD33
    Pause 500 ' Delay for .5 seconds
    lcdout $fe,1 ' clear display
    lcdout "min: ", hex mins
    lcdout $FE,$C0,"secs: ",hex secs
    Goto loop ' Do it forever
    Default values
    noticed all the values min sec ect go to 02 hex regardless of what my inital setting is
    Any Back-Up battery attached to this DS1307?
    Quote Originally Posted by DS 1307 datasheet
    Backup Supply Input for Any Standard 3V Lithium Cell or Other Energy Source. Battery
    voltage must be held between the minimum and maximum limits for proper operation.
    Diodes in series between the battery and the VBAT pin may prevent proper operation. If a
    backup supply is not required, VBAT must be grounded.
    Any Pull-Up on SDA and SCL pins?
    Mentor, Ohio
    Smile
    Hi jcleaver,
    Do you have your RTC variables declared in your program? Look on page 2 or the Project MN1307 program about 1/2 way down.
    Also do you have a statement "RTCSec.7 = 0". You need this to start the clock running. The clock chip powers up with RTCSec.7 = 1 which turns the osc off.
    Your program could be returning the errors if you don't have the clock variables declared. Guessing at this point.
    I see you have several segments to your program. You should take each one step by step. First get your LCD working. Something like a "Hello World". Then get the A/D portion working. Then add the clock program.
    HTH,
    BobK
    Default ty
    was the bat conn not grounded appreicate all your help getting this going
    thanks again
    Default ?
    that solved the problem of everything going to 02 but the clock is still not running i am sending $00 to secs on inital start up do have pullup on scl and sda so i guess im not as far along as i thought
    Default working
    think i got it circuit board problem i hope
    again thanks now i just have to add temp and i got this one done
    let you know
  1. 1307 RTC accuracy?
    By amgen in forum General
    Last Post: - 6th October 2008, 19:03
  2. Need help PIC 18F2550 with DS 1302
    By christina86 in forum mel PIC BASIC
    Last Post: - 28th December 2007, 02:05
  3. ds 1307
    By jcleaver in forum mel PIC BASIC
    Last Post: - 30th June 2007, 13:28
  4. ds 1307 revisted
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 17th February 2007, 15:10
  5. DS 1620 Code example?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 27th September 2006, 03:45
