help to compile from a different directory of pbp.exe
Results 1 to 2 of 2
    cirknop's Avatar
    cirknop Guest
    Default help to compile from a different directory of pbp.exe
    how can I compile a code source *.bas from a different directory of pbp.exe,
    and after have my *.hex in a same directory of my *.bas
    I use codedesigner
    (sorry for my english I'm french...)
    [email protected]
    I can't help you with Codedesigner as I don't use it, however, with regard to different directories...
    Example...
    My PBP compiler files are located in...
    H:\data-reference\PIC\PBP244
    The project I'm working on is located in...
    H:\Myproject
    Ensure you have a DOS window open and logged into the \Myproject subdirectory with a path to PBP's location... by default on opening a DOS window, Win-XP drops me into...
    H:\Documents and Settings\Melanie>
    So all I do is...
    cd\Myproject
    Path H:\data-reference\pic\pbp244
    Actually I have those lines contained in a batch file called gopbp.bat and by simply calling 'gopbp' it logs me into my working directory and sets all the paths I need approprately.
    Once logged into the working directory, I use the command line as normal... eg...
    pbpw -p16f876 myfile -v
    If you use the MPSASM assembler, simply add it's location to the end of your path statement...
    Path H:\data-reference\pic\pbp244;H:\Program Files\MPLAB IDE\MCHIP_Tools
    If you run older versions of Windows (or even DOS), it may not like subdirectories with long names or filenames with spaces in them. In that instance you are limited to directories with eight or less characters, no spaces or other hieroglyphs.
    Melanie
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 17:43
  2. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  3. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 09:18
  4. Replies: 2
    Last Post: - 9th February 2006, 23:03
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
